Question about GE GSS20IEP Side by Side Refrigerator
Always running compressor is always running. Unit stays cold, but I'm concerned about the efficiency. Is there a way to clean the coils. I have hairy dogs and I wondered if the cooling unit is clogged?
  • 58 Answers
Depending on the model of ref that you have, coils are accessible front bottom by removing the kick plate, (either screws or clips into place) or its available by removing the bottom plate (metal or cardboard) located on the bottom of the back of the outside of the unit. If the coils are really dirty, clean them and this should resolve the problem, if they are clean, check for excessive frost build up in the freezer section on the back panel indicative of a possible defrost problem, or broken door seal. If defrost problem is present, check defrost thermostat for continuity, if open replace, check heater for same, if open replace. Check defrost timer for proper operation, if faulty, replace as needed. Testing procedures will vary with model. Consult your schematic for proper testing procedures, or call a service tech if you don't feel comfortable with do-it-yourself repair. If the door seal is bad, replace as needed.
Posted on Jun 25, 2009
My ac window unit. Can I make it colder.
U do not have control over the temperature of the air; you can control how long the compressor operates with the thermostat. A longer running time equates to a cooler room.
Clean condenser out to maximize efficiency and cooling.
Jul 29, 2017 | LG Heating & Cooling
Freezer won't stay cold
What is the model number of your unit?
Feb 10, 2013 | Gladiator Chillerator Top Freezer...
Freezer runs continuously. It never shuts off. Freezer is cold and items stay frozen, but it is always running.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 16, 2011 | Refrigerators
K68625FJBL01 KitchenAid Sidebyside Refrigerator Freezer compartment was not cold yesterday so I cleaned the dog hair off the coils and the freezer is still warm and fridge side is not cold enough now. ...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Jan 29, 2011 | KitchenAid (KSRD22FKST) Side by Side...
Hello I have a frigidare refrigerator Model #GLRS64ZEB7 that doesn't get cold. I cleaned the condensing coiled. I tried it and it still didn't work??? The compressor is running the suction line is getting...
Unit is low on freon......
heatman101
Dec 14, 2010 | Frigidaire FFHS2311L Side by Side...
ZFSB26DRESS water runs warm and freezer not staying cold.
It sounds like the condenser coils , the coils by the compressor , need cleaned badly . This (and the compressor cooling fan) , can cause the compressor to cut off on overload (due to the heat) , thereby not circulation refrigerant thru out the freezer coils .
The water line goes from inside the freezer door ( cold ) , under the refrig ( warm ) , then to the inside refrig water reservoir ( cold ) . After that , you should get cold water , until the reservoir is drained of cold water .
Nov 19, 2009 | GE Monogram Side by Side Refrigerator
Both the refrigerator (upper)and freezer (bottom) dont stay as cold as they used to. Feezer doesnt maintain freezing temps
When the refrigerator cools but isn't as cool as it should be, I would suspect that the refrigerant coils underneath the unit are dirty.
A fan in the rear of the compartment underneath the refrigerator draws room air across these coils and removes heat from them. If the coils are dirty, the heat transfer is not efficient. This results in the coils remaining hotter than they should. This cuts down on the efficiency of the refrigerator.
Also check to make sure this fan runs whenever the compressor runs.
Oct 20, 2009 | Refrigerators
Central air running all day and not cooling very well
Condensation by the compressor is okay, but if you see it icing up thats reason for concern. The indoor coils can freeze up if there is not enough air flow. Make sure most if not all the registers are open. Take tempature readings at the return and at a supply vent. There should be a 20-28 degree difference. If the difference is only in the teens you have a functional problem. Be sure to shade direct sunlight. And if it gets below 65 degrees at night be aware that if the A\C runs through the night it may block up with ice in the evaporative area. If outside temp reaches 100 degrees unit will run all day. Good luck
Jul 13, 2009 | Heating & Cooling
A/c not blowing cool air
hello. I can help you. There are several possible reasons for your problem Here they are. Read them over and it will give you insights into how your A/C works.
Is the thermostat knob turned to the proper setting? Is the compressor motor running? The compressor is a football-sized case with no apparent moving parts. It is located inside the air conditioner at the center. Is it humming or making any kind of continuous noise or causing the lights to dim? If it is making a continuous noise, and your air conditioner is still not cooling at all, there may be a serious problem with one or more of these areas:
  • Compressor
  • Condenser
  • Evaporator
These items are not user serviceable. You will need to contact a qualified appliance repair technician to repair these components.
If the compressor is not running but you do have power to the air conditioner there may be a problem in one or more of these areas:
  • Compressor
  • Overload and/or relay
  • Thermostat (Open thermostat)
  • Burnt wiring
  • Bad selector switch
  • Capacitor
The air is cool but doesn't seem cold enough If the air doesn't seem cool enough it is necessary to use a thermometer to check the difference in temperature between the air going into the unit and the air being blown into the room. Ideally, the temperature difference should be more than 15 degrees. For example, if the temperature going into the air conditioner is 80 degrees, the temperature coming out of the unit should be at least 65 degrees or less. If the difference is 15 degrees or more there is probably no cause for concern. If the temperature difference is less than 15 degrees you should check the following:
  • Air damper
Check to make sure the air damper is closed. If it's open, it will bring in outside air and reduce the efficiency of the unit.
  • Back cover
During the winter season many people cover their air conditioners to protect the unit from the weather. In the spring or summer they will sometimes forget to remove the cover. If your unit has a cover on the outside portion of the air conditioner remove the cover first.
  • Condensing coils
The condensing coils will always be on the "warm" side of the air conditioner. That is, on the side that faces outside of the room to be cooled. Air is drawn into the back of the air conditioner on the sides through vent slots and is blown directly out through the condenser coils. If the coils get clogged with lint, dust and dirt the cooling system cannot provide the cooling necessary. To clean the coils it will be necessary to remove the entire cover of the air conditioner or pull it out of the wall to gain access to the coils. They can be cleaned by blowing compressed air at them or by using a soft bristle brush to wipe the dirt off. It is important to also clean any dirt or lint build-up in the bottom of the air conditioner so the condensate water will be picked up by the condensing fan slinger properly.
Jul 05, 2009 | LG Goldstar GWHD5000 wall/window Air...
When i turn my a/c on it makes a *tink* noise but the fan still works ((its not cold))
The fan runs but there's no cold air? Is the air conditioner completely dead? See section 1. Is the thermostat knob turned to the proper setting? Is the compressor motor running? The compressor is a football-sized case with no apparent moving parts. It is located inside the air conditioner at the center. Is it humming or making any kind of continuous noise or causing the lights to dim? If it is making a continuous noise, and your air conditioner is still not cooling at all, there may be a serious problem with one or more of these areas:
  • Compressor
  • Condenser
  • Evaporator
  • Compressor
  • Burnt wiring
  • Capacitor
  • Air damper
  • Back cover
  • Condensing coils
if this helps please vote me a fix ya
Jul 18, 2008 | Heating & Cooling
GE GSS20IEP Side by Side Refrigerator Logo
103 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
