Question about Troy Bilt Walk Behind Chipper/Shredder/Vacuum 205cc
MTD yardman chipper wont start get spark need manual
I am successful too at using the starting fluid in the carb or directly into the clinder. That is how I start my MTD 5.5hp chipper. My problem is I have to hold down the primer bulb to keep it running. If not, the engine will stall.
Posted on Apr 18, 2010
  • 3 Answers
Clean out gasoline
from tank & Carb. pull plug and clean.
When refilling besure gas is cleared from
fuel lines pull filter off and spray carb. cleaner
directly into carb, and try starting. if this did
not work besure to check fire to the plug.
Posted on Sep 29, 2012
  • 513 Answers
Good spark or weak spark check compression spray starting fluid in carb try these & see what happens if you have good spark & fuel it should start the only way it won't is if the head gaskets blown which isn't comen but possible
Posted on Jun 05, 2009
Can anyone help me and tell me the part number for a blade for a dx70 Mtd yardman 8.5cc
Duncan, Blade #, MTD Part No 742-0578, 27.5" should be replacement bade for Yardman DX70. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
GENUINE 27 5 Blade for Yardman DX70 MTD Beatle Lawnflite 503G Ride on Mower
YARDMAN DX70 MODEL 310 SINGLE BLADE MOWING DECK FG424 5900
Yard Man 13A 325 402 Operator Manual
May 21, 2016 | Mtd Garden
Mtd yardman wont start getting feul no spark detected
they go bad rarley make sure your blade brake switch is not ingage killing spark
Apr 19, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
MTD 5hp. Starting and running only while I spray
Remove the fuel line from the carb. Drain fuel tank and blow thru fuel line until clear. If you use compressed air be very careful to use LOW pressure. I just use my mouth. reinstall fuel line replace the fuel filter, add a new spark plug for good measure and refill gas tank
You should be chipping away right soon!
Mar 04, 2010 | Garden
Having trouble with Mower...what to do?
Clean out the carburetor float bowl and main jet. Sounds like dirt or moisture in it
Sep 12, 2009 | Yard Machines 24a 021h700 4.5 Horsepower...
I need owner's manual for troy bilt chipper/vac model # 47291
you can try a MTD ride on mower dealer or steelfort Engenering web site or mtd web site.
Sep 05, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Have MTD model 464b 6.5 hp chipper/shredder purchased 3-28-01. It hasn't been used for 5 or 6 years. Loaned to son-in-law only to find out it won't start. Is there anything other than spark plug, air and...
Hi, I'm almost sure that if it sat that long that your fuel has turned to varnish and you will have to clean out the whole fuel system including carburetor with a good solvent before you will get it to run. This is assuming that you have spark to the plug
Aug 25, 2009 | Mtd Heavy Machinery
I need a owners manual for a 10 hp chipper schreddermodel 24a464g729 serial no. 1io14g4o175 i think i may need blades
Go on line to " PartsTree.com" Start your search by clicking on MTD. Go to chipper/shredders, and fine your Model number, It's listed. In the search window- type in chipper blade. Also, on the drawing schematic of the machine, the blades are # 31 in the list of parts. I looked up the 2005 model. There are are few years with the same Model #.
Jul 14, 2009 | Mtd Products Yard Machines 158CC Tiller
5hp b&s mtd chipper wont start
defiantly the carb but its not bad - clean / soak it with some seafoam and blow out all the holes. its just clogged and isnt getting the fuel/air mixture right.
Mar 30, 2009 | Heavy Machinery
Troy Bilt Walk Behind Chipper/Shredder/Vacuum 205cc Logo
1,352 people viewed this question
Top Troy Heavy Machinery Experts
Matt Olenzek
Matt Olenzek
donald boissonneault
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Troy Heavy Machinery Expert? Answer questions, earn points and help others
