Question about Philips 19 in. CRT Monitor
Identifying which capacitors might need changing in a Philpips PHP-X19I have looked for swelling/distortion but they all look good to me, so are there a common capacitors that go, and if so which ones are they. Cheers Dave T
  • 1 more comment
  • dtstaffs May 12, 2009
    Philips PHP-X19, it is a LCD Monitor, I have read that it is a common fault on these monitors for "swollen capacitors"
    I have strip down the unit and looked at all of the capacitors, but they look pretty well normal to me.
    They original fault is that the monitor comes on for a few seconds and then goes off, if powered down and turned on again the same thing happens.
    Hope this info helps
    Dave T
  • dtstaffs May 13, 2009
    I am beginning to think that maybe I should have just put the monitor in the bin, I have very little knowledge about electronics. I was hoping that once I opened it up I would see obviously swollen capacitors, and just be able to replace them. When I searched the internet and found that it was a common problem with these screens, I was hoping that someone might have took photos or be able to tell me if there was a common capacitor that needed replacing.
    As the screen is only about 1 year old it just seems a shame to bin it.
    Thank you very much frankzjm for showing an interest in my problem, and taking time to try to help me, but I have not got a clue when you talk about supply filters/inverters and driver components etc.
    So I might just concede that this task is a little beyond me.
    Again many thanks
    Dave T
  • Frank Zhang
    Frank Zhang May 11, 2010
    Philpips PHP-X19I it is a LCD monitor or CRT?
    which capacitors ? where they are? which board? please
  • 191 Answers
Ok, you need to do
1) check all capasitors at power supply (filter) and inverter (there are some smaller capasitors, see is there any color or swelling (even very tiny). change them.
2) most common the inverter board problem with some driver components wrong. need check the condition
3) if the monitor use over 3 years that one of lamps could be overlife, it should be a sympton like this,
hope you fix it, any ask to me please
Posted on May 12, 2009
  • Frank Zhang
    Frank Zhang May 13, 2009
    is this help you? please keep in touch. please rating me thanks
My asus laptop always shutdown
The hardware that you are trying to access is damaged or failing.
Capacitor
Capacitors, sometimes also called condensers, are used to store energy in an electric field. In the context of computing, capacitors are used to block the direct current being circulated around the motherboard. A typical capacitor should last up to 15 years, but some computer manufacturers use substandard capacitors resulting in shorter lifetimes. Computer Problems b> When a capacitor has gone bad on a computer you may experience a large range of problems. The computer may have trouble booting up, or it may shut down without notice after running for only a short period of time. The most common problems associated with faulty capacitors are that they cause unexpected computer crashes and general reliability issues ranging from read/write issues to distorted screen images. b> Identifying a Bad Capacitor b> To identify a bad capacitor you will need to open your computer case and locate the capacitors on your motherboard. A bad capacitor may exhibit swelling at the top or the base of the capacitor or it may sit at an awkward angle with the motherboard, so compare the various capacitors in your computer in terms of and placement. Additionally, a bad capacitor may have a funny smell or it may have a brownish residue leaking from the top or the base. b> Prevention b> Manufacturers claim that capacitors may go bad because a computer is not receiving enough power from a power supply, because of an overclocked processor or because a computer is operating in an environment with too much heat or humidity. However, some capacitors prematurely fail due to faulty work on the part of the manufacturer. If you have a bad capacitor be sure to do research as to the lifespan of other products made by your manufacturer. Identifying bad capacitors http://www.youtube.com/watch?v=ngA4k32jLGc Capacitor replacement http://www.youtube.com/watch?v=s0Pn2tEjY04 How to check a capacitor http://www.youtube.com/watch?v=U4tnHA0phcc Replacing a leaking capacitor http://www.youtube.com/watch?v=s0Pn2tEjY04
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable
Test all power and data leads that attach to your hard drive SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty. Although it would be very rare for the sata lead to be faulty. Make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty Computers need power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Feb 05, 2013 | Computers & Internet
