Question about KitchenAid 24 in. KUDM01TJ - Multiple Color Built-in Dishwasher
Cancel / drain
Lights no longer work on control pad and now when start is pressed the cancel/drain is activated. any clue?
  • 447 Answers
Re: cancel / drain
Sounds like the membrane switches have failed-- very common for the new computer controlled appliances. I believe it will be sold as a whole new top console available at all appliance parts retailers or
Posted on Oct 15, 2007
0 characters
3 Points
Dishwasher starts on its own (no house is not haunted). Start resume button flashes
have a service technician in as it appears to be a problem in the program board
could be moisture across the circuit board
Feb 06, 2016 | Maytag MDB7749AWQ Builtin Dishwasher
Dishwasher won't run
It is the touchpad that is faulty.. coz if the control board is faulty the unit may not respond to any button at all.. So just get a new touch pad.. If you want to buy it online.. then let me knnow i will get you the link..
Mar 13, 2008 | Kenmore 16372 / 16374 / 16379 Built-in...
Kitchen Aid dishwasher won't start. All keypad buttons/lights appear to be functional.
The touch pads are common to go bad. It could be a bad start switch pad or bad control board.
Oct 05, 2014 | KitchenAid 24 in. KUDS01FLSS Built-In...
Green start button won't stop blinking
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
Nov 29, 2010 | General Electric GLD6966RSS Stainless...
Electrolux dishwasher delays before starting
  1. To cancel the the delay pad again when the delay is counting down. The indicator light will go out and the cycle will start or resume immediately.
  2. To cancel the delay and the cycle, press Start/cancel once to drain and turn-off the dishwasher.
  3. Press Start/cancel twice to turn-off the dishwasher without draining.
Aug 31, 2009 | Electrolux EDW5505ESS Built-in Dishwasher
Touchpad--No Response
The "2H" is an error code indicating the control panel needs to be replaced.
May 08, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Hi: How do I turn off the beeping signal when the cycle is completed on my Bosch dishwasher? It's a fairly new model, with the control on the top of the door. Thanks, Jean Ferrario
I just tried this and it worked.
The Cycle Completion Signal
this Cycle Completion signal is a tone that sounds to alert you when your dishwasher finishes washing and drying your dishes. You can either disable the tone or set the volume.
to activate:
· press and hold the right “Cancel Drain” button then press and hold the on/off button.
· When the light on the “Cancel Drain” button you are pressing illuminates and the tone begins to sound, release both buttons.
· press the right-most “Cancel Drain” button until the tone is either at the desired volume or is silent.
· press the on/off Button. the Cycle Completion signal is now set.
Jan 22, 2009 | Dishwashers
Bosch Dishwasher won't drain, cancel drain lights blink
when you said "I can run a wash", does the machine act normal for that time frame up to the point of drain? if yes, the pump is fine. sounds more like the micro chip on the board is "confused", but not sure why.
Jun 04, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
KitchenAid 24 in. KUDM01TJ - Multiple Color Built-in Dishwasher Logo
123 people viewed this question
Top KitchenAid Dishwashers Experts
Mike Cairns
Mike Cairns
Carmen Mikulic
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
