Question about Maytag 24 in. MDB7601AWS Stainless Steel Built-in Dishwasher
Model mdb7601awb diswasher . Nothing works , no buttons torn on or work when pushed, no action. 1.Have checked power to unit and is ok 2.checked door switches (2) and both work properly. 3. no visual discoloration on circuit board. There is a blue dot on the wiring harness from control board to button panel.When evaluating with magnifing glass I believe this to be blue ink droplet and not any burnning of harness. Need a Guru.
  • rayswifeahle May 13, 2009
    mine, too. no lights ..nothing...i've unplugged checked my fuse box..everything else works from the same outlet...couls it be a fuse unside my kenmore elite?
I have had the board replaced 5 times and the entire dishwasher replaced once. It was necessary to go to the state attorney general to get Maytag to extend the warranty. Just called the service center for the sixth time, after this the warranty will be gone and will replace with something well built.
Posted on Oct 23, 2009
My LCD panel is also on the fritz. Suspect the control board. Spoke to Maytag and there is a recall out on certain serial #s for this model. Mine is out of the range but hopefully yours is covered....worth a try.
https://repair.maytag.com/repair/dish_faq.jsp?siteCd=MT_EN_US
Posted on Nov 16, 2009
  • 3 Answers
Did either of you solve this? I have what sounds like the same problem: Display dead in that no lights light.
Posted on Aug 17, 2009
The Diswashers Maytag Quiet Plus II only works when we push against the door
It sounds like the door switch or sensor needs to be adjusted or replaced.
Nov 22, 2012 | Dishwashers
My Chamberlain Liftmaster Formula 1 garage door (2002) has stopped working. The power is on -- light turns on when I push the wall mount button. But the remotes no longer work. The door does not move. ...
The light by the learn button may be sending a diagnostic code. See if it is flashing a number of times, pausing and then repeating. Count the flashes. Is your door stuck in the open posititon?
Jun 11, 2011 | Sears Craftsman LiftMaster Chamberlain...
GE Profile GSD4010202AA Built in Dishwasher acts as if no power
1. turn breaker off to diswasher. 2. remove bottom access cover. 3. remove cover over electrical connection box on right side. 4. hold each wire nut connector and firmly tug on one wire at at time to make sure none of the wires pull out of the wire connecor nuts. A loose connection here is more common than you might think.
If those are all OK, turn breaker back on and make sure you have power there. (120 volts black to white) If that was OK, then check door latch switch inside door at the top center and wires passing through door at the bottom of the door.
Jul 26, 2010 | GE Dishwashers
I have a Merlin powerlift-model 2500L Garage door and cannot find the Learn Button to program my new remote. Please help...
This is a foreign design but here is what the instructions say to do.
Remove the light cover then remove the colored plastic rectangle strip located underneath. This will reveal a red Learn/Delete? button. 1. Push Learn/Delete button for 2 seconds the lamp will blink continuously to alert you that it is in Learn Mode. 2. Push the big button on your remote for 2 seconds 3.Push the little button on your remote for 2 seconds Minimum of 1 second is required between each action Your remote will now operate with your motor b) Overhead Doors Remove the coloured plastic rectangular strip located next to the Merlin label on the front of the motor. This will reveal a red Learn/Delete button. 1. Push Learn/Delete button for 2 seconds the lamp will blink continuously to alert you that it is in Learn Mode 2. Push the big button on your remote for 2 seconds 3. Push the little button on your remote for 2 seconds *Minimum of 1 second is required between each action Your remote will now operate your unit. Thanks BB
May 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Liftmaster GDO just clicks, no lights no open/close
Pull the logic board and check it for burnt or missing traces on the printed circuit. Thunderstorms love logic boards.
Apr 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
My hp pavillion dv1000 wont turn on it is plugged in but the charging light doesnt show up and when i push the power button nothing happens
Problem with your charger, try this :
1. Check whether the charger plug is properly inserted in the Power port/jack of your Laptop!
2. Check the power cord (any cuts OR torn-out)!
3. If above steps don't work, replace your charger.
Jan 02, 2010 | HP Pavilion dv1000 Notebook
Diswasher stopped working
There is a thermal fuse on the controller that commonly goes out. If you take apart the panel, and see the computer part, there is usually a part clipped on the side with 2 wires on it. When that goes out, it acts like there is no power to the unit. Very easy and in-exspensive to replace if that's it. It's pretty common on those. Good luck
Feb 15, 2009 | Dishwashers
Garage door opened, won't close
If you can press and hold the wall button and the door will go down, you have a photo eye issue. Check the photo eyes at the bottom of the door.
Jan 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Flashing Power Failure Light on Frigidaire Diswasher Model # FD989GFC2
I have a Frigidaire that does the same thing. I was able to push the start cancel button then select a cycle and press the start button, shut the door and presto it worked.
Oct 17, 2008 | Frigidaire 24 in. GLD2162RDC Stainless...
there is a fuse in the washer that needs to be replaced reply to me and will walk you through it
Dec 31, 2007 | KitchenAid 24 in. KUDI01FLSS Stainless...
Open Questions:
Maytag 24 in. MDB7601AWS Stainless Steel Built-in Dishwasher Logo
879 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
