Question about Dell 1720dn Laser Printer
I replaced a toner cartridge, yet when I press the print keys, a window shows up that the toner level is low and it wont print. I have replaced the new toner, with another new toner cartridge, without any results. Any suggestions? I would appreciate it. Genaro Lara Tx.
  • Anonymous May 14, 2009
    I placed a new "refurbished" toner cartridge in the machine but it will not load. I have taken it in and out and turned the machine off and on but it is useless.. Its has the same reading as the previous cartridge as if is has never been changed. Before when I would place a new cartridge in it would pause and then say that it was loading new cartridge. I am almost out of ink, as far as the machine is concerned, and not sure how to fix it. Its a 1815dn. Please give me an idea of what i can do to make it load?? Desperate!
    Tracie Hicks
    OxyPro, Inc
  • Jerry Naidoo May 11, 2010
    Have you tried opening the software that came with printer and reset toner level or click on the icon to say you installed a new toner. Most software allow for you to inform them that you replaced the toner so it can reset it level and also to ask you if you put in a reconditoned / new toner.
    Problem Solver:
  • 19 Answers
Your printer did not detect your inserted cartridge.Try to check in the manufacturer's site if it is compatible to your printer.
Posted on May 13, 2009
How can tell if the ink level is low? hp 2420
Cartridge comes along with memory, the information of estimated ink/toner levels will stored in this memory(Depends upon the cartridge model yield will varies). When printer performs the printing, memory count will comes down, when its reaches the minimum count printer will display the message of "low ink/toner/remain pages" levels, once its reaches to '0', display will changes like "replace the cartridge"...But there is no electronic component or mechanism to measure the ink/toner levels in the cartridges.Only estimated levels only printer can recognizes.. Take usage page through menu, you will get the information that usage % & printed pages info,you can judge how much remain it can print...
Dec 06, 2011 | HP LaserJet 2420 Printer
Hp laserjet 4100 show message "Toner out". I can't print anything. Help me!!!
TONER OUT
The toner cartridge has run out of toner.
Depending on how the printer has been configured, it will either continue to print or stop.
Due to the resolution of the toner level sensor, it is possible that a small amount of toner (less than one percent) might still be present in the cartridge.
1. If the printer has stopped, you can resume printing by pressing GO for each job.
2. Replace the toner cartridge.
Jul 14, 2011 | HP LaserJet 4100 Printer
Does anyone know how to reset the toner levels in an HL3040, i have put new colour toners in and each is still showing empty
Hey, I've just figured this out myself. Here is the procedure:
1. Open the front cover that gives you access to the toners. 2. Press and hold "Secure Print" and "Cancel" at the same time. You will see "K-TNR-STD" display on the screen. 3. Using the "+" and "-" buttons select the toner you want to reset. 4. Press the "Ok" button. 5. It will display "Ok?" and hit the "Ok" button again to reset the toner. 6. Close the lid.
All done!
Regards, Michael Pasqualone TotalServe Solutions
Nov 01, 2010 | Brother HL3040CN Laser Printer
The printer is not working, toner is always showing low toner and not give the print.
hello try to do this
press menu#1934 and right arrow key disply show ready tech
press menu button and press left arrow key
display show new cartridge.press enter button twice. then restart your printer.error message didnt display
Aug 31, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Replaced black toner..now printer won't print any
In this case, actually it is not the Black toner that got depleted. Here the message being displayed indicate that one of the color Toner supply need to be replaced as it got depleted and currently the printer is printing in Black and white using the Black toner cartridge.
in this case, to troubleshoot these issues please try performing the following and check for the results.
* 1. Check for the level of the toner cartridges:
a) Check from the HP Toolbox application. Here are the steps to be performed from your PC:
* Access the Toolbox software.
* Select the Status tab.
* Select the Device status option.
Here you can check for the supplies status in terms of the % remaining for each toner cartridges.
b) By checking the supplies status from the printer control panel display.
On the printer display when printer is in Ready mode the supplies status can be checked from the supplies level indicator. Each toner cartridge and the Imaging drum level will be indicated by a bar which varies according to the level of the supplies present.
c) Print the supplies status page from the printer.
* On the printer control panel menu, press Menu .
* Use the (Right Arrow) button to select Reports, and then press Enter .
* Use the (Right Arrow) button to select Supplies Status, and then press Enter .
If any of the color toner cartridges and the Imaging drum have a low supply level replace them with genuine HP print cartridges.
The part numbers of the consumables are as follows:
* Black print cartridge - Q3960A
* Cyan print cartridge - Q3971A
* Magenta print cartridge - Q3973A
* Yellow print cartridge - Q3972A
* Imaging Drum - Q3964A
Sep 23, 2009 | HP LaserJet 2840 Printer
Had toner life end message. Replaced toner and drum with oem,machine reset but now just making blank copies. Tried to print internal report that's blank too
To reset the sensor after installing a new toner cartridge follow these steps.
1. With unit powered On, open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press 1,0 .
5. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
6. Close cover and see if Toner Life End error message has gone.
Please note that this must be done with a new cartridge so the unit will see that there is toner in the cartridge.
Aug 01, 2009 | Brother IntelliFax-2820 Laser Fax
Toner level
To check the toner level, there is a little clear window on each cartridge you can use for this purpose. Hold the cartridge vertically. If you see toner in the window, it is more than half full (or less than half empty, ha!). If not, slowly tilt the cartridge toward the side with the window. Essentially, how far you tilt it before you see toner determines how far below half full it is. If you pass a 45 degree angle before the toner appears in the window, it is nearing empty and must be replaced or refilled (yes, refilling is an option).
If you do have to replace or refill, don't forget to empty the waste toner bottle (responsibly, of course). By the time you run low on toner in one of your cartridges, the waste toner bottle will likely be nearing capacity.
Jun 19, 2009 | Konica Minolta Magicolor 2530 DL Laser...
False detection of toner low
The only remedy you have now is to change the sensor , for this you have to refer to the product manual you can download it from
http://www.brother.ca/en/products/pdf/QSG/HL2030-QSUG.pdf
Good Luck
Dec 05, 2007 | Brother HL-2030 Laser Printer
Black Toner replaced
Replace Toner with gen cartridge.
Or Take cartridge back as faulty after checking that it was opened and installed correctly.
Check display on printer for indications that maybe it needs one of the 3 colour toners indicators are Y,C or M
K is black
Oct 20, 2007 | Epson Aculaser C1100 Printer
Dell 1720dn Laser Printer Logo
148 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
