Question about Kenmore Elite HE3 Steam 8674 Dryer
My Kenmore dryer is flashing a code F23 what does this mean?
It will not work at all and is flashing a code F23
  • 460 Answers
F33 Possible Cause / Procedure 1.-Unplug washer or disconect power  2.- Check for wire harness condition to the pump and Central Contral Unit (CCU). 3.-Plug in the
http://www.scribd.com/doc/7075573/Whirlpool-Kenmore-HE2-Plus-Troubleshooting-Tech-Sheet-8540259
Was this helpful?
Posted on May 13, 2009
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
My Kenmore elite smart heat quiet pak 4 automatic dryer model 110. 87872603 shut off during drying cycle and showed service code f23. The dryer was extremely hot.
call sears service . sounds like the exhaust blower has failed you or perhaps the filter us plugged and needs cleaned out which should be done before or after each use
Jun 16, 2015 | Kenmore Dryers
I have a Whirlpool Cabrio dryer, model WED6400SW, that displays an F23 code. What type of problem does the F23 code signify?
Your heating circuit is out of range. Most of the time, it's the thermistor that has gone bad.
Sears has the replacement:
Thermistor 8577274
If that doesn't do it, then the next most common culprit is the main PCB board.
Oct 19, 2014 | Dryers
Kenmore HE3 Gas Dryer F23 error
Well the F23 error code is an exhaust thermistor error. It indicates the thermistor is shorting out. This occurs after the thermistor heats up and that is why it happens after 2 minutes. Remember to unplug the power cord so there is no voltage present while servicing.
All you need to do is to pull the dryer out from the wall and be able to get to the back. If you can do this then you can replace the thermistor.
you can check out the below link for more information -
http://media.fotki.com/1_p,wksdqrtgsdbddsdxgtqsskgwtqkq,vi/wbrfdqtbtxwkrtsktgt/1/1303472/5961857/image59719img-or.gif
The thermistor part number is 8577274.
Good Luck!!
Thanks for using FixYa!!
Jul 07, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite slide in range model # C790-440732 keeps displaying error code F23 and oven will not work except on broil
I have the same problem with my Kenmore F23 code will not bake but the broil works?? What the heck?
Feb 07, 2010 | Kenmore Ovens
F23 fault
F23 that it indicates a leak into the base of the appliance.
You'll need to unplug the appliance and take the rear cover off.
Check for a spillage and if there is an anti flood device in the base, ensure it's reset/working or replace it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@@@@
Oct 25, 2008 | Bosch Logixx WFT 2806 Front Load...
Kenmore elite
It should just mean "Power Failure". Restart your dryer. Does your house loose power a lot? Or just the dryer. Check your power to the dryer.
Nov 18, 2007 | Kenmore Elite HE4 Electric Dryer
Error Code
I don't have a manual on the newest dryer like you have, but one of the models just older than yours has a F23 code that indicates a shorted thermistor.( temp sensor )
Since it is new you need to call for service. They will usually look up the code and tell you if it is anything you need to check but most likely you will need a repairman to repair it in warranty.
Post back if you have any questions.
Nov 08, 2007 | Whirlpool GEW9250 Electric Dryer
Kenmore Elite HE3 Steam 8674 Dryer Logo
1,100 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
