I own a old TI-82 graphing calculaor and i was wondering where the +/- button was because i need to figureout an equation with a negitive in it and i cant find the button!!!!
    Sniper:
  • 69 Answers
Well, there are 2 ways, the easy way and the hard way, and I will give both.
EASY: the [+/-] button should be near the [ENTER] button
"HARD": type in "0" and then subtract the number that you want negatave and "FixYa!"
P.S. If this solved your problem please rate it as best answer.
Posted on May 12, 2009
  • 68 Answers
Pleas download the manual at
www.frontiernet.net/~bbusacke/DownLoads/TI 82 Manual.pdf
How do I graph an equation with TI 89?
Just open the Y= equation editor and enter your equation. Use X for T. Make sure the angle unit is in radians.
Nov 10, 2014 | Texas Instruments TI-89 Calculator
How to solve graphing equations
How can you graph equations (functions) if you do not have a graphing calculator?
Feb 12, 2014 | Texas Instruments TI-30XA Calculator
My TI-84 PLUS calculator wont show the graph after i type in an equation. please help!
You need to fix your graph so that it shows the correct y-axis and x-axis.
It works best if you press the zoom button and then scroll to find the ZoomFit option.
Then the graph should show up.
Jun 15, 2011 | Texas Instruments TI-84 Plus Calculator
How do I set up graph lines
in order to give the calculator a function to graph, you will want to enter the y= window by pressing the top left most button on the calculator. nintenman1.gif a menu similar to the one above will open, wherein you can enter an equation for the calculator to graph, such as (x^2-2). On the ti-83 itself, you can enter up to 9 equations to be graphed at once. after that, you may want to go to the window menu, where you can set the dimensions of the graphing plane in both the x row and y column. to view the graph, press the top right most button on the device.
hope that helps :)
Mar 29, 2011 | Texas Instruments TI-83 Plus Calculator
My TI-83 Plus calculator won't graph anything whatsoever. Did I need new software. Please help me.
First - Are you graphing within the proper window? Hit the zoom button and change it to zoom Standard within the graphing window.
Second - Are you inputting the equation correctly? Make sure you are inputting your equations in a y= format. If possible, please reply with a screenshot of your graph screen.
Feb 07, 2011 | Texas Instruments TI-83 Plus Calculator
Graphing
i had the same problem .... just go to apps and go all the way down transfrm and click it then click the uninstall button !!!
Apr 01, 2009 | Texas Instruments TI-84 Plus Calculator
How do you set up window range?
or press ZOOM, option 6 (ZStandard).  That instantly resets the window range.
Jan 20, 2009 | Texas Instruments TI-84 Plus Silver...
TI82 does not graph correctly
My best advice is to go to Window then Format menu and make sure your axes are on. Or press 2nd then up arrow and hold it untill it is visible (if you go too dark do the same thing just with the down arrow.
Jan 17, 2008 | Texas Instruments TI-82 Calculator
Graphing
The first solution will allow you to watch your calculator graph two equations simultaneously rather than finishing one before graphing the next; it won't solve the problem of having the calculator unselect one equation when you select a second. To fix that problem, try the following:
In order to select additional graphs, the Transformation Graphing App will need to be uninstalled from the TI-83 Plus Family and TI-84 Plus Family. Uninstalling the App does not erase it from the calculator, it disables it from interfering with the normal graphing modes. Below are the steps to successfully uninstall the App.
  • Press [APPS] key
  • Select Transfrm from the menu
  • Press 1:Uninstall
The illustration and solution are courtesy of Jesse Phillips, who cites this page from the Texas Instruments support site
- doug garfinkel, Children's Day School
Jan 15, 2008 | Texas Instruments TI-84 Plus Silver...
101 people viewed this question
jasbo
jasbo
