Question about Jenn-Air Electric Double Oven
My jenn air model ww2780w double oven has nothing lit up in the digital panel, and i cant use the darn thing. Help!!!
    Scholar:
  • 54 Answers
BrianGem posted a great solution back in May of 'o8, I just completed that fix on my own Jenn air, took me about 30 minutes once I got the correct capacitor.
The display board appearently has a weak spot in the design, most likely heat related, (probabily low priced components from offshore sources)
Fix: Replace heat dammaged capacitor labeled C3 on display board, Hard part will be obtaining the 35Volt 68uF capacitor, I'm luckey enough to have a Brother in the electronics design field who found me a couple of high reliability caps designed for hot applications, He does not recomend changing sizes without design review for fear of overloading another componant, however several other posts have indicated a 35V 100mF cap has worked fine for them.
My control panel was attached to the oven with 4 screws accessed from above the top oven door, the panel slid up about 1/2 " and lifted off, Unplug the ribbon cables and the panel can be removed to a convenient work surface. The display board itself is mounted with 4 screws and connected with a wide flat ribbon cable, the suspect capicator is surface mounted to the reverse side of the board, two plastic clips need to be released (gently) and the ribbon cable unpluged. Capicator is likely discolored or leaking, Desoulder it and replace with new, match polarity marks and dont use any more soulder than needed. TURN OFF POWER TO OVEN PRIOR TO STARTING ANY REPAIRS. and good luck.
Thanks for this site..
Posted on Aug 12, 2009
MY Jenn Air model WW2780W isn't coming on. When I click on the control panel it clicks then the display says 140 preheat on.. for about 30 seconds then it shuts off it has done it for awhile and it would...
I have the same double wall oven, and it will "turn on" and then shut off after about 30 seconds. The top oven stopped working 4 years, the bottom oven stopped working about 2 years ago. Both are doing the same thing. I'm interested in replacing the capacitors to see if that fixes the issue. There are 2 larger capacitors (1000uf 35v), and lots of smaller ones. Is it safe to assume it's the larger ones that need to be replaced? The only other 2 matching capacitors are very small (0.47uf 5v). I know this is an old thread but would appreciate any advice. Thanks!
Sep 27, 2013 | Jenn-Air Ovens
I have double oven my lower oven is not working appears a code in the screen that is not allowing to work the lower oven i restart unit in the code disappears but letter around cameback the code to the...
The exact same thing just happened with my lower oven and the code 4d22 appears in the upper right part of the display panel by the the timer. There is no explanation for the code in the instruction manual. Hope someone can help us with this. Upper oven works fine.
Dec 20, 2010 | Jenn-Air JJW8230D Electric Double Oven
The control panel display light is completely dark but the oven still seems to function ok. Jenn Air Model WW30430P double wall oven.
A lot of ovens use a gas-filled vacuum flourescent display module that takes a higher voltage to drive it. The modules can get damaged or the power supply for the higher voltage (usually around 50 volts) may have failed.
Chances are the thing is only sold as an assembly...While the displays are common in auto speedometers that have digital display, those for these ovens are special with wpecial characters and background.
Jan 31, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
Jenn air oven
More then likely your electronic clock control board is going bad. After turning the power off, you can also try cleaning the connectors on the clock board and make sure the connectors are tight.
Mar 23, 2009 | Jenn-Air JJW8230D Electric Double Oven
Very old Jenn-Air wall oven (model w100) will not heat
nope..no fuses...time to research a new oven.
May 28, 2008 | Jenn-Air Ovens
Jenn-Air built in oven Model W188-C, Serial # 210764UC approx 1987
Big oops, Millwood. Shut power to the unit immediately and wait a day or more for it to dry out. If it works then, fine. If not, you've got a learning experience installing a new pad.
Dec 07, 2007 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air Electric Double Oven Logo
643 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