I cant boot my hard drive with my imicro sata to usb 2.0 external hard drive
Ahh the bluescreen of death
BSOD Bluescreen of death can be caused by a number of things
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards A bad or faulty motherboard data lead or its connection if its a flat 40 pin ide it will be the first to fail
make sure all leads have a dust free secure connections
A bad driver loose or faulty lead or not having enough ram or the RAM modules might be dirty. Might be getting hot Check you CPU make sure its securely seated and has thermal grease http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Then reseat the modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. You might not have enough RAM random access memory not having enough will cause your computer to run over its maximum limits and can cause the blue screen of death and hang and cause memory dumps
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always ask the seller if they guarantee the compatability of the ram before making any purchase
if you dont want to install more ram uninstall some unnecessary programs
make sure your ram modules have a dust free secure seating and the CPU central processing unit has thermal paste
When Computer Capacitors Are Bad b> Capacitors look like small metallic canisters and they are found in many different computer components including computer monitors, computer motherboards, video cards, power supplies and a variety of other consumer products. A bad capacitor can cause a variety of computer problems, but if you can identify the faulty capacitor you may be able to replace it and save your computer.
Capacitor
Capacitors, sometimes also called condensers, are used to store energy in an electric field. In the context of computing, capacitors are used to block the direct current being circulated around the motherboard. A typical capacitor should last up to 15 years, but some computer manufacturers use substandard capacitors resulting in shorter lifetimes. Computer Problems b> When a capacitor has gone bad on a computer you may experience a large range of problems. The computer may have trouble booting up, or it may shut down without notice after running for only a short period of time. The most common problems associated with faulty capacitors are that they cause unexpected computer crashes and general reliability issues ranging from read/write issues to distorted screen images. b> Identifying a Bad Capacitor b> To identify a bad capacitor you will need to open your computer case and locate the capacitors on your motherboard. A bad capacitor may exhibit swelling at the top or the base of the capacitor or it may sit at an awkward angle with the motherboard, so compare the various capacitors in your computer in terms of and placement. Additionally, a bad capacitor may have a funny smell or it may have a brownish residue leaking from the top or the base. b> Prevention b> Manufacturers claim that capacitors may go bad because a computer is not receiving enough power from a power supply, because of an overclocked processor or because a computer is operating in an environment with too much heat or humidity. However, some capacitors prematurely fail due to faulty work on the part of the manufacturer. If you have a bad capacitor be sure to do research as to the lifespan of other products made by your manufacturer. Identifying bad capacitors http://www.youtube.com/watch?v=ngA4k32jLGc Capacitor replacement http://www.youtube.com/watch?v=s0Pn2tEjY04 How to check a capacitor http://www.youtube.com/watch?v=U4tnHA0phcc Replacing a leaking capacitor http://www.youtube.com/watch?v=s0Pn2tEjY04 If eventually you can get a screen Click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver. If you computer came with a motherboard disk the drivers could be on it or you might have to download one. or it might be a virus right click in bottom toolbar select task manager applications to see what is running and processes to see what is ticking over. http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information malware protection http://100-downloads.com/download.php?p=615 windows xp microsoft security essentials http://100-downloads.com/download.php?p=614 windows 7 microsoft security essentials
Hope this helps.
Jan 25, 2013 | Imicro IM35SATABK 3.5" SATA-to-USB2.0...
Why does Dell Dimension 8300 restarts on it's own?
I would suspect the settings, always shut down using the start menu, shutdown. Open the Control Panel, Power Options, Advanced, change Hibernate, Uncheck, apply. Look over all settings select your options.
