Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
E5 error - need to know where drain hoses are
Working with a Hobart LXi Dishwasher - have an E5 error - drain error. Is there a picture showing where the drain hoses are?
  • Leslie Looman
    Leslie Looman May 11, 2010
    What specific model number please....thank you
  • Dan Todd May 11, 2010
    Is there any water on the floor or in the cabinet where the drain hose is connected to the waste pipe?
    You should be able to go to your manufacturer's site and look for their download section to obtain an operator or service manual for your model number.
    This will probably download in a pdf format so you will need Acrobat Reader (free) and the latest version is 9.
Tried to take off the drain hose, but could not get it off the back, only by the disposal. I turned if off and on about 6 times and ran the delime cycle with lots of limeaway. It got the E5 error on the delime cycle, but it worked the next time I tried to run it.
The manual does say to turn it off and on as it drains out the water. Takes a while as it has to heat up the water each time.
Posted on May 20, 2009
What does the error code ER5 for a EDW154E Eurotech D/W mean?
e5 error is drain error. need to check all drain related items.
drain pump, drain hose, and of course garbage disposal knock out.
Jun 06, 2014 | EuroTech 24 in. EDW154E Built-in...
Samsung error E5
I don't know about a E5 error; are you sure it's not a 5E error? That means a drain error or "water not draining" error. Check the drain pump and drain hose for an obstruction. If that's okay, and the dishwasher drains water, then you probably have a bad ECS sensor.
Mar 30, 2014 | Samsung DMR77LHS Tall Tub Dishwasher
Dishwasher is not working, FP DW60CSW1, three of five lights blinking
It is possible you have this error
First 3
programme
indicators
flashing
E5 Water tap not turned on.
Insufficient water supply pressure.
Water supply hose is crimped or
bent.
Drain hose is too low.
Ensure the water is connected
and turned on.
Check household water pressure.
Check hose and straighten if
needed.
Ensure that drain hose is
connected in accordance with the
'Installation instructions'.
For details refer user guide.
Apr 08, 2013 | Fisher and Paykel Dishwashers
I have a PD code on a Hobart LXI dishwasher. What does that mean
PD is not an error code. It shows that when it draining water out shortly after power-up and when shutting down. If it seems to be showing "PD" longer than usual, it means the dishwasher's control circuitry believes there is still water in the tank, due to a faulty water level probe, most like the one under the lift-out screen. It has a plastic body with a metal probe coming out the center.
There is also a dual probe at the rear of the machine, but I believe the dishwasher uses the front probe to determine when to stop draining the machine during "PD" - most likely meaning "Power Drain" or "Power Draining".
If you are not seeing any E- codes (E1, E2, E3, etc.) then these water level probes are likely just fine and the "PD" is appearing normally, as it should during draining conditions.
Feb 08, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
The machine has an E5 error code , it will drain itself and then needs to shut down and turned bavk on to get it working again
e5means water did notdrain below top water probe, there are 2 probes in theright corner of the mach. make sure they are clean you can use a copper tubing cleaning brush to clean probesmake sure to clean the back of them, then try 3 cycles, if after 3cyc. the e5 doesnt come back you have fixed your d/w dont forget to vote
Oct 23, 2009 | Hobart LXIC-6 Dishwasher
E5 everytime we run the wash
Try running the drain hose into a bucket next to the machine. If it drains Ok, look for the restriction in your plumbing. If it won't drain into the bucket, look for a closed drain valve, open fill valve, bad middle or top probe, check power at drain connector ( it's DC volts from the bridge rectifier in the top drawer on the relay board.. Basically, water is at top probe at beginning of rinse, or it didn't drain down after the wash. Drain hoses can kink from hot water if not routed well.
Jul 17, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
E-5 error code and no draining or rinse cycle machine less than 3 months old
E5 is a drain error - machine is not draining - check drain hoses - pull out machine if needed - check air gap. hope this helps. jimmy.
Sep 26, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Rinse cycle has no water
check the sump probe under the screen and the 2 probes in the right back corner.clean them with a light grit sandpaper.let me know.
Mar 28, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
3,226 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
