Question about Dell 1503FP 15" LCD Monitor
Dell model No. 1504FP will turn on for 3 sec then off
This display will turn on for 3 seconds then it will turn off, i have power but only the display is off after 3 sec. is my problem in the power supply board or the CPU board or the display it self, thanks
  • Moe Kananah May 12, 2009
    thank you Rod. but this monitor is not mine and thats what i told its owner and Iam in jordan overseas, and LCD monitors are very expensive here, i bought sony 19" from the states while i was there, but this is what i do for living here in jordan, fixing LCD's and laptops, thanks again for your quick response
  • 1,602 Answers
THE PROBLEM IS THE MONITOR IT SELF.
IT IS TIME TO BUY A NEW MONITOR. I KNOW ALOT OF OF US CANNOT AFFORD A NEW MONITOR EVERY TIME ONE BRAKES, I HAVE FOUND THAT SECOND HAND STORES SALE THERE MINITORS FROM 1-2 DOLLARS PER INCH, I PICKED UP IBM FLAT SCREEN 20" AROUND 20.00 USD. AND IT STILL RUNNING AND I HAVE HAD IT FOR A YEAR OR MORE NOW.
Posted on May 12, 2009
Dell 1504FP hdmi
It doesnt matter how many different ways you connct the monitor it will only support one input at a time
May 12, 2014 | Dell UltraSharp 1504FP 15" Flat Panel LCD...
Neither picture is displaying on moniter nor sound is coming (DELL TFT moniter)
Which is a dell tft or compaq crt monitor ?
The Dell 1504FP is a flat panel LCD monitor that has a viewable area of 15 inches.
The monitor, which uses TFT technology, is designed to be used in a home or office and displays video at a resolution of 1024 x 768 pixels.
Over time, you may encounter problems using your Dell 1504FP monitor or it may cease functioning altogether.
Fortunately, there are variety of ways that you can repair the monitor to get it back up and running.
Shut down your computer and press and hold the power button on the side of your Dell 1504FP monitor if your monitor has a blank screen.
Unscrew the VGA video cable that connects the monitor to the computer.
Power the Dell 1504FP monitor back on and wait as it launches into the Self-test Feature Check.
During this period of time your monitor will make settings changes to ensure that it functions properly with your computer.
Firmly screw the VGA cable back into the rear of the monitor to ensure optimal video quality. Power both the monitor and computer back on and wait for your computer's desktop to appear.
Power off your Dell 1504FP monitor if the screen is dirty.
Wipe down the monitor using a dry microfiber cloth to remove any dust particles or smudges that have accumulated on the screen over time.
Power the monitor back on when you are complete and resume using it.
Press the "Auto Adjust" button on the right side of your Dell 1504FP monitor if the display is blurry and images appear out of focus.
Unplug the monitor's power cord for thirty seconds if the problem persists.
Plug the monitors power cord back into the rear of the device and power it back on.
This will reset the monitor and your display should now be focused properly.
http://support.dell.com/support/edocs/monitors/1504fpis/en/trouble.htm
Troubleshoot a TFT Monitor
TFT monitors can suffer from many potential problems, ranging from simple screen brightness issues to disconnected inverter or LCD cables.
These can cause video- and backlight-related failures on your TFT monitor.
Fortunately, you can attempt to repair these problems, even if you have no experience fixing a TFT monitor.
The only tool you will need is a Phillips screwdriver, although opening your TFT monitor will likely void its warranty.
Check the brightness settings on the TFT monitor.
There are dedicated adjustment keys on the bottom face of the TFT monitor.
If it is a screen incorporated into the design of a laptop, you'll find monitor adjustment keys on the top row of the laptop's keyboard.
A TFT monitor that has its brightness turned all the way down will appear to be almost completely dark.
Ensure the TFT monitor's power cable is still plugged in, if it is an external monitor. In the case of a laptop, make sure that the power cable is plugged in or that the battery is properly charged.
Disconnect the TFT monitor from the power source. If the TFT monitor is an external model connected to a computer tower, disconnect the video cable as well.
Remove the battery from your computer if you are using a laptop.
This is an important safety measure.
Turn the laptop over and slide the battery release mechanism over.
This mechanism is just below the horizontal outline of the battery on the underside of the laptop.
