Question about Maximatic RO-1010X 1500 Watts Toaster Oven with Convection Cooking
Fan motor my oven has been packed away for 8 months. When I set it up to use, the fan does not run. I removed the back, plugged it up, watched as the fan tried to turn, made a quick grunt, but would not run. Unplugged, the fan turns freely by hand.
  • 790 Answers
Maybe you have stain in motor shaft! you can clean the motor by spraying of WD40. or maybe you have defective fuse thats connected to motor to source! or try to clean the rotary switch!
Posted on Oct 14, 2007
SOURCE:
How do I fix the Convection Fan not running/working
Make sure that the fan motor is being energized. If so, and it does not run then the fan needs to be replaced.
Apr 20, 2016 | Breville The Smart Oven Convection Toaster...
What ever setting I use Toaster, Pizza etc the oven runs for 3 minutes and stops and in the read out window E 1 comes on the screen
Unplug the unit for at least 30 seconds. Plug in, set clock. When making pizza punch in the time you wish it to run, such as "7:30" then "start". Watch carefully the first time to see how much time it takes to cook to your liking.
Sep 03, 2014 | Oster Digital Countertop Oven With...
Tension spring on door
I found the answer (see below) posted on another web site. I followed the instructions and replaced the spring. I found, as the original poster had, that the new spring works better than the original and is much more sturdy. To the original instructions, I would add the following:
1) There are about 20 screws so have patience removing and replacing the screws.
2) Step 3, "Slide off the rear panel" requires further clarification as the panel will not slide off even with all screws removed. I had to turn the oven over, with the top of the oven sitting on the work table. I then used a screw driver to lift the two tabs that hold the back panel to the bottom panel. With the tabs lifted, the back panel will rotate away from the oven along the edge where back panel slides into the top panel. The back panel can then be slid out. I have included three photos that show this step.
3) Step 7, "Re-attach feet": Be sure to use the guides on the bottom of the oven to slide the foot assembly onto the oven. I had unsuccessfully tried to screw the feet onto the oven without using the guides.
Oringinal instructions for replacing the broken spring:
Just repaired this yesterday.
Got a spring from Lowes (Hillman Part # 543028 for about $4), it's larger than the original but seems much sturdier, original is really thin metal. Fit the space provided without problem.
Oddly, end result was a more 'giving' spring action, prefer it to original, which loved to snap shut unless door was 100% opened (ie fully 90 degree open).
This is for BOV800XL:
1. Remove all rear screws
2. Remove feet entirely
3. Slide off rear panel
4. I was not able to remove top housing - but I was able to gently pry sides open just enough to thread the new spring with a little ingenuity and effort. Watch out for sharp metal edges everywhere.
5. Slide back in (remember that top edge goes under the top edge/lip)
6. Put all screws back in
7. Re-attach feet
7a505b80-f785-4973-b674-12594d9dcb1d.jpg 2e67ee3d-99c9-4e88-8b9f-8d1721e5caa6.jpg 529808f4-8d72-4aea-8286-b525347addee.jpg
Apr 02, 2014 | Breville BOV800XL 1800 Watts Toaster Oven...
How can I fix the fan in a Hamilton Beach 31197C oven which is vibrating. I can push on the end of the shaft and it stops vibrating. Ive tried WD40 on the winding to see if it's a lube problem, and it...
You really need to replace the fan. This motor uses cheap sleeve bearings and you will only cause a problem (maybe burn the house down) trying to spray lube from the interior which I assume is what you are doing.
This is not an easy repair. I replaced mine which had an open winding. HB tried to make this unit so it could NOT be repaired, but of course it can be if you want to spend the time. The motor is part of a metal duct assy which also holds the rotisserie motor. It is RIVETED to the interior wall of the oven. The fan uses a DUAL shaft C-Frame shaded pole 120 VAC ~ 3000 RPM ~ .5 amp motor which is not very common, with 2 separate axial type metal blade sets. The oven door also develops a problem over time that keeps it from staying closed. The thermo on all these units is also inaccurate as the "sensor" is simply a metal plate screwed to the top right area of the oven interior. When I replaced my fan I also put in a new REAL oven thermo with a 12" sensing bulb which I mounted inside the oven as it should be. It took some searching to find these two parts. You can also repair the door mechanism at the same time and give yourself a couple more years until you have to do it again. I have all more and can post images if you want to tackle this. I did because the oven is large and the replacement model (31100 for $69 at Wal-Mart) has 1.5" less height and it uses the SAME parts with the same design flaw for the thermo. The retail cost on the parts for this job are ~$160, but I got mine for $15 total. I paid $48 for this oven years ago at Sams.
Mar 12, 2011 | Hamilton Beach 31197 120 Watts Toaster...
Have T4800 Convection Oven. Need fan, motor and thermostat cannot locate parts.
If Farberware can't help then copy and paste this address. It will give you a list of sites that carry oven parts. Maybe one of them can help.
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
<a href="http://www.toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
Feb 16, 2011 | Farberware T490C 1500 Watts Toaster Oven...
Whirlpool fan assisted oven - fan motor coil burning out
The PCB board is definitely at fault here. One of the dc voltage lines is transferring too much current. The regulator and resistors are probably compromised. The better option is to replace the board than to try and fault find the components.
please rate my help++++Thanks for using FIXYA
Jun 23, 2010 | Toaster Ovens
Fan turns on and off during cooking
mine says the fan will turn on and off to keep the computer board cool... probably normal
Jul 31, 2009 | Toaster Ovens
Slow to heat Haier Convection Oven
you are correct . it is the convection . the fan blows the air around and away from the elements ,when that is happening the elements can never get hot enough to glow , as the oven gets hotter and at some point the air is so hot even with it blowing the elements will start to get red ... this is good because todays elements are thin and cheep and melt easy so the fan keeps the heat away from them and the elements last longer ...... if this answer helped please rate it a 3 or 4 stars .this high rate will help keep me in the paid answer department ... thank you
Apr 04, 2009 | Haier RTC1700 1700 Watts Toaster Oven with...
Farberware Convection Oven T490c does not turn on.
It is usually one of two items that could cause this problem. You need to take the outer shell off. Lots of screws. Pull the "brain board" from the right, front of the oven. There is a relay housing. This 30 amp. relay is made by Omron. Look at the connector pins on the back side of the relay, especially the white wire that goes to the distribution block then on to the heating coil. I find that the soldered pins on the pc board next to the relay often get so hot that they 'shed' the solder. If so, simply clean well and re-solder. The relay itself can also go bad. Unfortunately, I haven't been able to obtain replacements. What I did on one oven was to buy a 30 amp, open frame relay (~$20). Mount it on the chassis near the fan. Remove the Omron relay and simply run the appropriate wires to the open frame relay. That works very well.
Nov 28, 2008 | Farberware T490C 1500 Watts Toaster Oven...
Maximatic RO-1010X 1500 Watts Toaster Oven with Convection Cooking Logo
152 people viewed this question
Top Maximatic Toaster Ovens Experts
Marvin
Marvin
ray gallant
ray gallant
Kardoc
Are you a Maximatic Toaster Oven Expert? Answer questions, earn points and help others
