No Picture Hello I have a Mitsubishi model No. CT-33AC25L(A) and have lost the picture I still have sound but the picture just went black with a line through it. I am trying to fix it myself and have pulled the turn table and the back of. can you please help me. regards Rocky
    An expert who has answered 500 questions.
  • 556 Answers
Are you getting one bright horizontal line with sound.
if it is a case
then your problem is in vertical section
but remember to minimize brightness to avoid screen burn.
  • supply to vertical section
  • loose contact or print break in vertical output section.
  • any capacitor or low value resistor failure in vertical output section.
  • connector loose which is going to deflection coil.
  • vertical ic might be faulty.
  • hope this will help.
  • good luck
Posted on Oct 15, 2007
I have a Phillips FLATTV model ... Problem with the Philips Flat Panel Televisions I have a Phillips FLATTV model 42PFL7662D/ 05 I have no picture, the audio is OK, I have had a hissing noise for about 2...
Try with that...,g/PHILIPS-42PFL7932-LC420WU5-V2-CIRC.html
Sound but no picture.
Master or Slave inverter is defective.
It can be that the driver IC is defective or MOSF
inverter transformers, or 470uF 35V C
Replace driver IC BD9897FS or MOSFET's.
996500046243 IC BD9897FS
996500046242 Mosfet FDD8447L
996500046241 Zener KDZ100V
Oct 18, 2010 | Philips Televison & Video
Mitshubishi VS-6041 No picture, sound ok
It has been my experience with that model mitsubishi that the usual culprit is loss of vertical sweep. If the beams in the picture tubes stops moving up and down this is detected by the micro processor and the video is blanked, but the set is not shut down. The usual cause of loss of vertical sweep is bad solder connections on the deflection yokes or a failed vertical output IC.
May 27, 2009 | Mitsubishi VS-6041 60" Rear Projection...
No sound, or picture, just replaced lamp and it work for 2 min...
CPU(Central Processing Unit) I.C(Integrated Circuit) of your TV needs to be reprogrammed or come to worst needs to be replaced (if the CPU I.C. part number is available in electronics parts store) by a qualified electronics service technician... hope this help ;-)
May 24, 2009 | Mitsubishi Televison & Video
No picture on tv just blank screen
Sounds like you lost your High Voltage Power source which lights up your screen. If you don't know anything about TV's do not attempt to fix this problem. The High Voltage Power Supply is around 40,000 Volts!
Mar 26, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Model # WD-62525 lost picture
really hard fix. but its like 350 to send it off to the repair center in cali.
Mar 12, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I have Mitsubishi WD-62525. Last week I turned TV on and there was no picture, on green horizontal lines across the screen. The picture then went black and I only have sound. The lamp indicator lite turned...
that is a common problem with that model you will need the v26 power pwb repair kit and the V26 FMT pwb repair kit. You can get both kits at the following link which includes the replacement capacitors and instructions on where the capacitors are located. Heres the link.
Sep 26, 2008 | Mitsubishi Televison & Video
Sound no picture
Try resoldering the vertical output IC this is acommon problem with this model
Mar 20, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
217 people viewed this question
Top Televison & Video Experts
