Question about Apple iPod nano
One BIG freaky problem
I have had my original ipod nano since august of last year and recently when i went to charge/update it on my laptop, it was not being recognised by my pc. everytime i connect it to my USB outlet on my laptop, a big red circle with a line through it is displayed along with the message "do no disconnect". it then freezes like this regardless if i disconnect the charger cord, and i usually have to reset the ipod or let the remaining battery run down before i can use it again. this only happens when i connecnt my ipod to my laptop but charges perfectly fine on my PS2 wich also has a USB outlet. (also note that i had a virus on my computer at the time this problem arose but the virus is not present anymore). to try and fix this bizarre problem, i bought a new charge cord, but it did not work. i also downloaded the latest itunes but to no avail. my warranty has run out and i cant afford to purchase a similar ipod at this time. did the virus that corrupted some files on my computer affected itunes and my ipod too? is my ipod stuffed forever? should i get it replaced?  or does it simply need to be fixed by a professional? please help... sinceerly - sarah
  • 21 Answers
Sometimes by pulling out the cord directly from the ipod, will cause permanent damage, because it happened to me. You should always eject the ipod from itunes.
however, you might want to try to get "Apple Update" and install the firmware for the ipod over again. Or, get new driveers for your laptop.
Posted on Oct 17, 2007
We just purchased a 8g nano ipod. Why does it shut itself off after about 1 minute while we are either listening to the radio or the songs that we downloaded? No one seems to know.
Ensure that your iPod is fully charged first. Another reason your ipod could be shutting off is that your headphones are not properly seated. I f music stops playing when the screen goes dim, it is because the nano does not detect the headset. Remove and then firmly re-insert your headphones.
1. Failing that, your first fix would be to set your Nano for a sync, then restore it. This will automatically restore the Nano to its original settings.
2. If this doesn't work, run an update the same way you did for the 1.1 update. If the original update went wrong, this should rectify the situation. Don't end the sync until the onscreen directions tell you.
3. If you are still having problems, it might be good to visit your Apple Store, if you have one nearby. Document the issue clearly, so the tech can determine if it's a software or hardware problem.
Mar 07, 2011 | Apple iPod nano 8 GB Pink (3rd Generation)...
My IPOD NANO 8gb 3rd gen just hung up after charging it normaly.How so I fix that?
Tips:- Charge you Apple ipod with original Charger which comes with Apple ipod box as a accessories.
Solution:- Charge it will original charger & Connect this ipod to iTunes & just restore the ipod or update iPod software to latest version.
Feel free to ask your further queries to us.
After that all it will work fine 100% .
Thanks.
Happy to help you.
Apr 25, 2010 | Apple iPod nano MP3 Player
New Ipod Nano 4th Gen 16GB has went blank and will not turn on
HI there,
worst case scenario is that a circuit has broken inside. But your ipod will be under warrenty for a year from purchase.
Otherwise, leave the ipod to charge for a long time. Just leave it connected directly to the computer USB port despite not having any change in appearance. Also, don't connect it via a usb hub or through your keyboard. You will need to plug it into your computer directly.
You can also try entering DFU mode. Here is a great step by step guide to do that. http://iphonefreakz.com/beginners-guide/howto-dfu-mode/
Then restore the ipod and update the firmware. Make sure you have the latest version of itunes installed. By checking through software update.
I hope this helps,
Nathan.
Apr 14, 2009 | Apple iPod nano 4th Generation
Is there a way to override or reset the password on the iPod Nano
Unfortunately, if the password has been forgotten, you will have to "Restore" the iPod, which will erase all the songs and other files that are currently on there.
To update or restore iPod nano:
1 Make sure you have an Internet connection and have installed the latest version of
iTunes from www.apple.com/ipod/start.
2 Connect iPod nano to your computer.
3 In iTunes, select iPod nano in the Source pane and click the Summary tab.
The Version section tells you whether iPod nano is up to date or needs a newer version
of the software.
