Question about NEC-Mitsubishi Nec Display Solutions LCD1770V (Black) 17 in. Flat Panel LCD Monitor
NEC LCD1770V model:L174F will power for 3 sec then off
The problem is that there is power but the display will turn off after 3 seconds, is it the display it self or the CPU board or some thing in the power supply. thank you
The projector turns on but won't project any light through the lens.
If this is a NEC VT series projector, Change the lamp. When if it continues to blink amber and not project and image after installing a new lamp check the lamp cover to see if the micro switch tab on the lamp cover broke off. Some models have a built in lens cover. If the cover is not slid over to open completely the light may not turn on.
May 19, 2014 | NEC VT800 LCD Projector
NEC Multisync LCD1770V Model# L174F- Monitor powers on for a few seconds then goes black. You can still see a faint image in the background and the power light is still green. I checked for leaky caps on...
Check the iCs on the lcd control board which shut down the ccfl lamps? If hot put a paper sticker slightly smaller on the IC. This prevents condensation from osmosis into the IC.
Dec 19, 2010 | Televison & Video
Power die
Most common failure in the LCD moniotors are due to bad caps in the power supply section, that will be the first place for you to check. please see my albums so you can make the decision if you will want to DIY repair or not.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Aug 28, 2010 | NEC-Mitsubishi Nec Display Solutions...
Power problem????
Your Secondary Power supply Hot TRansistor is Faulty, Its situated next to the lopt TRansformer to a Heatsink
May 16, 2009 | NEC MultiSync LCD1770V - Flat panel...
Dell model No. 1504FP will turn on for 3 sec then off
THE PROBLEM IS THE MONITOR IT SELF.
IT IS TIME TO BUY A NEW MONITOR. I KNOW ALOT OF OF US CANNOT AFFORD A NEW MONITOR EVERY TIME ONE BRAKES, I HAVE FOUND THAT SECOND HAND STORES SALE THERE MINITORS FROM 1-2 DOLLARS PER INCH, I PICKED UP IBM FLAT SCREEN 20" AROUND 20.00 USD. AND IT STILL RUNNING AND I HAVE HAD IT FOR A YEAR OR MORE NOW.
May 12, 2009 | Dell 1503FP 15" LCD Monitor
Power light steady green but monitor goes dark after 4 secs of video
The video card in the computer could be going bad too or the driver for the video has corrupted. Try reloading the video drivers in the PC first.
Mar 29, 2017 | NEC MultiSync LCD1770V - Flat panel...
NEC LT30 - Lamp dosen't turn on.
From the manual: To reset the lamp hold down the "HELP" button on the remote for 10 sec and the lamp indicator will turn off. Then start up the projector again.
It worked for me!
Mar 17, 2008 | NEC LT30 Multimedia Projector
DiamondPoint V71LCD Not displaying image
The LCD screen may be burned out. There's whats called an invertor board and there is an electronic ribbon strip on the LCD itself. If you look very carefully you can probably see a faint image on the screen. The LCD screen will need replacing. Before doing anything with this monitor, try it on another computer first and if you can try another monitor on your computer. Other than that, there really is nothing you can do but replace the monitor.
Jun 27, 2007 | NEC-Mitsubishi Nec Display Solutions...
NEC-Mitsubishi Nec Display Solutions LCD1770V (Black) 17 in. Flat Panel LCD Monitor Logo
287 people viewed this question
Top NEC-Mitsubishi Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
mukhtar21 shaikh
mukhtar21 shaikh
Gregg Errera
Gregg Errera
Level 1 Expert
Are you a NEC-Mitsubishi Computer and Internet Expert? Answer questions, earn points and help others
