Question about Compaq tc4400 Tablet PC
MMC-SD Slot not working
Nothing happens when I put an SD chip in the slot, my old one used to make a noise and in my computer the info would come up, but with the new one, I just got, I get nothing, if it is turned off how do I check?
Help
  • jkpf May 11, 2010
    do you see a drive letter for the MMC-SD?
Sim card for Samsung Galaxy tablet 4?
A SIM card is for 4G LTE internet service, so if you have a Samsung Tab 4 ensure it is 4G capable before trying to insert a SIM card. If you try to insert a SIM card into a SD Card slot you may damage the card reader.
That being said, I believe it is located on the right side of the tablet. Sometimes the SD Card slot and the Sim card slot are right next to each other. Once you open the cover that reveals the slots there should be small icons for the SD Card and the Sim card. Normally, the SIM card slot will have a little notch on the icon. Attached are guides with pictures.
http://www.samsung.com/us/support/answer/ANS00030415
SIM card Samsung Galaxy Tab 4
Oct 22, 2016 | Samsung Tablets & eReaders
How do i get my micro sd card out of the slot on my asus memo pad, its stuck and i cant see it
The card reader slot is shorter than the memory card itself, so it sounds like you didn't put the SD card into the card reader but rather, into some other kind of slot. If you cannot see the card at all, try straightening a wire such as a large paperclip or something and try using a flashlight so you can see to try and fish the SD card out. If you can't do it, you will have to go to the local computer store for them to try for you.
Apr 26, 2015 | ASUS MeMO Pad HD 7
Says my sd card is unmounted or no files are on it. what happened to my files?
When you remove an SD card from its slot, you should *unmount* it first so you don't lose data. If you just pull it
out without first unmounting it, you could corrupt it and lose
data. This might have happened in your case or not. If you didn't remove it, try this.
Go to Settings>Storage>External SD, touch Unmount.
Then remove your SD card and using a Q-Tip and some
solvent like alcohol clean the copper contacts. Then slide it
back into the slot. The device should *Mount* it automatically.
If it still doesn't work, you could try hooking your device up to a computer via its USB cable and see if your computer can see any files on it. If it can't see any then somehow they could have gotten erased. Try loading them back. If they won't load and you get error messages, the SD card itself may have gone Kaput.
Apr 17, 2015 | PANDIGITAL Tablets & eReaders
Where does the SD card go on 9" ONIX tablet?
It has a micro sd card slot on the side its very thin slot.
Aug 20, 2014 | Tablets & eReaders
I inadvertently uninstall the sd card how do i put it back
turn it of , on the left side of the tablet should be the slot to re install it , put it in all the way till it stays in (it will lock ) then turn the tablet back on .it should find it on its own , if not you may have to re set the tablet with the SD card in it so it can re configure it .
Feb 25, 2014 | Coby Tablets & eReaders
Micro sd card in sim card slot removal
I just did the same thing. I didn't want to put anything metal in to the slot. After trying with various pieces of hard packaging plastic I put double sided sticky tape on a piece of plastic and slid it down into the slot. The sd card attached itself to the sticky tape and I was able to pull it out. Good luck
Jan 06, 2012 | ViewSonic ViewPad 7 Android Tablet
Hi Can anyone please tell me how to transfer music from my computer to my viewsonic viewpad 7. Many thanks
put micro sd card into usb with a usb micro sd holder a put music or photos onto it/put micro sd back into viewpad slot next to sim card slot /thats it.
Oct 01, 2011 | ViewSonic ViewPad 7 7Inch Android 22...
How do i load pictures from a sd card into computer
determine if your computer has a memory card slot for sd cards..
if memory card slot is not available use a "card reader" you can get that from walmart and on other stores
once memory card is connected.. it will appear on your
computer as a removable disk or device.. you can check that on "my computer" window for XP or "computer" window for vista..
you can explore the content of the memory card and get your files.. good luck!!
Sep 24, 2009 | Gateway CX200S Tablet PC
Nothing happens when I put in a 2gb SD chip
Check to make sure it isn't an SDHC card. Most older card readers aren't able to read the formatting of the newer cards. You may need to buy a new card reader with SDHC support.
Jun 08, 2009 | Compaq tc4400 Tablet PC
Compaq tc4400 Tablet PC Logo
965 people viewed this question
Top Compaq Tablets & eReaders Experts
Jerry Umali
Ann
Level 1 Expert
ray gallant
Are you a Compaq Tablet and eReader Expert? Answer questions, earn points and help others
