Question about Microwave Ovens
Frigidaire Micro FMT139 built in..Above a Frig Oven. Was part of the home when we moved in 1999...has worked fine. Yesterday AM, I used it to heat my coffee; by dinnertime, it stopped working. Only the timer works. Set a time, punch the button...nothing...just the light and the timer. Is there a part I can replace, or am I due for a new one?
  • mjkcomm May 12, 2009
    http://www.applianceaid.com/micro.html
    This link states the same problem I'm havinfg: the timer counts down, the light works, but no power. It indicates the likely cause is a faulty doo switch. this makes sense, since, for some time now, the door does not just 'pop out' when you press the open button; you have to pull it open.
    What is involved in replaceing the door switch?
  • 916 Answers
Make sure you hear the fan is still operating in your microwave. Next is to make sure the air intake grill on your microwave is not plugged up with air borne dust and dirt. Frigidaire Micro  FMT139 - nuker100.jpg Use an old tooth brush to help clean off the grille area.
Posted on May 13, 2009
    Brigadier General:
  • 3,917 Answers
I actually solved my own problem. It was never the microwave in the first place. Once I hit start, it lost power. It wasn't the fuse box, or the fuse in the micro. An electrial outlet on the same fuse box ended up blowing, so I had to look at the outlet behind the stove to realize it had burned up.
The reason why this could have burned is:
Probably due to a loose screw or clip connection where the wires connect to the outlet's terminals.
These must be tight, especially for high-current loads like microwave ovens.
Loose connections can lead to serious or dangerous overheating.
I would say the reason the microwave made it blow was that the microwave's outlet is probably fed by (daisy-chained with) the outlet that blew.
If so, this is not really a good idea.
A high-current load (microwave, freezer, fridge, etc.) should ideally be on its own breaker / fuse with no other items on the same power line.
For any further and future doubts you can always refer to the site:
Thank You
Posted on May 12, 2009
I changed the fuse on a Frigidare #FMT118EPB Microwave and it blew again. I checked the micro switches with a meter and they seem to work. What else could be causing the fuse to blow? Thanks.
If you put in the correct size of fuse then what it needs is to go to a qualified service tech. What would be next requires removing the covers and if you do not know what you are doing you will fry yourself.
Dec 06, 2014 | Frigidaire FMT118EPB Microwave Oven
My micro wave is not heating everything esle is working . it was working find yesterday it won't heat water today
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Oct 11, 2010 | Maytag MMV4205 Microwave Oven
Microwave will not turn on -- light does not come
Chances are good that you have a bad door switch.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
May 22, 2010 | Whirlpool RMC275PD Microwave Oven
Frigidaire FMT 148GP Microwave oven. Turntable
1. the motor to rotate the glass table in the micro wave may have stop working or the switch to the motor is defective.
Mar 13, 2010 | Frigidaire FMT148GP Microwave Oven
I have removed the mounting brackets from the top of the microwave but still cannot get it to tilt forward for removal. I do not see any levers as suggested in the Solution #1 above. Any other advice?
Did you remove the 3 screws from the top that hold it to the cabinet. Here is a install manual so you know what screws to remove. also make sure the ducting is removed all the wat to tilt micro.
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316495064.pdf
Good Luck
Nov 21, 2009 | Frigidaire FMT118EPB Microwave Oven
Handle on Frigidaire Microwave broken, probably because of heat from gas burner below - this is a defect becaquse the microwave oven was manufactured to be built-in above range. Frigidaire has finally...
im kinda confussed as to why Frig would do that,,,
but if you send the model number im sure we can help
most times repacing the door is really just a matter of lifting it off the pin hinges after you have removed the vent
but i can be more clear with the exact model
Oct 28, 2009 | Electrolux Microwave Ovens
Frigidaire micro plmv169dcd not working
test it with a meter it has a small wire inside and, sometimes can not be visually checked
May 28, 2009 | Frigidaire PLMV169DC Microwave Oven
Maytag above the stove microwave not working
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Apr 14, 2008 | Maytag MMV5165 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