4 Click Update to install the latest version of the software.
5 If necessary, click Restore to restore iPod nano to its original settings (this erases all data
from iPod nano). Follow the onscreen instructions to complete the restore process.
Mar 23, 2009 | Apple iPod nano
Ipod nano
Apple iPod is Locked
There is only one way - and it will erase all your songs (applies to most models, not just Nano):
If you lock your iPod nano screen and can’t unlock it
Normally, if you can connect your iPod nano to the computer it is authorized to work with, your iPod nano automatically unlocks. If the computer authorized to work with your iPod nano is unavailable, you can connect iPod nano to another computer and use iPod Updater to restore your iPod software. See the next section for more information.
If you want to change the screen lock combination and you can’t remember the current combination, you must restore the iPod software, and then set a new combination.
Updating and Restoring iPod Software
You can use iPod Updater to update or restore your iPod software. Apple periodically
updates iPod software to improve performance or add features. It is recommended that
you update your iPod nano to use the latest software. You can also restore the software,
which puts iPod nano back in its original state.
- If you choose to update, the software is updated, but your settings and songs are not
affected.
- If you choose to restore, all data is erased from your iPod nano, including songs, files,
contacts, photos, calendar information, and any other data. All iPod nano settings are
restored to their original state.
To update or restore iPod nano with the latest software:
1 Go to www.apple.com/support/ipod and download the latest iPod Update. The update
has the latest software for all models of iPod.
2 Double-click the software installation file and follow the onscreen instructions to install
the iPod update.
3 Connect iPod nano to your computer and open iTunes. The iPod Updater application
opens.
If you’re using a Windows PC and the iPod Updater application doesn’t open
automatically, you can find the updater by choosing Start > All Programs > iPod.
4 Follow the onscreen instructions to update or restore iPod software.
If you use the iPod Updater application and it doesn’t recognize that iPod nano is
connected to your computer, reset iPod nano (see page 45).
If you want to restore iPod software and you don’t have an Internet connection, you
can use the iPod Updater application that was installed on your computer when you
installed the software from the iPod CD.
-Tha Mp3 Doctor
Nov 10, 2008 | Apple iPod nano
Unlocking my ipod nano
There is only one way - and it will erase all your songs:
information.
combination.
â If you choose to update, the software is updated, but your settings and songs are not
affected.
â If you choose to restore, all data is erased from your iPod nano, including songs, files,
the iPod update.
opens.
-Tha Mp3 Doctor
May 28, 2008 | Apple iPod nano
Nano i pod has locked silver ipod nano
i forgot my ipod code
help me
May 26, 2008 | Apple iPod nano
IPod Nano Wont Charge
Do the 5 R's:
These are for Nano, but they apply to all iPods:
Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with your iPod nano. If
one of the following doesn’t help, read on for solutions to specific problems.
â Reset your iPod nano. See “General Suggestions,” below.
â Retry with a different USB port if you cannot see iPod nano in iTunes.
â Restart your computer and make sure you have the latest software updates
installed.
â Reinstall iPod and iTunes software from the latest versions on the web.
â Restore your iPod nano. See “Updating and Restoring iPod Software” on page whatever.
May 23, 2008 | Apple iPod nano
Battery Problem?
It's possible you damaged the battery but not likely. The ipod has a circuit inside it to prevent overcharging (i.e. it stop scharging when the battery is full).
I would try the five R's at apple's website and then try charging it again and see if it fixes the problem.
See the five R's here:
http://docs.info.apple.com/article.html?artnum=303940
Jan 29, 2008 | Apple iPod nano
Ipod nano 1st gen sync/charge problem
Try these options i got them from apple when my ipod dident work trying a new port and reinstalling itunes worked for me 1)Reset your iPod. 2)Retry with a different USB or FireWire port. 3)Restart your computer and make sure you have the latest software updates installed. 4)Remove iTunes software and then reinstall iTunes software from latest versions on the web. last resort 5)Restore your iPod. See ?Updating and Restoring iPod Software? in the user's guide.
Aug 24, 2007 | Apple iPod nano
Apple iPod nano Logo
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
