Question about Zenith D52WLCD 52" Rear Projection HDTV-Ready Television
Green screen TV comes on with a green screen and lam indicator light is on. Also the screen says "replace lamp" at the bottom. I replaced the lamp last night and it works. Screen is still green. How do I fix it.
  • Anonymous Apr 30, 2008
    I get a green rainbow that comes up from the all across the screen and halfway up
    An expert whose answer gotĀ voted for 100 times.
  • 208 Answers
I have never seen this tv have a problem that turns the picture all green. What is signal source, (cable or satelite) and are you using component cables? Make sure your cables are good and that they are plugged in properly on both ends as a defec or loose component cable or a bad cable or satelit receiver can cause this problem.
Posted on Feb 10, 2008
Sony Wega 60" TV lamp light
Nope. It appears that you now have a main power supply issue since the set is dead.
Jun 23, 2017 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Bravia KDS-55A3000 while watching last night screen went black as if someone turned the TV off when attempting to turn it back on the the power indicator light flashes green repeatedly stops then a...
It sounds like the lamp has failed. It is advisable to use a genuine Sony lamp. The part number for is XL-5200. It will cost around 180.00. That should fix you problem. If you cannot find the lamp local to you can order it form Sony at.
I hope this help,
Dec 15, 2010 | Sony KDS-55A3000 55" HDTV
WD57732 purchased 12/06 and has worked fine. Turned off at 11 pm last night. No indication of trouble. Tried to turn on this morning and nothing. Did TV Reset, green light flashed for a minute like it...
Now,tv on?.Tv "LAMP" LED light indication flashes or stay on?How long the Lamp been inside this tv,been inside like 1 1/2 or 2 years and tv been on each day like 4 or 5 hours a day in used.The lamp life are over.Should replace another lamp.
Dec 10, 2010 | Mitsubishi WD-57732 Projection Television
When you turn it on, the green LAMP light goes on, then it clicks and the STANDBY/TEMP red light goes on, then clicks and back to the green LAMP light. It does this a few times, then The TIMER green light...
Usually if all 3 indicator lights come on this could be the color wheel is not functioning or the DINe chip needs to be re-soldered. Be sure the lamp door is closed all the way, but the color wheel needs to be looked at first.
Nov 17, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
My Konka KLC-1508U was working fine, last week, I would lose picture but still had sound, I would re-power & would be fine again. But as of last night, I get power only (green light) but no picture or...
hello!the problem is not on the power cord it is on the backlight of your tv (a cold cathode lamp)this needs to be replace you can reach the cathode lamp by disassembling the screen/monitor of your tv the lamp is place at the top and bottom of the screen be very careful when doing this.replacement is available online at
sometimes the problem is on the inverterboard the inverterboard is the one supplying a current to the lamp the input voltage of the inverterboard is 24v so you have to check the input voltage from the power supply to the inverter board.a poor solder from the terminal post of the power supply to the inverterboard will also cause the resolder them.reminder..always unplug the tv before working on it..goodluck!A four thumbs up is much appreciated for answering your free question..
Sep 06, 2010 | Konka DLC-3211UT 32 in. LCD Television
The screen went black. Last time I changed the bulb and it started working. This time the TV did not come back. The screen is black. The center Green light and the bottom red light blink. Samsung 567W
Make sure properly connected and tightly sure cover put on and screws in,if change projection bulb,still blinking "LAMP" LED indication light.But,if "LAMP"LED indication flashes and making clicking noise.Ur Ballast board also dead.Require replacement,this Ballast board help to ignite the projection bulb.
Jul 30, 2010 | Samsung HLN567W 56" Rear Projection HDTV
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Zenith D52WLCD 52" Rear Projection HDTV-Ready Television Logo
89 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
