Question about SanDisk Sansa m200 SDMX3-512 MP3 Player
Will not take a charge. took two charges prior but has now stopped
My sansa stopped taking a charge. I have only had it long enough to take 2 charges and it has now stopped.
  • Anonymous May 24, 2009
    my sansa is crazy
    Scholar:
  • 161 Answers
I found this online at www.sandisk.com under warranty and manuals link.
I believe they have an excellent Return Authorization system, that if you truly have trouble with your disk player and it's still under warranty, gather your receipts and get on line to get an RMA. I have successfully returned to disc players that were infact faulty (FAT problems) and received two replacement players. Get on it right away. Look at the manaul online too. IT can be very helpful. I've included the Battery info, and the link for the manual at the end.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
Posted on Aug 26, 2009
  • Ladybug Aug 26, 2009
    Battery
    The Sansa
    Charging
    computer.
    Clip player.
    Sansa
    adapters.
    http://www.sandisk.com/media/175960/clip...
SOURCE: Sansa E250 Battery Low always when charged fully
Open the battery cover, remove and replace battery, fold a piece of paper the size of the battery a few times over, place on battery and replace cover. paper presses battery into place! Now charge it.
Posted on Jan 31, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: my sansa mp3 player won't charge or connect
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Dec 28, 2008
mikaleda
  • 14 Answers
SOURCE: my sansa fuze wont turn on
i had the same problem try resetting it by slideing the power switch to the on position and hold it there for 10 to 30 seconds until it turns on then let go. that should sove you'r problem
Posted on Mar 24, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: Sansa Clip 1G stops charging after a few minutes..
Make sure the hold/lock is not engaged first.
-Tha Mp3 Doctor
Posted on Mar 26, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: sansa clip is completely dead
Make sure the hold/lock was not accidentally engaged - see manual for a visual on this.
If not:
-Tha Mp3 Doctor
Posted on Mar 27, 2009
I have a sansa connect 4g it does not want to charge it was charging (blinking blue light on power button) and then it took 2 hours until it breifley turned on and shut off. is the battery dead-if so can...
The battery could be dead and can be replaced if you have another player as batteries aren't sold separately. But first try the Sansa Recovery tool found on the following website and let me know how that goes. http://www.sansacommunity.com/article/11050/Sansa-Connect-Recovery-Tool-Procedures/
Benjamin
Nov 05, 2010 | SanDisk Sansa Connect MP3 Player
HI, MY NAME IS ANGELA. I PURCHSED A SANSA MODEL
The Sansa charges via the USB cable. Fully charged, it should be good for 12-15 hours of playing. Be aware that not all computer USB ports put out enough current to charge external devices. If your computer doesn't charge the Sansa, try a different computer. You can also charge the Sansa using other USB charges, such as you'll see for charging cell phones from a wall outlet or a car cigarette lighter.
Jul 23, 2010 | SanDisk Sansa e250 MP3 Player
Sansa e250 wont charge when plugged into the computer.
Sounds like the internal battery needs to be replaced.
Hope this helps. Good Luck!
Aug 07, 2009 | SanDisk Sansa e250 MP3 Player
Sansa clip pc charging problem
I'm not sure exactly what the problem is but it sounds like it could be faulty or old battery, they can sometimes stop taking a charge. Are you sure it needs to be charged? some devices detect if they need to be charged and dont allow it to be charged if it is already full.
Jul 23, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip wont power up unless hooked up to usb
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Charging
computer.
Clip player.
Sansa
adapters.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
How do I charge my sansa?
all you do is put the usb in the mp3 and the computer and then the battery will just start to charge it takes about one or two hours
Nov 14, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa 250 2 gb
your USB might not be getting charge to it. might be, but see.
May 22, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Charging sansa c200
u're not doing nothing wrong, but you should take it to where it was bougth 'cause it can result in something worst than just the batterie
Nov 25, 2007 | SanDisk Sansa c200 MP3 Player
SanDisk Sansa m200 SDMX3-512 MP3 Player Logo
114 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
