Savin 9935DPE document feeder maintenance
We have a Savin 9935DPE copier. When placing a document in the auto-feeder, it goes just 2'' and stops. The mechanism has one roller, a belt, some springs, and small plastic clips. We're wondering what parts we should replace? Looking at a catalog from Precision Roller, none of the pictures looks like what we need. The roller looks worn and my guess is that an inexpensive roller may be all we need (hopefully). Any comments would be much appreciated.
  • dlapenson May 12, 2009
    Hi, Yes I found the actual site was at savin.com, then clicked "downloads" and "manuals". This looks to have what we need. Will follow up when we find the part(s).
  • 1,602 Answers
GO ONLINE TO SAVIN: TYPE THE FOLLOWING INFORMATION:
WWW.SAVIN.COM/SERVICE_MANAUL
/TECH_SUPPORT
/SERIVES
/HELP?
CALL SAVIN ASK TECHICAL SUPPORT, ASK FOR A TECHICAIN THAT REPAIRS OR FIXS THAT TYPE OF EQUIPMENT AND EXPLAIN THE PROBLEM AND SEE IF HE HAS ANY IDEAS YOU CAN TRY BEFORE YOU GO OUT AND SPEND ANY TYPE OF MONEY ON THAT PART.
ROD
Posted on May 12, 2009
How do I copy from document feeder?
Dear Flaim
pl. do load documents on the adf tray.face upward and the press copy or start. it will do
thanks.
Apr 02, 2015 | HP Officejet 5740 Wireless e-All-in-One...
Savin 9935DPE is printing one thick vertical balck line down the copy or print pages. About 2 of every 3 pages printed. What's wrong?
are you printing from Doc feeder or glas?? if from feeder then try to make a copy from the glass, does it still do it? yes problem is with drum.
No? problem is with the small scanning glass to the left, look carefully see if any spots or lines on the 1inch glas --- clean it
Sep 05, 2012 | Savin 9945dpe 9935dpe 2035dpe 2045dpe...
Savin 2545 document feeder gives a gray band on the copies
Yes - surprisingly - we had the same problem, the gray stripe along the side of the page only showed up when the original was fed through the document feeder on top. Cleaned the small area of glass under the feeder repeatedly with no change to the resulting stripe, but then while cleaning the upper roller, above the area of glass where the scan lamp illuminates during the copying from the ADF, we found a small piece of paper adhering to the top roller in the paper path, cleaned it off, and no more band. We didn't see the bit of paper on the upper roller until we rolled it while cleaning. Still can't figure how that made a stripe....but hope this helps you.
Feb 22, 2010 | Savin 2545DP Black and White Copier
Savin 9935 dpe not working
try to ask your question to the problem section you will have more chance
Nov 13, 2009 | Office Equipment & Supplies
Canon 1023if auto feeder not working. Says check
The document feeder has multiple sensors in it. sometimes they hang up and stay stuck out of place. Other sensors might get paper dust on the face of the sensor. If you can open the document cover, locate the sensors and see if any are ajar or the sensor flag fell out of place. Also look to see if a paper is stuck in any of the paper path areas. Not seeing the machine it is hard to say if it fed paper and says check document, if it did, clean the feed wheels with a wet paper towel.
Oct 15, 2009 | Canon imageRUNNER 1023iF Black and White...
Scanning a legal size document
Move the document feeder front guide towards the rear of input tray, line up with 8 1/2" marking. This should inform the machine to register for 8 1/2 x 11 or 8 1/2 x 14 originals>fed lengthwise.
Jun 01, 2009 | Canon iR 2022i Printer
I have a savin 9935dpe b&W multifunction copier. It states an error code of: "functional problem SC321-00" and to poweroff the machine or call for assistance. I powered off the copier and...
the laser unit can't write, pull out laser unit to clean out (do not open black box ) laser unit located at left down corner of the toner unit. after clean if still not work, change laser unit.
Dec 11, 2008 | Office Equipment & Supplies
HP 7410 streaks when using auto document feeder to make copies
the document feeder of that unit have its own scanner glass. try opening the document feeder and clean the scanner glass with a lint free cloth that is moist with water and also clean the rollers of the document feeder
Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Auto Document Feeder
has the feeder attempted to feed in the document ? Check to see if there is already a document on the copyboard platen
Apr 27, 2007 | Canon PC-980 Color Copier
107 people viewed this question
jasbo
jasbo
