Cx3650 Problem with paper feeder
Hi, i have a problem with the paper feeder. As soon as we try to print something the paper is being crushed to the right hand side and then there is a paper jam. I tried to switch off printer and also to put more papers but it's not working...
do you have any idea what can be done Please?
tks
    Scholar:
  • 134 Answers
There could be an issue with the gear inside your printer now that is why it is not feeding the paper through properly anymore. Please try this basic troubleshooting steps:
Turn off the printer. Disconnect the USB cable from your printer. Open up the whole scanner unit to see if there are objects blocking the way of the printhead or if there are any objects down the paper feed area. Check if the cartridge cover is closed properly. Toggle the paper guide left to right back to the proper position. Load 10 to 20 sheets of regular paper into the printer. Turn the printer back on. Do a standalone copy.
If it does the same thing, please log on to support.epson.com. Click on help me find a service center to the right of the page to find an epson certified servicer near to your area.
Posted on May 13, 2009
Hi, I have a Dell printer, and it says "MPF Load Error" every time I try to print something. How do I fix this?
Verify the Paper Type Matches the Type Set in the Printer´s Operator Panel
To verify the paper type matches the type set in the printer's operator panel, perform the following steps:
  1. Press the MENU button.
  2. Press the down arrow until Tray Settings appears and press the return%20arrow%203100cn.jpg button.
  3. Press the down arrow until Paper Type appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or Multipurpose Feeder) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper type, as shown in Table 1, and press the return%20arrow%203100cn.jpg button.
  6. Press the MENU button.
Print from the Multipurpose Feeder (MPF)
To print from the Multipurpose Feeder (MPF), perform the following steps:
  1. Click the Start button, point to Programs, point to Accessories, and click Notepad.
  2. Type the word test.
  3. Click File and then click Print.
  4. In the Print window, verify that the Dell 3000cn / Dell 3010cn / Dell 3100cn printer is selected in the Select Printer dialog box.
  5. Click the Preferences button.
  6. In the Printing Preferences window, click the Paper Tray tab.
  7. Click the Paper Source drop-down and select MPF.
  8. Click OK.
  9. Click Print.
Aug 19, 2011 | Dell 3010cn Laser Printer
Keep on paper jam everytime i try to print paper feeder not align help me pls how to fix this one
check for something they may have fell into the feeder like peice of paper or thumbtack anything that would obstruct the paper path.
May 04, 2011 | Computers & Internet
The feeder of my dell 948 printer crushes the paper and it does not go straight through the feeder (it is pulled to the leftside). Searchin on the internet I found a solution for if something was stick...
Use alcohol and a swab to clean off the paper dust off the pickup roller. You can also get paper path cleaning sheets from office supply stores. They are sticky on both sides and will remove paper dust from the rollers in the paper path.
May 04, 2017 | Office Equipment & Supplies
Loaded paper not going through
Annie, did you try to feed it one paper at a time? in many printers the feeder doesn't do a good job separating one paper from the rest.
another thing you can do is to turn off the printer and back on. this might get it out of the stuck status it is in.
did you check there isn't any paper stuck in the feeder?
Mar 10, 2010 | Lexmark X5470 All-In-One InkJet Printer
Hi :) I'm trying to print on my Canon PIxma- mp480 to no avail
Hello
This can be due to a feeder wrong setting on the printer or on your PC: your printer tries to take paper from the back feeder, whereas your paper is on the front feeder....
try to check these settings in your PC and on your printer, and retry to print, hoping this helps
Jul 29, 2009 | Canon Pixma MP480 All-In-One InkJet...
Hi, my name is Fernson I have a Lexmark t630 anytime i try to print something it says "load mp feeder letter "
Load "MP" means to load media into the Multi Purpose feeder , which is in the front of the printer.
This can be caused by several things, all of which are easy to fix.
First, open the printer driver and verify the correct selection of media draw.
Next, ujse the printer's paper menu to set the proper tray.
Lastly, make sure that the print file going to the printer is not asking for the MP Feeder.
May 07, 2009 | Lexmark T630 Laser Printer
Printer jams
I has a problem like this too. What I did is I checked the paper feeder by putting my hand in it (while turned off) and I found a ballpen cap.
Oct 09, 2008 | Lexmark X2500 All-In-One Printer
Epson CX3650 Printing Only half a page
This may sound nutty, but I have an epson stylus cx3650, with the same INFURIATING problem. And I think I *may* have just fixed it. and its daft, and simple, but we all know how picky printers can be!
Okay, the paperfeed at the top, on the left hand side is a grey slide, (right in the printer) to hold the paper in place. USE IT to keep the paper straight, it seems, if the paper goes in straight, the whole page is printed. I don't know how or why but it worked for me! ^^ (and this is after the printer was stored in a cupboard for a year, because of this problem!)
Nov 08, 2007 | Office Equipment & Supplies
Unable to print properly keeps printing on one line
Sounds like there is something jammed in the paper feeder, or maby its the paper feeder itself. Check to see if the path the paper follows through the feeder is completely clear. Sometimes paper is left in the feeder from previous paper jams.
Aug 07, 2007 | Lexmark X73 All-In-One InkJet Printer
123 people viewed this question
jasbo
jasbo
