Linksys EZXS88W pass-through port problem
Have a fully used Linksys EZXS88W router. Attempting to access three (3) workstations on this router (each running Windows XP Pro) so these workstations can be controlled using XPs remote desktop feature. How can I open three ports in the router and assign them specifically to each of the workstations to avoid port congestion problems ???
  • 413 Answers
Type 192.168.1.1 on your browser's address bar. You will see a login dialog box .
Type your username & password and login to device.
A web page will appear , you can go to security section & select virtual servers.
From virtual servers section you can create port you want either TCP or UDP.
Thanks and Regards
Posted on May 12, 2009
My Linksys WRT310N Wireless Router was already configured to be an access point (in Access mode). I have three cables that were plugged into the back. Can you advise me on this.
to ensure faultless performance, when I've connected an AT&T 3G microcell I've found it's best to take the cat5 from the modem, into the microcell and then into the router. you use the yellow port on the router as input
Dec 07, 2016 | Linksys Computers & Internet
Port Forwarding On Linksys RV016
it's a rather lenghty explanation so please go to this site and follow the instructions...
http://portforward.com/english/routers/port_forwarding/Linksys/WRT54G/
Robert
Please rate this solution ... thanks
Sep 08, 2008 | Linksys RV016 Router
I have an Internet Connectivity problem which I believe was caused by resetting our D-Link WBR-2310 router. We have a strange, perhaps illogical network setup in our office. Although it was set up before...
It appears you are not using the wireless connections on both the routers and the reason for using Router B was that there were insufficient LAN ports on Router A to connect to the two workstations that are connected to Router B.
To simplify your network, I suggest you replace Router B with a network hub or ethernet switch and connect the two workstations to this network hub/switch, then configure these two workstation to Obtain an IP address automatically. Router A will then issue IP address to these workstations via the network hub/switch.
Jul 09, 2011 | Computers & Internet
How do the cables connect? Which cable goes where?
Step 1:
Connect the broadband modem to the router's WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we'll connect the computer to port number 3.
NOTE: It is advisable to connect the computer to one of the Ethernet (1, 2, 3 or 4) ports when setting up the router for the first time. If you have successfully configured the router using a wireless computer, unplug the Ethernet cable which connects the computer to the router for you to have wireless Internet connection. For instructions on how to connect the wireless computer to go online using the Linksys router, click here.
Step 3:
Make sure the power adapter is plugged in to an available power outlet.
3678-005.png Step 4:
Check if the corresponding LEDs on the router are lit. For instructions, click here.
Related Articles:
Accessing the Router's Web-Based Setup Page
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 12, 2010 | Linksys Wireless-G WRT54G Router
Ps 3 linksys 160n problem
Hi Friend,
In order to use PS3 we need to open few ports. Kindly follow the steps:
1.Open the internet explorer and type 192.168.1.1 and hit enter.
2. If you have not changed the default password of the router then kindly leave blank the username box and in the password box type admin and hot enter.
3.In the setup page click Application and Gaming
4. Under that click Port Range Forwarding.
Below are the port numbers which we need to open for PS3
TCP:
80
443
5223
UDP:
3478
3479
3658
Now please type these port number in start and end port. Please make sure start and end port has to be the same.
First enter the TCP ports in first three boxes and then UDP ports in next three boxes.
Save the settings and turn off the router for 10 seconds and restart again.
Enjoy.
Regards
Chiranjeet
Mar 15, 2010 | Linksys WRT160N Wireless Router
Connecting PSP to wifi
Change the primary DNS of your PSP to 4.2.2.1 and secondary dns to 4.2.2.2
Apr 25, 2009 | Linksys WRH54G Wireless Router
Trouble creating wireless access point from D-Link DI-514 router
You should be able to plug the D-Link into any of the Linksys wired ports (not the Uplink port) and tell the D-Link to get an IP address from the Linksys router (as long as the Linksys router has DHCP turned on). Verify that both boxes are on the same network (192.168...) and don't have the same IP address. What happens when you do this? Can you get to the Linksys & D-Link from a wired workstation?
Dec 11, 2008 | IBM ThinkPad R31 2656 Notebook
Changed from DSL to cable
Usually DSL connections require ppoe while cable uses dchp You need to log into your router and change the settings
Dec 29, 2007 | Linksys EtherFast EZXS88W (DSLSEZXS88W)...
Linksys Routers and Microsoft PPTP
Microsoft uses IP Protocol 47 [GRE] for this secure tunnel. Provided that the PPTP Pass Through is set to Enable on the Router's Filters page and port 1723 is forwarded to the VPN Server, the Router will allow authentication and remote access into your network. The router will also allow you access remote PPtP networks from behind the router providing the PPtP Passthrough is enabled on the router.
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
BEFSX41 and Microsoft PPTP
Feb 16, 2006 | Linksys BEFSX41 Router (DHBEFSX41)
Computers & Internet Logo
494 people viewed this question
David Payne
David Payne
