Question about Tricity Bendix AW1000W Front Load Washer
Help me to wash!!
I just bought second hand a Bendix concerto washing machine approx 7 years old, and i have no idea how to work it. all it seems to be doing is filling with water and draining out, no washing or spinning???? what number do i turn the dial to do just a normal wash and spin cycle???
  • Anonymous Apr 20, 2008
    Hi I have just bought a second-hand Bendix Concerto 5kg washing machine (W1043N) and I can't find a manual for it. does anyone know where I could find one?
    this sounds like a syphoning problem this means the outlet /drain pipe at the back of the machine has been pushed to far into the drain upstand pipe causing the water to syphon straight through the machine make sure that the drain pipe is only part way down the drain pipe, hope this works for you
Posted on Oct 16, 2007
Drum won't spin on Tricity Bendix AW 1260W washing machine. What do I replace? Is it worth it? Machine is 7 years old.
Hi just food for thought,I normaly fix my things that are brocken,but I was told by a washing machine teck that the life span is usuely 5years,some times you get lucky and other times it gose wrong and you keep throughing money down the drain,I wish you the best and hope it works out for you if you deside to try and fix it.
Nov 21, 2016 | Tricity Bendix Washing Machines
Tricity Bendix AW1400W Loud noise when spinning
The turning tube's belt or bearing may have problem.
If you know how to tighting the drive belt, you may try.
If not, maintenance or service persone should to call.
May 28, 2017 | Tricity Bendix Washing Machines
Zanussi FJS 1425W - the machine is not spinning the clothes so clothes are quite wet when they are washed so have to spin but this is also not working well - washing purchased approx 7 yrs ago -
hotpoint top loading washing machine serial number TS182924N MODEL NUMBER HNXR1060T8WW. machine won't spin and will not empty water, just a humming noise. number on scamatic diagram 175D275OGO71 MACHINE IS APROX 20 YEARS OLD
Jan 06, 2010 | Zanussi Washing Machines
This Bendix washing machine is approx. 26 years old!! ......still washes exceptionally well but, the spinning process is becoming less efficient and a little noisy at times.Could this be a ' belt ' problem...
Worn belts don't usually make noise unless they are slipping or are disintegrating. You may have to wait while the parts dealer orders one. Shake the agitator and drum sideways in various directions. Expect some looseness and it may also be the source of some of the noise while running. As long as things don't progress to 'knocking', a little looseness should not hurt.
Aug 19, 2009 | Washing Machines
Trinity Bendix 1000- inside smells of drains
are you using gel casules that go into the machine instead of powder if so stop using them and go to powder also put a small cap full of bleach in machine and put machine on a hot wash no clothes in.let machine rinse through
Jun 23, 2009 | Tricity Bendix WDR1040W Front Load Washer...
0E flashing on Westinghouse LF708C Washing Machine
Had the same problem. After checking that all the hoses etc were clear and no blockages, then suspected that the pump (cost $90 Australian dollar) was faulty. The Westinghouse service technician acknowledged that that was probably the problem, which I then confirmed by pulling out the pump, and then carefully connecting 240V across the pump terminals. Certainly was a faulty pump. So I spent the money on a new pump and installed it and now the washing machine (6 to 7 years old) works fantastically.
Apr 10, 2009 | Westinghouse Washing Machines
Bendix Washer/Dryer WDB 1074T
Well well well - Welcome to the Bendix Club!
Here is the secret!
Push all 4 buttons in!
Turn on the Cold water only!
Set the first dial on 3 dots before the GREEN #12
Set the second dial to snow or cold
Set the third dial to one dot after the green 7....
If this doesnt work...the something is wrong with the machine!
Or email me.
Apr 28, 2008 | Tricity Bendix WDR1040W Front Load Washer...
if it,s 7 years old. you,ve had your moneys worth. Scrap it and buy a new one.
as a repair solution, Check that the machine is emptying.
And that the pump has,nt got a coin/badge or anything else wedged in it.
Mike @ Compurepair.
Feb 25, 2008 | Washing Machines
Tricity Bendix AW1000W Front Load Washer Logo
296 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
