Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
External hard drive stopped driving.
Have a Western Digital mdlWD800B015RNN serial # WCAM92660307, order #WDXUS800SSNN that is external hard drive that is locked up. Blue power light will light when pressed but will not turn off. No action. Is there a reset. Do I need to drop it on the floor?
  • 413 Answers
First things first .....check for power cable and data cable and make sure they are not tampered or damaged inside the casing now move to next step>>>
kindly remove all jumpers in HDD now go to
Control panel>Administrative tool>Computer management>Disk management
you can see the disk here and change settings accordingly like assigning path and drive letter if this does not work
then just see that is it recognized in device manager as unrecognized device then update driver for HDD even now if the problem persists
KIndly consult the manufacturer
please do not drop it on the floor.........
Thanks And Regards
Posted on May 13, 2009
Question about retreiving data from external hard drive.
There are no problems hooking a external hard drive to any computer. If you mean take the hard drive out of the external case and putting it inside of your computer with a SATA cable, you can do that to. If your worried that they are both Western Digital, there are no conflicts with that either.
Good Luck
Dec 07, 2013 | Western Digital Computers & Internet
Is this a plug and play drive?
In most computers that are encountered, devices that are plugged into the USB ports are "plug & play" capable. There are numerous scenarios that can turn this function off inadvertantly such as a virus, data corruption or driver changes. In order to fix the issue and make an external device, such as a Western Digital Passport Elite hard drive "plug & play" capable, a user will have to make a few system changes. Click "Start" and "Run," then type gpedit.msc Click on "Administrative Templates," from the tree then click on the "System" folder. Double click on "Turn off Autoplay." Select the "Disabled" option and ensure it applies to all drives. Hope this helps,
Dec 12, 2012 | Western Digital 500GB ELEMENTS 500 GB USB...
I'm trying to install a Western Digital Serial ATA Hard Drive into the external hard drive enclosure. There are no instructions as to what cables need to be attached and to where
USB external hard drive cases are supplied with SATA and power connectors attached to the circuit board in the case. If you canot connect it to the SATA hard drive then you may have the wrong drive case, your case may be a IDE or SCSI type.
Jul 07, 2011 | NexxTech 1 Bay USB 2.0 External Drive...
My Western Digital Passport 80GB Hard Drive is no longer detected when I plug it in. The power light is on, the drive is running but it is not detected on either of my computers running Windows...
Any external disk-drive as small as 80GB is probably "out-of-warranty" -- it's likely that the disk-drive inside the enclosure has "died".
You have two options, not mutually exclusive:
* exercise the Western Digital "Customer Loyalty" program -- find the serial-number of your Passport, and access WD's web-site to buy a new Passport, citing the old serial-number to qualify for a significant discount on your purchase;
* open the enclosure, disconnect the disk-drive from the USB-to-disk-drive adapter, buy a new, compatible, disk-drive, and connect it to the USB-to-disk-drive adapter, to "frankenstein" it, creating a "new" external storage-device.
Oct 24, 2010 | Western Digital Passport WDXML800UE...
Where can I get a replacement USB cable for a Western Elements 500GB external hard drive?
you should be able to get one from any reputable computer store,where ever you brought the drive from may be able to order you another usb lead,
May 15, 2010 | Western Digital Elements powered by WD 320...
My computer does not recognize my WD external drive
You've tried different USB cables; so, that cannot be the problem.
You've tried connecting to different computers; so, the problem is _not_ your computer.
What's left is "inside" the case:
* the USB-to-disk-drive adapter,
* the disk-drive.
Open the case, and remove the disk-drive, and connect it as a "slave" drive to some computer.
If it is detected, then the USB-to-disk-drive adapter that has failed.
If it not detected, then the disk-drive itself has failed.
FInd the serial-number on the Western Digital disk-drive, and enter it onto Western Digital's web-site, on the "check-warranty" page. If it's older than 3 years, the warranty probably has expired, unless you were "lucky" and got a 5-year warranty.
Western Digital has a "Customer Loyalty" program -- just buy a new Passport through their web-site, and cite the serial-number, and you'll get a significant discount on _their_ price (could be higher than your local retail computer-store) for a new (probably larger) Passport.
Apr 05, 2010 | Western Digital WD Passport 250GB Portable...
Western Digital 1 TB External Hard Drive and BSOD
perhaps the new hard drive is bad western digital software is junk take it back and get seagate external w/freeagent on it
Dec 31, 2009 | Western Digital My Book Essential Edition...
Windows Server trying to boot from external hard drive
go into your 'update settings'. there is a section of where it asks you about how you want your settings set and where to send updates to. You may find the problem here. Check all the 'advanced' settings as well. If your Western digital is plugged in via USB and not requiring updates, unplug it while starting your system, after complete start up, reinsert the USB plug. It may show new devise found, then from here, you may be asked to reinstall it to stop the rebooting.
Aug 24, 2009 | Western Digital My Book Essential Edition...
It whirs for a few seconds, stops, then whirs again for a few sec
The hard-drive is "dying".
Is it still under "warranty"?
When you have the serial-number of the hard-drive inside the external unit, access Western Digital's web-site, and check the Warranty Status.
Note that Western Digital (the maker of the external drive)
has a "Customer Loyalty" program. Enter the serial-number
of the hard-drive on their web-site, and you can purchase a new external hard-drive at a significant discount.
Jun 01, 2009 | Western Digital My Book Essential 500GB...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
266 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
