Question about Mitsubishi WS-65411 65" Rear Projection Television
Mitsubishi WS65411. Front panel dead.
The front control buttons are dead.  Remote still works.  Can it be fixed?
    Novelist:
  • 192 Answers
 This set has a keyboard lock feature and it can be removed by pushing in the menu button on the front keyboard on the set for about10 seconds. This should take care of your problem.
 Reply to this post if you have any questions and I will respond.
Posted on Oct 14, 2007
Ws65411 shut off then restarts
Could be a failing power supply. Nothing to do with the remote.
Sep 06, 2014 | Mitsubishi New Original WS65413 Remote...
Tip
Bypass Mitsubishi WS-48511 Front Lock
Bypass Mitsubishi WS-48511 Front Button Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi HDTV Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
________________________________________
Reset Mitsubishi WS-48511 VChip Password
Mitsubishi WS-B55 Manual Download
on May 03, 2010 | Televison & Video
My mitsubishi ws55511 remote does not work and
The front buttons need to be replaced. I would replace them all due to no being able to tell which ones are the bad ones. It should fix the problem.
The part # of these Tactile switches is 432P089010. Mitsubishi's parts department phone is 800-553-7278.
The two front grill covers pull off and the front plastic housing unscrews from the front.
Hope this helps,
Sky Assoc
Oct 21, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511 not responding to remote or front panel. Tried System Reset Button several times. No luck.
Sometimes the control panel switches on the front of the set go bad.
Try running your fingers across the buttons to see if it helps.
I ended up disconneting the front panel switch board and just use the remote now.
Oct 15, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Tv won't power on ws-65511
This forum is pretty dead. Anyways the technician came and disconnected the wires running to front control panel ( where the buttons are). And now the TV works with the remote. Apparently the front pannel had shorted.
Details: He moved the grill on top of the speakers. You will see two sets of wires running from the bottom of unit to the front control pannel. These wires are joined by clips. Just disjoin the wires at the clip.
Apr 18, 2008 | Mitsubishi WS-65511 65" Rear Projection...
No control of WS-65511
The following solution has been posted in another forum (www.hometheaterspot.com) and it fixed my remote problem:
"...it's possible that one of the front panel buttons is "stuck" or shorted, and this could cause the TV to ignore commands from the front panel or remote. But this should also cause the Power command to be ignored, too. You might try pulling off the front panel and disconnecting the front panel buttons and then see if the remote works."
Oct 22, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Tv turns on manually, but auto flips through channels and you can't use remote
Found this in another forum (www.hometheaterspot.com) and it fixed my remote problem:
Oct 19, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Will not power on. Please Help!!
Error code 12 means normal operation. On these models we have found that a switch is sticking on the control panel not allowing the set to turn on. Disconnect the control panel. You will be able to use the remote on it. To find the plugs for the control panel: Remove the speaker grill and front panel, then follow the wire to the connection. Remember to unplug the set before putting your hands inside of it. Tell me how it went. Lead Tech
Dec 14, 2006 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-65411 65" Rear Projection Television Logo
409 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
