Question about Garmin n?vi 265WT Car GPS Receiver
When I connect my 265wt to the computer, it just keeps loading the maps and the computer won't reconize the nuvi.
  • 2,335 Answers
I can help you reset and fix your Garmin Nuvi 265WT.
Erratic behavior is an indication that the firmware / system software inside your GPS has been corrupted.
It is not necessary for your computer to be able to 'see' your Nuvi in order for the firmware update to work. When it is successfully updated, the Nuvi will communicate properly to the computer, and your pc wil;l 'see' it, and you can load your maps.
There are three steps to take to get your Nuvi 265WT running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 265WT Manuals here.
Posted on Apr 19, 2010
My garmin nuvi won't turn on? i've tried to plug it into charger but nothing happens
It is not necessary for your computer to be able to 'see' your Nuvi in order for the firmware update to work. When it is successfully updated, the Nuvi will communicate properly to the computer, and your pc will 'see' it, and you can load your maps.
I hope that helps.
Nuvi 265WT Change Home Phone Number
Nuvi 265WT Delete Phone Numbers
Apr 10, 2010 | Garmin nuvi 265 Car GPS Receiver
Tip
Garmin Nuvi 265WT Webupdate Models: Garmin Nuvi 200, 200W, 250, 250W, 260,...
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 265WT, 275
Does your Garmin Nuvi 265WT GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
Backup & Restore Nuvi 265WT Favorites here.
Download Nuvi 265WT Manuals here.
Garmin Nuvi 265WT Hard Reset here.
on Apr 19, 2010 | Garmin n?vi 265WT Car GPS Receiver
Tip
Garmin Nuvi 265WT Hard Reset Models: Garmin Nuvi 200, 200W, 250, 250W, 260,...
Does your Garmin Nuvi 265WT Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 265WT GPS unit.
I hope that helps.
Download Garmin Nuvi 265WT WebUpdater here.
Garmin will not come on
Not starting, getting stuck on the flashing Garmin logo, or a message about not finding any maps, are indications that the firmware / system software inside your GPS has been corrupted.
I hope that helps.
Feb 21, 2010 | Garmin nuvi 265WT Car GPS Receiver
My Garmin 265wt will not turn on for navigation when connected to a computer anymore. It displays the computer connection but I cannot get to the navigation while charging like I had before. Any help how...
I asked Garmin how to display maps when connecting a 265WT to a PC with a USB cable. Based on the following reply I received from Garmin the answer is you can't. Have you ever updated your software in your Garmin 265WT. Perhaps you were able to display a map with the USB cable connected with an earlier version of the software. Whereas the latest version of the software will not let you display a map with a USB cable connected.
"Thank you for contacting Garmin International.
I will be happy to help you with this. Unfortunately when your unit is
connected to a computer you will not be able to use the device. The unit
is designed to go into mass storage mode when connected to a computer."
Sep 20, 2009 | Garmin nuvi 265 Car GPS Receiver
It wont load when I turn it on
I hope that helps.
Aug 01, 2009 | Garmin n?vi 265WT Car GPS Receiver
No maps found when updating garmin with latest maps
I hope that helps.
Apr 12, 2009 | Garmin n?vi 265WT Car GPS Receiver
My garmin 265wt lost the map and audio while in use
I hope that helps.
Apr 07, 2009 | Garmin n?vi 265WT Car GPS Receiver
Frozen on 'loading...' page during registration
I hope that helps.
Jan 30, 2009 | Garmin n?vi 265WT Car GPS Receiver
Nuvi 265wt Shuts off then back on and keeps doing this
I hope that helps.
Jan 25, 2009 | Garmin nuvi 260W GPS Receiver
Garmin n?vi 265WT Car GPS Receiver Logo
689 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
