Panasonic Home theater system sa-ht700 came with the sb-wa340 (subwoof/speaker portal) that emits a Super loud (deafening) squeal ocaisionally. It will happen when watching TV or a DVD . It stops only by turning it off, and then back on. Sometimes, very soon after turning back on, it will happen again. It's the only problem with the system, but it's a biggy... Please Help!
    Brigadier General:
  • 8,619 Answers
Hi!
There are so many reasons of the issue you have described which are as under--
Custom Sound Memory – Store the sound settings: DVD-A] [DVD-V] [VCD] [CD]
Store the sound settings for a disc so the unit recalls them the next time you play it. Make the settings. Press and hold [C.S.M]. Discs recorded with 2-channel LPCM at 44.1 kHz or 48 kHz This feature gives you a more natural sound by adding the higher frequency signals not recorded on the disc.
[WMA] [MP3]: Discs recorded at 44.1 kHz or 48 kHz. This feature reproduces the frequencies lost during recording to give you a sound closer to the original.
Double Re-Master – Enjoying natural sound: During play press [DISPLAY] until the unit information screen is displayed then press <, > to select the audio menu. Then press <, > to select “Double Re-master”. Then press <, >
This doesn’t work if input is “DIGITAL IN”.
DR COMP – Dynamic range compression: Change this setting to listen to a source recorded with Dolby Digital when “DIGITAL IN” is selected as the source at low volume (such as late at night) and maintain audio clarity. This setting reduces the peak level in loud scenes without affecting the sound field. Press [SHIFT]i[DR COMP].
Each time you press the button:
STANDARD>MAX>OFF
STANDARD: The level recommended by the producer of the source for household viewing. MAX: The maximum allowable compression (recommended for night viewing). OFF: Source is played with the original dynamic range (factory setting).
Changing the delay time (Speaker Setting): (Dolby Digital, center and surround speakers only) For optimum listening with 5.1-channel sound, all the speakers, except for the subwoofer, should be the same distance from the seating position. If you have to place the center or surround speakers closer to the seating position, adjust the delay time to make up for the difference.
Press <, > to select the delay time box and press [ENTER]. Press <, > to adjust the delay time and press ENTER. Check the connections. ≥Turn the volume up. ≥Turn muting off.
≥Switch off the unit, determine and correct the cause, then switch the unit on.
The main causes include:
–Shorting (bare wires touching) of positive and negative speaker wires.
–Using speakers with an impedance lower than that rated for this unit.
–Straining of the speakers through excessive volume or power.
–Using the unit in a hot environment without proper ventilation
≥Adjust the position of the FM or AM antenna.
≥Use an outdoor antenna
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on May 12, 2009
How do I connect a new dvd reader with a Panasonic SB-WA340 active subwoofer?
Of the Phillips is not a home theatre system them you can but you will have no volume co trol of the sub. If it is the alot of philips home theater in a box (htib) use special plugs...you would need to change the cable end of the sub to a compatible plug.
Aug 23, 2016 | Panasonic Audio Players & Recorders
I have a Panasonic SB-WA340 Active Subwoofer, and need to know if this is compatible with other Panasonic home theater units?
It should be compatible with other Panasonic equipment that has an output for a powered subwoofer
Dec 25, 2012 | Audio Players & Recorders
I need remote code for panasonic sa ht700
Hello Fernado
I thinks that you are looking for a four digit universal remote setup codes with your Home Theater In a Box [HTIB]. If so try with this code.
0974
This is the only one four digit setup code for Panasonic.
OK.
Oct 10, 2011 | Bose Cinemate Digital Home Theater System...
How to connect the speakers to the sb-wa342 panasonic subwoofer
I hope I understand you correctly.
As you can probably tell from the very different connector types on the subwoofer and the HTS, they don't match up. That speaker system and this electronics are not meant to be used together.
The SC-BT200 uses passive subwoofer while the SB-WA342 is an active (powered) subwoofer.
http://www.retrevo.com/support/Panasonic-SC-BT200-Home-Theater-Systems-manual/id/23459dj389/t/2/
Jan 21, 2011 | Panasonic SC-BT200 Home Theater Systems....
How can I hook my alternate DvD player to SA-HT700 subwoofer without a cable ?
Without a cable? You probably can't unless wireless DVD is out.
http://www.retrevo.com/support/Panasonic-SA-HT700-Home-Theater-Systems-manual/id/312bh731/t/2/
If you want to use a wired DVD player, you would have to settle for just audio (analog stereo or optical digital) from it since this unit doesn't accept any video IN.
Jan 12, 2011 | Panasonic Audio Players & Recorders
Need to connect panasonic sb wa730 to panasonic sa dp1 system
There is a subwoofer outlet at the back of the sa dp1 connect via cable to the inlet on your sub then on your sa dp1 remote press shif and subwoofer at the same time
Feb 28, 2009 | Panasonic SC-HT730 System
Panasonic sa-ht700
same bro and its happening when there has no bass
Jul 29, 2008 | Panasonic Home Theater System System
My receiver for the Panasonic-SA-HT800V is toast
ebay? the speakers can only be used with this model..unless you strip the speaker wire...
May 06, 2008 | Panasonic sa-ht800V Home Theater Audio...
Subwoofer
is it just the sub you have or do you also have the dvd unit with it?
Feb 20, 2008 | Panasonic SC-HT690 System
126 people viewed this question
 Grubhead
Grubhead
