Question about Whirlpool ED5VHGXM Side by Side Refrigerator
Makes loud knocking noise under refrigerater side
1 Solution for "my whirlpool refrigerator makes a loud knocking noise about every 20 to 30 minutes how can i fix it
  • Anonymous Mar 15, 2014
    Lg fridge making loud knocking noise
    President:
  • 1,136 Answers
Hi, Does this noise accure when the compressor is shuting off?
Posted on May 12, 2009
Why does my whirlpool refrigerator makes a very loud clunk noise when it turns off
Try looking for any pipes that are rattling against the cabinet , if not, I'm afraid compressor problem.
May 02, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
KNOCKING NOISE WHIRLPOOL GD5RHAXNB00
ME TOO !!!!! THE COMPRESSOR RUBBER MOUNTING BUSHINGS ARE LIKELY WORN OR LOOSE. THE HARMONICS OF GAS PRESSURE "HAMMERING" ARE CAUSING IT TO SHAKE.
THIS IS WHAT I DID: UNPLUG THE FRIGE, AND REMOVED THE CARDBOARD PANEL ON BACK. THE COMPRESSOR IS A GALLON SIZED BLACK GLOBE SHAPED UNIT. IT HAS 4 RUBBER MOUNTING BUSHINGS/FEET. SHIFT OR WIGGLE THE COMPRESSOR AROUND SOME AND THEN TIGHTEN BUSHINGS WITH 7/16" (11 MM) WRENCH UNTIL IT GETS TIGHTER. YOU MIGHT NEED TO REPEAT UNTIL YOU FIND A QUIET/SWEET SPOT . WHILE YOU ARE DOWN THERE, ALSO REMOVE THE FRONT COVER AND CLEAN THE DUST OFF OF THE COILS WITH A VACUUM. WATCH OUT FOR SHARP METAL EDGES AND HOT COILS WHILE WORKING. .... DOUG
Feb 16, 2013 | Whirlpool ED5VHGXM Side by Side...
My whirlpool ED5FHEX all of a sudden sounds like a motor reving from below in the back. It gets pretty loud. Sometimes I unplug the refrigerator and wait several minutes before plugging it back in and the...
If the shock absorbers under the compressor are damaged or loose there can be a lot of different noises but I have never heard it referred to as a motor racing.
A motor racing sound would be more like a fan motor going berserk and not keeping a constant speed. Since the compressor fan is located in the area of the sound you might want to take a look at it and see if it is keeping a constant speed.
Aug 16, 2011 | Whirlpool ED5FHEXMQ Side by Side...
Knocking noise coming from bottom of refrigerator
check the compressor for operation adn check the fan in the back of unit to make sure it is running...whirlpool units are notorious for compressor relay failure normally they click in and out every few minutes... if it is a knocking noise and continuous make sure compressor is not trying to start and sitting there shaking... normally it will stop after a few minutes and then start again....
Jan 25, 2011 | Whirlpool GS6NBEXRS Side by Side...
Load knocking noise
these high efficiency compressors make noise when they are in defrost..you will sometimes hear water running, or tapping noise or even a popping noise. if it happens when its off in defrost.. it will only happen three or four times per day as this is the defrost frequency and nothing can be done without securing the heat exchanger to the suction line ..sometimes these come loose...
May 20, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Very loud noise whirling sound
Can you tell me where the sound is coming from? Like inside freezer or under refrigerator. Most sounds like you describe come from a fan motor and the fan blades are hitting something. Let me know, Thanks, Sea Breeze
Apr 23, 2009 | Whirlpool ED5FTGX Side by Side...
Knocking noise coming from Whirlpool Gold refrigerator
Mine does it too. I know what it is because I repair them for a living. That is the sound of ice expanding as the defrost heater comes on to melt the frost on the evaporator. The next ime you hear it make a note of the time. Every 8 to 10 hours it will go into defrost mode. The ice box will also quit working for 21 minutes.
Dec 02, 2008 | Whirlpool GD5SHAX Side by Side...
Whirpool Refrigerator Making Loud Noise
I have the same problem. 3 years old fridge. Under warranty?
Aug 08, 2008 | Whirlpool GC5SHEXNS Side by Side...
Whirlpool ED5VHGXM Side by Side Refrigerator Logo
1,977 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
