Question about KLH R5100 Receiver
Klh audio video R5100 surround sound receiver
To whom it may concern
when i make a test from the unit , it checks all 6 speakers , and each speaker test is fine making that static or hissing sound as it goes from 1 speaker to the next , but iam only getting music or video out of the right side speaker only , but the test indicates that all are working ,is there a fix for this proplem ? or should this item be terminated?
best regards
spider mike ..........
  • 77 Answers
Could be 2 things....
1) The receiver could be set to feed the right speaker with more volume. Check the volume setting for each individual speaker on the receiver.
2) The cable connecting the left input from your dvd player is not connected properly or is bad. Try swapping the left and right audio input cables to see if this moves the problem to the other side. If it does - get a new cable.
Posted on May 12, 2009
What's your problem?no sound
Put your unit in Direct Mode or Pure Audio Mode. If you now have audio in your front right and left channels only then you have a problem with your DSP circuit. If you do not have audio at all, then check your + and - 15 or 12 volt lines. If the voltage is missing then you probably have a bad regulator.
May 17, 2012 | KLH R5100 Receiver
My front left speaker has distorted sound coming from it. any advice?
Check to make sure the speaker cone is not damaged. Then test the channel with another speaker (use your front right speaker) to see if the channel is the problem.
Jul 27, 2010 | KLH R5100 Receiver
What speakers are beneficial with this receiver? I want to have surround sound from my TV and also from my other components - CDs and old record player.
Well to get the full effect of 5.1 surround you will need 2 front speakers, 1 subwoofer, and 2 rear speakers. Personally I used 2 tower speakers, 2 rear speakers and a subwoofer. Match the speakers with the RMS wattage of your Receiver. (100x5) or roughly 50 watts per speaker. Yamaha, KLH, Philips are pretty good speakers.
May 13, 2009 | KLH R5100 Receiver
Workn my system
There should be a botton on the receiver that say for example, Speaker A, Speaker B, Speaker A B witch would be all of them, if your refering to surround sound try the Prologic
Oct 18, 2008 | KLH R5100 Receiver
KLH RS100 Receiver
Swap the left and right speakers, if the problem transfers, then the left channel is out. Theres 5 amplifier sections in this receiver and that one would be defective. A component troubleshooting technician would need to fix it.
May 10, 2008 | KLH R5100 Receiver
Klh r5100
Depending on the watts on your stereo would tell you the most, for example say its 300 watts u buy a 150 watt speaker it would blow the speaker, if you buy a 500 watt speaker your risking frying the stereo, it be best too even it out as best you can, i know that this has nothing to do with what ur asking but it would help you to save more money on buying a new speakers or receiver, now to the answer to you question, i would recommend a 12inch speaker, it would give you good sound quality
Mar 10, 2008 | KLH R5100 Receiver
Can get either 1 or 2 speakers working at the same time.
u can't do use a 5 with a cox only with fiberoptic than it will work
Jan 12, 2008 | KLH R5100 Receiver
Surrond sound
For Stereo Mode (Front L & R Speaker), you must plug RCA cables (match up red and white) from Output on DVD player to DVD Input on the back of the receiver. Then with speaker wire, run from receiver speaker output (Front Speakers) to designated speaker (make sure + and - match up to both input and output). As for hooking up surround sound, I'm currently trying to figure that one out with just using the L, R and Center. I don' t want wire running all over the place just for rears. Hope this helps
Sep 04, 2007 | KLH R5100 Receiver
KLH R5100 Receiver Logo
509 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
