Sony Cyber-shot 10.1-Megapixel Digital Camera - Black Logo
Sue Lindstedt Posted on May 12, 2009
Sony Cyber-shot 10.1 no power, I put in two charged batteries, nothing, is there a RESET button?
  • Sue Lindstedt May 12, 2009
    model on bottom N50 (cyber-shot 10.1)
  • Anonymous May 11, 2010
    Please intimate exact model of Sony camera written at bottom to lok for possible cause of no power.
5 Related Answers
Anonymous
  • 188 Answers
  • Posted on Jul 02, 2006
SOURCE: Sony Cyber-shot DSC-U10 low battery indication.
possible short circuit that is draining battery at a speed. get your camera tested at some good repair shop,
RixsFixes
Radio Code Pro
  • 2200 Answers
  • Posted on Jul 16, 2009
SOURCE: Reseting Sony H1 digital camera
Hi
If you examine the body of the camera there is a tiny reset - which is recessed into the body. To access it you need somthing such as a bent out paper clip wire.
Hope this helps. Remember to rate my answer. Thanks.
Anonymous
  • Posted on Sep 04, 2009
SOURCE: Sony Cyber-Shot DSC-H1 Digital camera that will not hold a battery charge
Aparently you have to use sony batteries with a sony charger. I have the same problem and have been trying different batteries because I thought what's the difference with batteries as long as they are rechargeable? I spoke with a guy at the sony store and he told me to use sony batteries with the sony charger I have. Don't know if he's talking BS or not but I'll give it a shot and see if it will hold a longer battery life. When I bought the camera it was great but now it dies really fast! I'll let you know how things turn out! Until then, if anybody else has a suggestion let us know so we can enjoy our H1's!
  • 102366 Answers
  • Posted on Feb 16, 2010
SOURCE: Sony Cyber-shot 10.1 user manual
Sony makes more than one 10.1MP Cybershot camera. If you know the model number, you can look for the appropriate manual here: http://esupport.sony.com/US/perl/index.pl
Anonymous
  • 11967 Answers
  • Posted on Apr 16, 2010
SOURCE: Cyber-Shot DSC-W120 won't turn on.
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Accepting Language
Try charging it to see if that helps if its under warranty bring it back or google to to try a factory reset
When i put the battery in my DSC-T300 the cyber shot screen comes up but nothing happens after that. The camera has never been wet, although i took it to afghanistan for a year but i kept it in its case...
Hello .Make sure battery is fully charged .Inside battery door compartment there should be a reset button to push..Try that, if unit still wont work,yes there is good chance unit was subject to moisture .Please let me know..Goodluck
Background all dark
Try to reset the camera through the menu.
http://esupport.sony.com/US/perl/model-home.pl?mdl=DSCT1&LOC=3
The above is the page for your camera.
Solution
sp.gif sp.gif Cyber-shot cameras nowadays have a built-in rechargeable battery for retaining time, date, and other settings. Since the built-in rechargeable battery is not removable, current Cyber-shot camera models can only be returned to the original factory settings by pressing a small RESET button on the camera or by using an Initialize option in the menu.
Older-model Cyber-shot cameras (prior to the year 2000) do not have a built-in rechargeable battery and do not have a RESET button or Initialize option in the menu. These cameras require a manual power reset.
IMPORTANT: To determine whether or not your camera has a RESET button or Initialize option, or for other model-specific information to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
Follow the appropriate procedure below for your camera.
Using an Initialize option in the menu
Since Cyber-shot cameras have different menu system layouts, refer to the instruction manual specific for your camera model.
Using a RESET button
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
Performing a manual power reset
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
If your camera is experiencing an issue and the issue is not resolved by performing the appropriate reset procedure above, then service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Sir, Shutter of my Digital camera Sony Cyber-shot DSC-P72 is not closing / return to original position completely. I have tried with changing the battery too. Every time that I do power on the massage...
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C91134&fes=true&mdl=DSCP72
Try doing a power reset:
Solution
Region
sp.gif sp.gif Canada Latin America United States Products
sp.gif sp.gif Cybershot Digital Still Camera Last Modified Date: 03-04-2010sp.gifID: C265373
1helpful
Hi i have sony h7 and wan to reset to factory
Sony Cyber-Shot DSC-T5 Digital Camera My camera will not turn on
1. Please make sure that you're using the fully charged battery.
2. Try resetting the Camera. To reset the Camera, remove the battery from the Camera, press and hold the Power button for 30 seconds and then, reinsert the battery.
3. Please make sure that you're using the compatible battery with the Camera.
4. You may also try using a different battery to check whether the issue is with the battery.
2helpful
My DSC-W120 Sony camera won't turn on OR remain on. If I remove the memory card and the battery and reinsert them, the power might come on for 1/2 a second. The battery is fully charged.
Date and time mode
How to reset a Cyber-shot® digital still camera back to original factory settings. Solution
Older-model Cyber-shot cameras (prior to the year 2000) do not have a built-in rechargeable battery and do not have a RESETbutton or Initialize option in the menu. These cameras require a manual power reset.
2helpful
Sony DSC-W55 Access Message - lenses going in & out automatically
Please remove the Battery from the Camera then reinsert it after two minutes. Make sure that the Battery is fully charged. if menu options are accessible on the Camera then reset it to the original factory settings. Please follow the steps that are mentioned below to reset the Camera to the original factory settings:
(i) Please turn ON the Camera.
(ii) Then use the control button on the Camera to the select the Setup (setting) option.
(iii) Next, select the Setup1 option then "initialize".
Performing the above mentioned steps will reset the Camera to the original factory settings. If the issue persists then service will be required.
3answers
Power on n off
sounds like a battery power problem or problem with the terminal of the camera ; you know the point where the battery meets the camera.
I would recommend a service center
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
