Question about Acer Aspire 5500 5570-2609 Laptop
DVD DRIVE NOT FOUND
I did a factory reset and now i have no dvd drive. It is not even showing up in the device manager but it still turns on and spins the disk. Is there anything that i can do to fix this.
I have an acer aspire 5520 with vista on it
Thanks in advance.
    Sergeant:
    Novelist:
  • 197 Answers
Try going into your bios (accessed by pressing a certain key when the computer boots, usually Del, F1, F2, F10, F11 or F12) and checking to make sure that your DVD drive is still enabled. Make sure that all SATA and IDE devices are set to enabled or Auto function.
Posted on May 12, 2009
DVD will not read any type of disk.
If there is an EXCLAMATION Mark for the DVD, the device could just be failing on you.
Mar 05, 2014 | OEM Systems Dell Xps 15 L502x L501x Blu...
I have a toshiba l355d and it is not showing that the dvd drive is even connected to the computer. Even in device manager. I have tried taking the dvd player out, cleaned connections and it does the
You have done all thing I would have suggested and if the BIOS does not detect this DVD drive then it is faulty and needs to be replaced.
If the BIOS detects the DVD drive then the DVD driver needs re-installing.
You can download the DVD and device drivers for your model laptop from the Toshiba WEB site from their download page. Make sure you enter the model of your laptop so you can get the correct drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Feb 12, 2013 | Toshiba TS-L632 DVD±RW Burner
Acer aspire 5740 DVD not recognized
Make sure it has power (ejects). Check Device Manager in Safe Mode by pressing F8 during boot. Right click My Computer > Manage. Select Device Manager > View > Show Hidden Devices. Now delete all DVD/CD-ROMs and reboot. Windows will say "New Hardware Found" and install. Check BIOS by pressing F key (correct F key is noted during boot) and make sure BIOS see's the Optical Drive.
Oct 25, 2012 | Computers & Internet
My dvd player used to work now it doesn't even show one is in the computer what doi Do?
Hi Maverick,
Can you get to device manager to see if your drive is installed and recognized by the system.
In windows 7/vista click start and type in 'device manager' in XP click start -> right cick on My computer and select properties and navigate to the device manger tab.
There will be a list of hardware installed in the list and you should find your drive under DVD/CD ROM drives. If there is a yellow exclamation mark - you need to update the drivers using the CD that came with the drive.
If the drive is not showing up in device manager you need to take your comp to a service center as there may be a fault with the controller.
Rhino.
Mar 05, 2011 | Lite On SHD-16P1S Internal DVD Drive
I have a compaq presario v6000 and my cd/dvd drive does not show or read cds, but it does spin when i put a cd in to it, also it does not show in device manager
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this dvd-drive then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 16, 2011 | Compaq Presario 12XL 104-106 Series 6X...
My computer no longer "sees"
hello
at end of this instruction set, see link to review more questions/answers,as your issue with CD/DVD ROM will vary .
This document applies to HP and Compaq desktop computers with Windows XP, Me, and 98. Use this document to make Windows and the CD writing software recognize the CD or DVD writer drive. Start at Step 1; do not skip to other sections until Step 1 has been completed. Step 1: Does Windows detect the CD or DVD drive? Use Device Manager to determine if Windows is recognizing the drive:
  1. In Windows XP, click Start , and right-click My Computer . In Windows 98 and Me, right-click the My Computer icon on the desktop.
  2. In Windows XP, select Properties , click the Hardware tab, and then click the Device Manager button. In Windows 98 and Me, select Properties , and click the Device Manager tab.
  3. Click the plus sign (+ ) next to DVD/CD-ROM Drives (or similar) category.
  4. Do the following depending on what is listed in the DVD/CD-ROM drives category:
    • If the CD or DVD drive name is missing , the drive is not being detected by Windows. Close Device Manager and skip to the section CD or DVD drive is not recognized by Windows .
    • If a drive name is shown but is disabled (icon is marked with a red X, c00877300.gif ), the drive has been disabled. Right-click the drive name and select Enable . You may have to restart the computer to complete the enabling process. The drive should work correctly once it has been enabled. NOTE: If the drive cannot be enabled, a required service or driver that the drive needs is not functioning or has been disabled. Click the plus sign next to IDE ATA/ATAPI controllers and troubleshoot any problems found according to any error codes in Device Manager. Resetting the BIOS may also resolve this problem.
    • If a drive name is shown but contains an alert icon (an icon marked with an alert symbol, c00877301.gif ), then use the section Using Device Manager error codes to troubleshoot the problem. You may also use the next section Disc burning software does not recognize the original drive to reset the drive configuration.
    • If the CD or DVD drive is listed as normal but your disc burning software does not recognize the drive, Device Manager shows no special icons c00877302.gif . Windows is detecting the drive but the writing software does not. Leave Device Manager open and continue with the next section Disc burning software does not recognize the original drive .
here is a link that will give you several other questions and answers to CD/DVD ROM issues.
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=11843&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=443069
please rate me with 4 thumbs UP to keep my services active
Dec 01, 2010 | HP Pavilion a810n (PP164AA) PC Desktop
My dvd and cdrom in Compaq Presario R3000 quit working. Help!
Unfortunately these devices will fail.
A new one will cost in the $20-30 range and is easy to install.
Mar 20, 2009 | Compaq 350831-001 - Presario R3000 Series...
Cd/dvd drive doesn't show up anywhere
Have you checked device manager to see if the drive is in there and has exclamation on it??
Nov 16, 2008 | Dell Inspiron B130 Notebook
LAPTOP 1502 DVD
right clik on my computer go to properties then hardware then device manager then find dvd rom drives then uninstall it .after uninstall it right clik any icon there then clik on scan for hardware changes.then it search if found any device simply clik next ..if not found turn off sytem .then check your cpu that dvd is connceted proter to mother bord.check data cable and power cable of dvd reconnect it.
then restart the cpmuter yout probelm is most of solved.
Oct 05, 2008 | Everex StepNote NC1500 Notebook
Aspire 4520 DVD combo problem
try uninstalling the drive in device manager then reinstalling it allso check for bad connections
Oct 14, 2007 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Acer Aspire 5500 5570-2609 Laptop Logo
98 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
