Question about Dryers
Whrilpool gas dryer lgn2000jqd stops heating half way
Whrilpool gas dryer starts up. heats up then goes cold
    Problem Solver:
  • 16 Answers
U have a maf coil the dryer has a prim/ second coil remove and replaced come in a kit
Posted on May 13, 2009
Hotpoint dryer will not heat - cold air only also the dryer will not stop running unless on no heat setting
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101'';;
Sep 08, 2011 | Hotpoint Dryers
I have whrilpool dryer and I am getting no heat, dryer runs but no heat. Sensor and thermo fuse good. Timer keeps clicking if dryer is off but knob is in some cycle position not off position. Open door and...
heatman101
Aug 12, 2011 | Dryers
Admiral Gas dryer will start to heat when first turned on then goes cold. The dryer will not stop running but will not heat. Any help would be appreciated. Thank you Jason
heatman101';
May 27, 2011 | Maytag ADG7005AWW Gas Dryer
The gas coils are ok by measuring them, the exhaust tube is clear but the igniter still stops half way on a maytag dryer sdg3606aww
heatman101
May 25, 2011 | Maytag SDG3606A Gas Dryer
My dryer will not stop automatically(have to open door to stop it) and will not heat....just cold air.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 16, 2011 | Kenmore Dryers
Whrilpool estate dryer model egd4400sqo not heating up
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 20, 2010 | Estate EGD4400SQ Gas Dryer
Gas dryer heats for couple minutes then goes cold
sounds like gas valve is not opening. your ignitor has to pull 3.2 to 3.6 amps to open gas valve. check amps
Jun 22, 2009 | Kenmore 63942 Dryer
Maytag atlantis gas dry is not heating up its about 6 years old
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Mar 28, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
152 people viewed this question
Top Dryers Experts
