Question about Copystar CS-1820 Copier
ERROR CODE "C7980". I HAVE ALREADY EMPTIED THE TONER WASTE. WHAT DOES IT MEAN AND HOW DO I FIX IT?
MY PRINTER (KYOCERA CS1820) IS GIVING A "C7980" ERROR. WHAT DOES THIS MEAN AND EXACTLY HOW DO I FIX IT. I HAVE ALREADY EMPTIED THE TONER WASTE.
    President:
  • Copystar Master
  • 990 Answers
Hello sir; The code you display which means waste toner bottle full, just dump it .
Posted on May 12, 2009
C7980
waste toner is full,,emptying it will get rid of the code!
Jan 29, 2014 | Kyocera Mita KM-1815 All-In-One Laser...
C-7 980 error code
can you give us the error code?
waitin for your reply.
May 08, 2008 | Kyocera KM-1505 Copier
Error code C7980
This code relate to the waste toner sensor, which means your waste toner tank is full, what you can do is, take out the imaging unit(is the unit where the toner sit) look at the lower sides, there is screw from each side, take off the screw and dump the waste toner out.(use plastic bag because it is going to be a mess if you do not use one. If you do not want to go through all this procedure just order the imaging unit and replace it.
Dec 13, 2011 | Kyocera Copystar CS-1820 Black and White...
Error occurred. call service person c7980 printer
try unpluging it(the power and the usb), count to 15 and plug back in
Jan 25, 2011 | Kyocera FS-1118MFP Laser Printer
Kyocera FS-1018MFP photo copier. Our copier has an error message C7980 which we understand means that the toner waste container needs emptying. Is there an easy way of carrying out this operation?
remove the drum unit. on the part of the unit that goes first in machine is the is waste toner container. on each side of the container there is a screw, remove one screw and pull out the cover. slant the unit and the waste will come out
Oct 05, 2010 | Kyocera KM-1505 Copier
The printer shows "Call service person" C7980. What is the problem and how can it be corrected?
this a drum unit related problem. empty the waste toner and the error will reset automatically
Aug 27, 2010 | Kyocera Copystar CS-1820 Black and White...
What is error code c7980
this is drum related error. empty waste toner from the drum unit
Aug 20, 2010 | Kyocera Copystar CS-1820 Black and White...
Error occurred. Call servoce person. C7980
Waste toner reservoir overflow problem (when the total number of copies is less than 100 thousand sheets) You need a new pcu
Jun 05, 2009 | Kyocera FS-1118MFP Laser Printer
KYOCERA MITA KM-1500 ERROR CODE C7980
C-7980 - Means that the waste tonerresevoir in the process unit is full with less than 100,000 copies onthe unit.
Clean/ empty the waster toner and vac.Also clean the sensor.
You may have to change the Process unit if cleaning does not work.
Mar 02, 2009 | Kyocera KM-1505 Copier
Kyocera cs1820
c 7980 is a warning that the waste toner container on the imaging unit is full, This usually means the life of the imaging unit is finished or close to being finished. If u dont want to replace it yet, a quick way is just to empty it. on the left and right of the unit at the back you will see 2 screws take those out then remove the small covers and just poor the toner out(DONT BLOW INTO THE UNIT). put tje covers back on, clear off any spilt toner and put the unit back into the machine
Aug 14, 2008 | Kyocera Copystar CS-1820 Black and White...
1,796 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Scott Yeoman
Level 1 Expert
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