Dec 28, 2012 | Dell Dimension 8300 PC Desktop
LG RZ 20LA90standby light flashes from red to green
Hi, this description usually indicates power supply failure, you can verify this by checking the output voltage of power supply. Cause of the error can be electrolyte capacitors. You can identify them by swelling at the top of the condenser. If you have the technical ability? so there are a few more options for testing. In any case always possible to replace all power supply. Good luck! Let me know if everything worked out, or if you need further guidanc
Feb 28, 2011 | LG RZ-20LA70 20 in. LCD Television
I have the a Philips Ambilight TV too. The power supply has two capacitors that may be going bad. Check the pic here... My question is what are the number(values) and brand name of the those...
Don't know what you mean by picture here ( cant see it) but if capacitors look swelled ie domed , swelled in any way distorted , replace them, look out value , say 100uf , voltage , say 100v, and running temprature , say 105 c.
replace with exact part and make sure of polarity, the capacitor has a stripe on one side for negative connection
hope this helps
this job is not for a novice though
pete
Nov 11, 2010 | Televison & Video
Picture is distorted keeps on moving
Good Day,
You have problem with caps on the Hyper Board. This is how to repair it:
MVPU13 Hyper Module Repair (23786198 / 23148017X)
Corrective Action: Remove the MVUP13 Hyper Module from the TV chassis, remove
the top shield and replace all of the 10uf, 16v capacitors using Part Number 24619040 It’s recommended that all of the capacitors identified be replaced. (Note: These capacitors are low impedance surface mounted aluminum electrolytic capacitors. Care).
GOOD luck, big IRISH.
should be taken to avoid damaging the PCB while replacing these capacitors.
Dec 08, 2009 | Toshiba 42H81 42" Rear Projection...
Model ls-k2463hl runs as soon as power is turned on at circuit breaker fan speed goes up and down
you possibly have a motor that the windings are bad. These windings swell when power flows through them and in turn the swelling presses onto the shaft causing the problem. Also, I would replace the capacitor first in the event it is bad If the motor runs properly then that capacitor is the only problem. If it doesn't cure the fan problem then the motor is going out. If you change the motor the capacitor will also need to be changed anyway so try changing capacitor first. Good Luck hope I helped you some
Dave
Sep 07, 2009 | Heating & Cooling
Left channel of preamp does not work
If all connections are good, then a capacitor in the audio channel will need to be replaced. Look for any swelled capacitors or burn marks on board. You can use a capacitor tester or multimeter/ohmmeter to determine faulty capacitor
Aug 02, 2009 | Audio Players & Recorders
Avm 3259 picture problem
Vcc is on Pin 6 of the vert. output IC so you can trace that back to it's feed resistor (not sure the location number but you can find it easily by following the circuit trace). Depending on what your problem is you may need to replace some electrolytic capacitors as well. Follow pin 7(pump up) back to it's electrolytic cap. and look for swelling or bulging. Look for other bulged capacitors in the vertical section. You may also identify a bad resistor by a discolored look but not always, if in doubt meter it.
Let me know if you need some more info.
Oct 03, 2008 | Sanyo AVM-3259S TV
Condenser fan rotation
However, if it is the ORIGINAL motor, check the dual run capacitor for proper microferrad value. It may be that it is swelled up on top and that is a direct indication it is a fouled capacitor. If the top is not pregnant or swelled, and it still looks like the top of a soda pop can, you will need a microferrad meter.
Disconnect ALL power to the condensing unit. If in doubt, kill the power to home. Remove 1 wire from the capacitor, the brown one or the one that is marked "FAN" and set your meter to Mfd, measure with your leads the value between the COMMON and FAN terminals. They should be within 6% of the rating on the capacitor. There is no rule of thumb here, you must know the correct value and see if it is equal or within the 6%. If it is under the 6%, you will need to replace the DUAL RUN CAPACITOR. No question, because it is a dual run cap, it controls the Compressor also. Best to change the whole capacitor with that of equal value.
God Bless.
ACMAN66 (Erik)
May 27, 2008 | Goodman CKL24AR24 Air Conditioner
Computers & Internet Logo
493 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