Remove the screws on the bezel of the TFT monitor.
The bezel is the plastic piece surrounding the TFT screen.
The screws will likely be covered with plastic seals for aesthetic purposes, so pop these seals off with your fingers and remove the screws using a Phillips screwdriver.
Pry up on the bezel gently and remove it.
Start at one corner and work along the bezel's perimeter with your fingers.
There will be small plastic latches between the bezel and the rest of the computer you'll need to disengage.
Check the TFT monitor's inverter cable.
This black cable lies at the bottom center of the monitor and should connect to a socket on the inverter board, which is the green color horizontal strip that lies just below the inverter cable.
If the cable is loose from the board, the TFT monitor's backlight will fail. Pull up on one side of the socket and slide the cable back in, then press firmly down on the socket to lock it down.
Remove the metal brackets on either side of the exposed TFT monitor if the inverter cable fix does not solve your issue.
There will be two to three screws in each bracket that must be removed using your Phillips screwdriver.
Pull the TFT monitor carefully away from the rear casing of the display to reveal the LCD cable. This cable runs from the back of the TFT screen and should be connected to a socket in a similar fashion to the inverter cable. If it is disconnected, lift up on the socket, slide the LCD cable back in, then press down on the LCD socket to lock it back down.
NOW FOR SOUND
if you can get a screen
Click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question / exclamation? ! mark or a red X Right click to reinstall drivers
If your computer came with a motherboard disk the drivers could be on it
or you might download slimdrivers.
Rather doing a driver hunt
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
Note: it will find all of your outdated drivers
This is a free driver solutions
which will automatically search for and find the correct driver
You will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
It might take some time being free
Aug 09, 2013 | HP COMPAQ 7540 CRT Monitor
M y DEll 1504fp has the same problem with 2 secs and back to black however I can not seem to find any inforamtion on what to change as there seem to be types of boards on this and all the info I can find...
If you facing technical problems while using Computer, Laptop, Printer and looking for a trustworthy and professional tech support service, then Dell technical support phone Numbers is solve your problem. To know More call : +1-800-204-4427 http://www.delltechnicalsupportphonenumbers.com/canada
Jun 21, 2017 | Dell UltraSharp 1504FP Monitor
When i turn it on it says ' cannot display this video mode '
try to play the vedio on diffrent players or try to download the different code of the player that you used
try downloading media player classic or km player
Oct 22, 2010 | Dell UltraSharp 1504FP 15" Flat Panel LCD...
Powers up, screen visible for about 3 seconds then goes blank.
There are two versions of the power supply/inverter PCB assembly, you need to look inside to see if it has any bad caps with bulging tops first, then post back so we can guide you further.
http://lcdrepair.us/1504fp-inverter-power.html
http://lcdrepair.us/1504fp-power.html
Feb 18, 2010 | Dell UltraSharp 1504FP Monitor
My monitor(1504FP) only work for 4 seconds after you turn it on, Then it goes blank.so just to use it I have to constanly turn it on and off every 4 seconds. Ive used the blue cord on another comuter and...
you monitor needs capacitors or a capacitor and maybe a bulb that is not to hard for a tech ,but depending on the size and scope of the monitor i would just buy a new one
Oct 20, 2009 | Dell UltraSharp 1504FP 15" Flat Panel LCD...
Where do I find the Model # on my Monitor? I wish
Its printed on a sticker at the back panel of your monitor where you connect the power cord
May 15, 2009 | Computers & Internet
Monitor going to power save mode and freezing
Hi, i have had that problem before and its wasn't the graphics card drivers, it was loose, anyway for you case go to device manager and uninstall the graphics drivers from there then restart and install then manual by updating and locate the exact location from the cd or any other location that has them.
That should help
Cheers
Apr 27, 2009 | XFX NVIDIA GeForce FX5200 Graphic Card
MODEL DELL 1504 FP
I have one with no backlight. The capacitors on the board are bulging. In my opinion they were designed too close to tolerance and "cooked out". As long as it's still working change the ones in the Regulator circuit(3 in the middle of the heatsink area), and the four really small ones over by the transformers. Should be right as rain.
Aug 18, 2008 | Dell UltraSharp 1504FP Monitor
Dell 1503FP 15" LCD Monitor Logo
351 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
