Question about Zebra LP 2844 Thermal Printer
Printer doesn't work when use usb parallel converter.
When I use the Serial cable,select the port com1.It works,but it takes about 3 minute to print one label. So I buy the usb parallel converter.Then it doesn't work at all."the document failed to print" I change the port,usb001,usb002,LPT 1... restart computer,restart printer.It still doesn't work.
Does anyone know what is the reason? The parallel converter is good. Thanks a lot!
  • THUY
    THUY Dec 27, 2013
    Did you find the solution other than forget about parallel converter? I need to use that port. I have been searching in the internet for the last few days to find the solution but I could not find anything help.
    Scholar:
  • 62 Answers
Forget about using parallel converter. Just use the USB cable it works best anyway.
Easiest way is this.
1: Turn printer on. (Green light. ready to print)
2: DISCONNECT the usb cable from the PC.
3 DELETE the Zebra LP2844 & Zdesigner drivers from the printers & Faxes folder. Just highlight them and hit the delet key. Don't worry Iknow what I'm doing.
4: Plug in your USB cable back into PC.
Just sit back and wait, your PC will automatically detect your printer and re-load your driver software.
Send me the cheque now!!
Posted on Dec 04, 2009
  • Jim H Dec 06, 2009
    reply
I have an old serial printer that works fine, I can not connect it to my new computer via a parallel to usb cable convertor on windows 7!
Hi craig931, First try downloading the latest driver of your printer and your usb converter compatible for windows 7. Second Checked your device manager if your printer and usb to parallel driver properly installed, it should be there. If not yet installed try using different usb port one at a time until the cable have been detected. Third if you see already the printer port force to change it to USB001 or Com1, then try to print. regards,
Sep 26, 2011 | Office Equipment & Supplies
I have the same printer, and xp on my pc, but how do i connect them? my laptop does not have a serial conection. i tried to use a usb/serial converter and i installed the xp driver from minolta website,...
You need to make sure you have selected the correct COM port whin you try to print. Depending on the type of USB to serial converter, the COM port it assigns can change just by moving it to another USB port. Right-click on My Computer and select MANAGE. Select Device Manager from the list. Click on the (+) next to PORTS and double-click on your USB-SERIAL device COM port. Somewhere in the Properties window you should be able to see the assigned COM port (COM1, COM2, etc.). If possible, set the COM port to COM1 or COM2 for greatest compatibility with older software. Then when you print, make sure your printer driver is also set to the same COM port.
Mar 05, 2011 | Office Equipment & Supplies
Recommended printer port for v305w in vista
If you connecting it through USB cable try COM1, COM2 and COM3...If you connecting it through Serial/Parallel cable use LPT ports.
For more help stay connected with us.
Thank you.
Good Luck
Aug 17, 2010 | Dell V305w All-In-One R840635AU InkJet...
I have a cash management system Royal alpha
I find that a lot of serial to usb or parallel to usb converters do not work due to the fact you can't get bidirectional communication. In every case I have dealt with, the resolution was a dedicated port card to physically install a parallel or serial port in the system.
Dec 07, 2009 | Computers & Internet
Zebra TLC2844 wont print at all
Try to make the self-test first:
Power OFF
Press "FEED" and keep it pressed and turn the power ON again.
Did it print?! if Yes... There must be a cable problem or port.
Is it USB? Serial? Parallel ?
Let's say it's Parallel, go to the command line and type:
"dir >lpt1"
without the quotes and assuming it's connected to 1st parallel port
did it print?!
on serial would be "dir >com1"
or, if it shows up in "Printers", pre-define it and just type: "dir >prn"
Still doesn't work!?
Try with a different cable, or other computer.
You can use it even without installing the drivers...
Sep 14, 2009 | Zebra Eltron TLP 2844 Thermal Label...
Setting up two printers on the same pc
You need to manually setup the serial printer, as it probably isn't getting detected via plug n play:
  • Go to Start Menu\Printers & Faxes
  • Click on the 'File' menu and choose 'Add Printer'
  • Click next at the wizard, then select 'Local printer attached to this computer' and leave the 'Detect Plug n Play...' box unchecked, click 'Next'
  • Choose the correct serial port (either COM1, COM2, etc), click 'Next'.
  • Choose the correct printer manufacturer & model to install the correct driver, click 'Next'.
  • Print a test page, just to make sure it's working
Aug 04, 2009 | Epson POS TMT88IV Thermal Receipt Printer
How to get Panasonic KX-P2123 printer to work with USB port
Cables are available from a number of sources which will convert from a USB plug for your computer to a serial or parallel connector for your printer. (I don't remember for sure whether that Panasonic is serial or parallel. I think it's a parallel printer and uses a Centronics connector.) Do a search for "centronics to USB" or "serial to USB" and you will find links to a number of sources.
Mar 25, 2009 | Panasonic Computers & Internet
Zebra Z4MPlus doesnt communicate with PC
Ok,
This machine has a parallel port. Try to print via parallel cable. If it works, consider staying with it. Serial ports are a pain to manage.
If you absolutely have to do it via rs232 though....
Question 1. Has it ever printed?
If yes, Go into Windows Printers and Faxes control and select the Zebra or whatever printer that you are using. Right click on it and you should get a menu that at the bottom say "Properties", select that, then you should get a new window with tabs at the top. You want the tab for "Ports". Select it and you will see all of the different output ports that you can direct your printing. RS232 is a COM port. So start at COM1, check it and try to print. If that doesn't work, go to COM2, etc.
Last resort, If you can't get control via the printer driver program, you will have to try redirecting the print manually (now you will understand why I said to stay with parallel output).
What you have to do is redirect your printing via the dos "mode" command.
Under "Start Menu" goto "Run" and put in "CMD" and click "OK".
This opens a black square window with a cursor blinking. Type in this:
mode com1:9600,n,8,1 (enter)
mode lpt2=com1 (enter)
Tell your program to use LPT2 if you can and see if it works.
By now a parallel cable instead of RS232 should be looking really good.
Mar 12, 2008 | Zebra Z4Mplus Label Printer
There is a serial port besides the parallel. how can i make it work with serial cable?
if the printer is built with a usb port, the it should work, is there another USB device in the PC that is working ?
Jun 02, 2007 | OKI OL 400e Led Printer
Zebra LP 2844 Thermal Printer Logo
1,252 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
