Question about Garden
Needed ignition switch so i changed it and now i've got absolutely nothing wont even try to start it's acting like it doesnt have a battery connected
  • 1,000 Answers
What brand of tractor do you have and what was wrong with the old switch.
Also, a model number and engine would be helpful.
Let me know.
Regards,
Posted on May 12, 2009
Wont start!! HELP!!!
Check your fuses. Likely burned one up for your ignition.
May 24, 2014 | 2000 GMC Jimmy
97 chevy s10 wont start
Then the problem is likely the ignition switch, or the neutral safety switch. Try jamming it into park a couple of times to see if it helps. If it does, you will need to change the neutral safety. If it doesnt, probably going to need an ignition switch. Those trucks, jimmys, and blazers are famous for ignition switch problems.
Feb 06, 2012 | Cars & Trucks
2002 volkswagen Jetta wont start or crank, when you turn the key the cars does absolutely nothing. No lights come on or anything. Then it will start if you leave it sitting for a while sometimes, but when...
It's possible you could have an intermittent problem with ignition switch. If the battery and alternator were tested and came back fine there has to be a bad connection somewhere.
Sep 03, 2011 | Volkswagen Jetta Cars & Trucks
When turning the ignition switch on my LT 1000 craftsman tractor, it doesnt do anything. I have replaced the battery fuse and the ignition switch and nothing happens. The lights doesnt come on either. It...
You may either need a seat switch,pto switch or a park break switch.If the tracter is in nuetral with the park break set,it should start with out anyone on the seat,eliminating the seat switch.If you on the seat and the park brake is pushed and it wont start make sure the pto is off,if it is and nothing happens,then it's likely the parkbrake switch.Also check the connections on the battery,starter and engine block[ground].Let me know how you make out.
Mar 17, 2011 | Craftsman Garden
Car wont start..turning the ignition and it wont make any noise at all, absolutely nothing. not even a click. power comes on though. any ideas?
Extremely low voltage from battery. If you are under 9 or 10 volts you can power anything in the car but it isn't enough to engage the starter. Before you buy a battery try cleaning the connection sometimes thats all it takes.
Mar 08, 2011 | 1994 Chrysler LHS
Hyundai Tiburon Won't Start
Possibly the alarm cut-off switch? or Ignition key switch (or wires) going bad?
But you mentioned you tried to jump start it and it did turn over?
IF so, you could have severe corrosion or loose connections of the battery cable both at the battery and at the termination points, such as ground and starter motor.
Check that the battery wires are tight and clean at the battery posts and at the other end.
Again the No lights suggests either the alarm cut-off, or an absolute disconnected battery cable.
Finally, it could be ignition fuse, Check fuses. Ignition key switch.
What makes this hard is that you suggest it would turn over with another battery connected. This makes no sense.
Good luck
Mar 16, 2009 | Hyundai Motor 2000 Tiburon
Starter wont engage
The problem is either the starter solinoid (located on fender near battery) or you are not getting power to the "s" terminal on the starter solinoid from the ignition switch. If you follow the positive battery cable from the battery you'll follow it to the solinoid. Remove the small wire from the terminal marked "s" on the solinoid and using a screwdriver jump from "s" terminal (not the wire) to where positive battery cable connects to solinoid. (with battery connected). If starter doesn't do anything the solinoid is bad. If starter cranks then you are not getting voltage from ignition switch through "s" terminal wire.
Feb 19, 2009 | 1997 Ford F150 Regular Cab
Won't start - Starter or ignition or what?
It could be the ignition going out. To test the ignition you would have to get a volt meter and find the hot wire to the ignition. When nothing happens when you turn the key, test the hot wire going out of the ignition that eventually goes to the starter. Your ignition is just like a light switch, just a little more complex. You will have to find the wire that connects the switch to the starter to see if the switch is working properly. If when you try to start the car see how many volts you are getting. It should be at 0 until you try to start the car. then it should jump up to either 12 or 24 volts depending on what your start used to start the vehicle. A lose wire from the battery can cause these same problems however. I would start with that and make sure you have good clean battery posts and connections. Then check to make sure they are tight. Then get into the ignition switch checks.
Nov 11, 2008 | 1996 Buick Park Avenue
Wont start
make sure transmission is in park.
slide a stick or twig up underneath the steering column which will hold a specialized switch in place. Try the ignition. Should it start, the actual problem in the transmission interlock switch for the transmission [located in the center console] which also protects the ignition from turning on [secondary switch prior to the ignition switch]. What a ***** to have found... took me 8 hours but GM wanted 800$ for the fix.
Oct 11, 2008 | 2003 Pontiac Grand Am
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
