Question about Garden
Engine will not start
I have a mtd yard machine rider,it will start,has gas but i do not see any spark at plug.it is a koler engine.
  • 86 Answers
First are all saftey switches set right blades off,out of gear, The only other thing would be points or module.
Posted on May 13, 2009
Wont start gas
squirt some starting fluid in the carb see if it will startif not chek for spark at plug if fireing check gas for water after that remove float bowl from carb clean it out replace plug and it should start
May 18, 2013 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
Lawn push mover
STARTING PROBLEMS ?? For a gas engine to start basically you need two things..fuel delivery and good spark....remove the spark plug ...Is it wet with gas??IF YES good you have fuel going into the cylinder.BUTwhat about spark?..Put the plug back in Pull the plug wire use a wooden closepin to hold the wire real close to the top of the sparkplug and have someone pull thr cord you should see little sparks jumping from the metal connector on the end of the plug wire to the sparkplug if you have spark.. if you have both fuel and spark maybe you have bad gas??You could try shooting a little starting fluid[ether] into the sparkplug hole screw the plug back in and try starting again..Goodluck RW...
Jan 21, 2013 | Mtd 22" Yard Machine Push Mower
My MTD Yard machines riding mower won't start.
Probably dead gas from sitting too long. Dump it out & put in fresh gas.Could have moisture in it. Pull out spark plug & crank it over several times after putting gas & let it sit a while to dry out or blow it out with compressed air. It should go.
Apr 04, 2012 | Mtd Garden
MTD Yard Machine 675 series 190cc Always started now won't, does not turn over. Can pull it to start but does not start. What can we do to fix it. One year old, never had problem before. Machine...
Based on you question, this could be anything (like going to your Dr. and telling him "I'm sick"). That being said, if it just sat with gas in it, then it's likely a fuel problem (ie; plugged carburetor). These machines do not like the new Ethanol Gas and they cannot be left to sit or they'll gum up on you. An engine needs three things in order to start and run. 1. Spark 2. Fuel 3. Compression. First check your spark; if there is no spark, it'll never start. If there is spark, then I recommend a good carb cleaning. Better left to a professional if you're not familiar with this procedure. I hope this gets you started in the right direction. Best of luck to you. (You can find "how-to" videos on all these procedures by searching on YouTube)
James
Oct 15, 2011 | Mtd 22" Yard Machine Push Mower
My 5 hp MTD mower keeps stalling after running for a couple minutes. I then prime it excessively and it will start back up and do the same again. I have cleaned the carb and replaced the priming needle,...
You probably have already done this, but I had a JD 111 rider awhile ago and did most of the things you have done with no success. Then I replaced the fuel line and "BINGO" it worked great after that. Seems the line had a weak spot and would **** closed when trying to start.
Good Luck
Jul 10, 2011 | Yard Machines 11A54MC006 21Inch 139cc MTD...
It just quit running...sounds like it's trying to start...It has gas and oil and the filer is clean....
Check for spark, try pulling the wire and hold it near the engine while trying to start it, look for a spark to jump. If no spark replace the wire or the ignition coil. If you get spark try replacing the spark plug. if you get spark you should also pull the spark plug and see if the end of the plug looks wet if its not wet you aren't getting fuel and I can make some other recommendations.
Jun 08, 2011 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Yard macine model 139cc will not start. Has gas and oil... where is the spark plug located on the lawn mower? I would like to replace it.
The spark plug is at the end of the thick black wire in the middle of the front of the engine or looking at the mower from the front, it is to the left of center. Make sure you set the spark plug gap before installing it new. The gap is probably around .030". They have tools for doing this at the auto parts store. Sometimes and older plug can be cleaned with a stiff wire brush and some solvent and gapped properly and continue to work well.
May 28, 2011 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Mower won't start, it is a Yard maching with 5.75 hp B&S engine, cleaned carburator, replaced gas in tank in case it was stale.
check your spark plug and also check to be sure you have spark. if you have no spark,,,your control cable has probley streatched and not letting your kill switch disingage. there is a cable that runs down to the engine. follow it down and remove the cover that it goes into. unhook the black wire and try to start the engine. if it starts, put new cable on.
Sep 20, 2010 | Mtd 22" Yard Machine Push Mower
Lawnmower won't start
Remove the bowl from the carb. and blow it out with air.
May 07, 2010 | Mtd 22" Yard Machine Push Mower
Lawnmower wont start
Possible Causes Corrective actions
Unit will not start Control handle is not engaged Engage control handle spacer.gif spacer.gif
Spark plug wire is disconnected Connect spark plug wire spacer.gif spacer.gif
Fuel tank empty or stale fuel Replace with clean, fresh gas spacer.gif spacer.gif
Air filter filled with dirt or debris Replace or clean air filter
May 23, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
85 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
