Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
No coffee I de-scaled it and ran 2 tanks of water through. Water comes out of the wand fine, but when I hit the brew button it grinds, but coffee grounds are not getting any water running through, and then the red light for the beans lights up. It disposed of the grounds OK, but the ground seem pretty dry. So, no coffee
  • william_fitz May 27, 2009
    I'll give that a try, thanks
  • bansheracer May 11, 2010
    What machine is this?
  • 1,089 Answers
Hi
Open the door and remove the grounds drawer and brew unit. Check the injector nozzel in the back of the machine and see if you have 2 orange o-rings. If you don't that is the problem. If you do, check that the gatevalve is opening. That is located between the 2 orange o-rings towards the bottom. Also check that the gatevalve has 90 degree legs. They should not be bent in. If they are you need to replace the gatevalve.
Posted on May 28, 2009
We had exactly the same problem. I called the repair shop that had done some repair and maintenance work on our Seaco Vienna superautomatica 3 months before. They had some suggestions which seemed to work:
The problem with the descaling is that the water with the descaling solution only gets flushed through the hot water wand but not through the outlet that leads to the brew group, so small mineral residue that get loosened can get stuck in there. After having the coffee machine turned on and heated up, I removed the brew group, which turns the coffee machine off automatically, so I have access to the water outlet (nozzle) in the back behind the brew group. It has 2 orange caskets and is of a beige color. A small lever on the beige part can be pushed upwards carefully with a fingernail or small screw driver. This releases some steam and pressure so if something is stuck in that outlet it might get flushed out. One can also try to gently insert a tooth pick at the end of the nozzle to loosen stuff. I repeated this procedure a few times after the machine heated up again.
So far it worked and it brews normal coffee again.
Posted on May 22, 2009
When my coffee starts to brew, the coffee (water) does not come down in a nice single stream. It is all spread out (kind of like water rolling off an umbrella) and some of it misses the cup. Also, alot of...
Sorry to read about your issue.
in addition to below take a pin and clean the little tube
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Jan 01, 2011 | Keurig B60 Coffee Maker
My Keurig B60 SE has recently started brewing k-cups very, very weak. I have a filter that I can put coffee in and that works fine, and I've even found that when I put the coffee from a kcup into the...
Sorry to read about your issue. plus you may have a bad k kups
Dec 22, 2010 | Keurig Special Edition B60 Coffee Maker
Does not brew coffee consistencty, water does not always flow from res tank...even if water flows down from tank the machine will make the heat noise show brew ready and when u push the button it either...
Dec 22, 2010 | Keurig B60 Coffee Maker
I'm only getting 1/2 cup of coffee each time I brew. I've changed the filter. What should be my next step?
Their is no filter on the b40 so i dont know what you mean about that.
you model may have one or two brew size 10oz and 8 oz take a kitchen measure cup and check it
Dec 21, 2010 | Keurig Elite B40 Coffee Maker
Sometimes it brews but most of the time it will not. It says ready but still will not brew. Help
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill your mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Dec 21, 2010 | Keurig B70 Coffee Maker
Keurig b40 won't brew. took reservoir off, refilled, only makes a humming sound. this is the quietest the b40 has been since i purchased it. tried holding down the buttons, unplugging and taking reservoir...
erwrwr33434
Dec 20, 2010 | Keurig Elite B40 Coffee Maker
THE MACHINE ONLY BREW 1/2 OF THE LIQUID.THE WINDOW READS/BREWING/BUT THE LIQUID STOPS.I GOT TO SHUT THE MACHINE OFF,THEN ON,TO GET ANOTHER 1/2 CUP,BUT SOMETIMES DOES WORK AT ALL.
Dec 19, 2010 | Keurig Platinum B70 Coffee Maker
It's blinking de-scale side water holder gets r4eally hot water is not coming out properlywhen u press one of the cup size bottons
This is the time, you need to Descale the machine. The simple procedure is :-
Unfortunately, in spite of the best-laid plans of mice and men, espresso machines often get clogged by scale, deposits of minerals from hard water. Scale can cause serious damage if untreated. If your espresso machine's water flow has decreased a lot, it's probably because of scale. Fortunately, there is an easy and inexpensive way to descale your espresso machine.
  1. Obtain some citric acid. You can either order this online or find it in the kosher foods section of the supermarket (usually marketed as "sour salt"). Acid solutions dissolve scale, which is made of calcium carbonate. There are special solutions marketed specifically for descaling, but citric acid works just as well and is much cheaper.
  2. Prepare the descaling solution by mixing citric acid with water (I use two tablespoons of acid and a quart of water).
  3. Put the descaling solution in the water tank, turn on the machine, and run water through the steam wand until the cup is filled, to expose the parts to the solution. Turn off the machine, and leave it for 20 minutes so that the solution has time to dissolve scale.
  4. After 20 minutes, run more water
  5. Run solution through the machine every 20 minutes, until the water tank is empty.
  6. Fill the water tank with plain water, and run water through the machine until output water no longer tastes sour. This is important, because excess citric acid does not make coffee taste good.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 12, 2009 | Keurig Coffee Makers & Espresso Machines
Water pump?
If you could brewer coffee or get hot water out of the steam wand then it could be the one way valve on the bottom of the water tank. If you are running the pump output into a glass then it is probably scaled up in the boiler.
Jan 02, 2009 | Saeco Magic De Luxe Espresso Machine
No coffee comes out from the coffe machine
The grind may be too fine. The Brew unit is plugged and needs service. The spout joining the boiler to the brew unit is broken. The unit may be plugged with scale.
Jul 24, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
233 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
