canon i950 light flashes orange 7 times then green once but still will not print. Have replaced all ink tanks and have even tried to do a deep cycle clean but it still will not work
Starting with printer in off condition holding reume and then power respectively,now press resume twice and and release power button le green light blink until printhead has finished moving now is the most crucial information that has to be followed
0 presses - green light - Test Print 1 press - orange light - EEPROM info print 2 presses - green light - EEPROM initialise 3 presses - orange light - reset waste ink counter.
Hello. My Canon i950 was showing 8 yellow flashes indicating the ink waste tank is getting full. I...
(More)
Hello. My Canon i950 was showing 8 yellow flashes indicating the ink waste tank is getting full. I removed the ink pads in the bottom of the unit. I cleaned them and let them dry before replacing them. I followed the code directions and the yellow light does not blink now, just solid green, but it won't print either. Only error message is, problem with printer. Help Please!
Printer: Canon i950. Two problems: The "utility" icon on the computer is grayed out and...
(More)
Printer: Canon i950. Two problems: The "utility" icon on the computer is grayed out and non-functioning. The larger problem is that when I try to print a black document, it comes out a faded, washed out almost pea-green color. I printed a test page - what should be black is pea-green. As I said, the "utility" icon is grayed out and I can't access that. Any suggestions, hints, solutions, etc.? Thanks! mg
Reds are not printing on my canon i950 ink jet printer. (Mac OS X) I have used the utility to...
(More)
Reds are not printing on my canon i950 ink jet printer. (Mac OS X) I have used the utility to perform several cleanings and at least 2 deep cleanings. I used a Q tip with rubbing alcohol to wipe the port where the ink is fed to the nozzle, still no reds. What can I do.
