Question about Dell Latitude C610 Notebook
How to replace usb port
I have dell latitude 640. today its usb port stop working. i attached usb storage device, usb mouse but noting detected. can i replace this usb port?
    Problem Solver:
  • 7 Answers
You are either missing the driver for usb or the problems is a hardware issue. Go to my device manger on your computer and update or reinsatall the driver. Check fo any drivers confilcts. If that does not solve the problem check if usb is lose. Possibly it became lose form mother board. You may need to solder it back.
Posted on May 12, 2009
  • 531 Answers
Yes you can, but in most cases it's just a cold solder and it just needs to be resoldered.
If it's not missing pins or physically damaged otherwise, try to resolder it first.
My Dell Laptop USB ports are not working any more
Do they not work on any device? Have you tried using a device that they used to detect in the past? Maybe the device you are using is too advanced for the old D600. For example, I would imagine it would have a hard time detecting a 1TB external hard drive.
If it will not detect a device that used to work in the past I would go into the BIOS or System Setup and make sure the USB is enabled. When you turn the laptop on just watch the screen and it will tell you which key to hit to get into the Bios or System Setup. I think it is the F2 key for the D600.
Apr 30, 2012 | Dell Computers & Internet
My Dell Latitude D400 laptop's USB ports stopped working. They used to work fine, now they don't recognize anything (card readers, mouse, camera, etc.) I removed the USB port drivers and reinstalled. It...
USB port is corrupt...if all that you said is what is happening then the best is to
buy a keyboard to USB port convertor....
refer this image....Ebay has it for about 1$
May 10, 2010 | Dell Latitude D400 Notebook
The USB port on my DELL Latitude C400 does not recognize the mouse
try to use otehr usb ports on your computer. check if the light on the bottom of the mouse lit up. open device manager. under mouse - delete otehr mouse components then restart computer.
Mar 08, 2010 | Dell Latitude C400 Notebook
XP crashed on my Dell latitude D600 laptop. I reloaded XP and all drivers. Everything works except it does not detect any device when plugged into the usb ports. They do light up. Utlities suggest that the...
I cant figure out a solution exactly as you have already tried things people have told you previously. but as far as i know dell should solve your problem for free instead of telling you to fix it. did you try contacting them and are you in your warrenty period?
Aug 03, 2009 | Dell X2033 - Latitude D600 D500 Inspiron...
go to mfg websight and down load all th proper drivers there is likely a mother board driver not installed that allows it to see the ports
install all of the manufacturer's drivers
dont expect that microsoft wrote windows just for your computer it is a general set of generic drivers that make most things work but not every thing
http://support.dell.com/support/downloads/driverslist.aspx?c=ca&l=en&s=gen&ServiceTag=&SystemID=LAT_PNT_PM_D600&os=WW1&osl=en&catid=&impid=
U.s.b not reconized
disconnect all USB devices attached to the system and remove/uninstall all USB HUB entry in the Device Manager. Restart the computer, reconnect the USB device and confirm if the system detects it. Test all USB ports of your system. If no go, updating the BIOS is another thing that you can try. If all fails, it can really point to a motherboard failure
May 14, 2009 | Dell Latitude D600 Notebook
I have an inspiron laptop. the two USB on the side stopped working all of a sudden however when I checked the computer stated that they are working fine
may i know what device was connected to those ports?try connecting a mouse to the same ports and see whether it is detected.If it works well and fine.Other wise goto Control panel>>System>>Device manager>>Universal Serial Bus Controllers>>Here, delete all the USB Root hubs.If you are removing them using a mouse connected,then u might lose the mouse response after u delete the USB Root hubs.Please note this.Restart the system after deleting all the Root hubs and wait for a few seconds for them to get installed back.Restart again and confirm whether the issue is resolved
Mar 15, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Usb not recognizing the mouse or flash drive
have you tryed the devices with out the cooling pad? USB ports have a limit on the amout of current they are able to source and it could be that the cooling pad is drawing to much current.
Regards
Nick
Oct 26, 2008 | Acer Aspire 9503EWSMi Notebook
Replace broken usb port on dell latitude laptop
You will have to take the machine apart somewhat, or at least to the point of being able to disconnect and remove the usb port. Here's a link to the D600 service manual download. It will guide you through the breakdown process.
http://support.dell.com/support/edocs/systems/latd600/en/index.htm
Jul 27, 2008 | Dell Latitude D600 Notebook
Dell Latitude C610 Notebook Logo
386 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
