Question about Optoma EP739 Multimedia Projector
Optoma EP739 remote wont work
Purchased a new remote for an Optoma EP739. In order to turn the projector on, the power button on the remote needs to be pressed about 10 times. Once the projector is on, none of the other buttons on the remote work, not even to bring up or navigate through the menu. It seems like it’s a battery issue but new batteries made no difference. Although the remote will eventually power on the projector, it does not turn it off. It makes no difference if you stand away from it or bring the remote right up to the sensor. i was told the remote will work right out of the box, without needing any programming. is that correct? if programming is needed, how?
Benimur
  • 6966 Answers
SOURCE: no signal optoma ep739
One good thing is that you are running XP. Will work on the premise (that you have posted) worked before and the driver (ForceWare91.31) was the only thing changed.
Let's try the easy ones first. Activate twin/dual view in your Display Properties. Right click on any clear area of your desktop, click on Properties, click on Settings tab, select monitor 1 or 2 depending which is your primary and which is your projector. Check (or uncheck-whichever works) on box "Extend....". Apply, OK.
or
do the same with nView Properties.
The hard ones are registry and/or inf editing, though I am reluctant to even suggest.
Incidentally, there is an application that is supposed to facilitate twin or dual view configuration, UltraMon. This may be better/safer way to address your concern.
If all else fails, you may have to rollback/downgrade your driver.
Cheers.
Posted on Jan 20, 2008
marsrover
  • 682 Answers
SOURCE: projector has no power
close lamp compartement door firmly because door switch can disconnect power from projector if not closed firmly.
Posted on Sep 22, 2008
SOURCE: optoma ep739 won't power up
The lamp cover has a disconnect that won't allow power while the cover is off. Sometimes the piece of metal gets bent out of place.
Try removing the cover for the lamp, and bending the little piece of metal forward.
It worked for me!!!!
Posted on Nov 27, 2008
SOURCE: Optoma EP739
The lamp cover has a disconnect that wont allow the unit to power on while the cover is off.
Try taking the lamp cover off and bending the little piece of metal you find underneith.
It worked for me.
SOURCE: Can the Optoma EP739 be
Mine has been in place for about three years. Because the ceiling was open I was able to create a connection for a tripod head on the ceiling and then using a STRONG tripod head and some small bolts (longer than the originals) I mounted an external base and with the tripod head fitting dttached to the projector it just became a matter of running the various connector cables from the sources I use that require projection to my wall.
Posted on Jan 02, 2011
Projector not turning on
seems that the lamp is defective, pls test it
Have a good day! any question ,contact me,Please
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Feb 25, 2014 | Optoma EP739 Multimedia Projector
We have a optoma ep739 used at our local football club;but whenit gets warm it cuts out until it cools down;isthere any filters that need cleaning
take the lamp out, there is a fan directly looking to the lamp... clean it with a compressor. and after that at the menu of projector there is a place called 'High Altitude'. turn it on. And it'll be fine...
Mar 01, 2010 | Optoma EP739 Multimedia Projector
Program Optoma EP-739 remote to Bell Express Vue 3100 remote
1 - Hold the clear tv buttom until all 4 light flash red
2- Press the red tv buttom
3- Press the amount of time needed on the up cursor ( around select buttom) until your tv shut down
4-When the tv goes off press the search buttom ( at the end on the right side )
5-Press record
Then u can use the red tv buttom to control ur tv and u can control the volume on satelitte mode without going back to tv mode , if u press too much time while searching the code and the tv wont light back , do the same thing but instead pressing the up cursor press the down one to go back on the code it will be faster .
Feb 23, 2009 | Optoma EP739 Multimedia Projector
Optoma ep739 color was going greenish so i replced the bulb and now it seems to be getting no power at all? i tried several outlets and still no power, no flashing light, no led, nothing. Any suggestions?
These units have many safety interlocks. First make sure that all of the doors that you opened are replaced correctly. If not, the interlocks will prevent any power from getting to the unit. Update this with what you find.
Dan
Jan 29, 2009 | Optoma EP739 Multimedia Projector
Optoma EP739
It worked for me.
Nov 01, 2008 | Optoma EP739 Multimedia Projector
Projector has no power
Aug 27, 2008 | Optoma EzPro 739 Multimedia Projector
Powers off and lamp never comes on (new lamp tested in other ep739)
The lamp might be burn out or you do ot have the computer in the right plug and the right input slected.
Jul 23, 2008 | Optoma EP739 Multimedia Projector
Optoma EP739
i have the same projector with same problem. i called optoma direct and ordered a new color wheel. it was relatively easy and came in about a week. the phone no. is 408-383-3710
Feb 11, 2008 | Optoma EzPro 739 Multimedia Projector
Optoma EP739 Multimedia Projector Logo
122 people viewed this question
Top Optoma Office Equipment & Supplies Experts
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
