Question about CTX Optoma EzPro 610 Multimedia Projector
Optoma Projector Only Displays White Screen
I have a optoma projector ezpro 610h. When you turn it on it just displays all white and will not load up anything else. Any ideas??
  • blissbna May 12, 2009
    It doesn't even have a menu when you turn it on at first. Like normally it says lamp warming up or something along those lines before it even connects with a blue screen, but it isn't even displaying that. It isn't displaying anything from any of the inputs.
    Thanks for your help!!!
  • 68 Answers
Did u use your function key on your laptop?or did u configure your graphic card so that the output of your computer can be recognise by your projector?or do you try to use your contrast or brightness control at your projector?
Posted on May 12, 2009
I NEED TO FIND A BULB FOR THE ezpro-610
This is it (in the USA) http://www.myprojectorlamps.com/projector/Optoma/EzPro%20610.html
You mention CTX & Optoma. The link above is an Optoma lamp for the EZPro 610....also note there is a 610H
Feb 16, 2011 | CTX Optoma EzPro 610 Multimedia Projector
Optoma EP751, Just got a white boarder from top to bottom. Left.
try to reset.... or clean the board between av board and main board.
Oct 29, 2009 | Optoma EP751 EZPRO DIGITAL PROJECTOR...
Image upside down
I'm on this site because my projector is down after swithcing out the bulb or I could jot down the exact steps for you. It's a very easy fix. When you push the menu button on your projector to get into settings, there is one that will allow you to flip the image. Sorry I can't be of more help
May 15, 2009 | Optoma / CTX EzPro 610H / 615H Replacement...
Optoma 716
on the projector, restart your laptop/computer, this will detect automatically. if not then try display settings to 800x600.
Dec 13, 2008 | Optoma (BL-FU180A) Projector Lamp for...
Optoma EzPro 610H Multimedia Projector Display is all white
Your projector is LCD based. That is, basically, a tiny panel is a computer monitor with a lamp behind it to shine through the panel and lense, onto the screen. This all white screen means the pixels of the LCD are all "deactivated" allowing all the white light through. This happens on computer monitors from time to time. I cannot find a blind reset, meaning there's isn't a method of holding down a series of buttons to "reset" the projector.
aside from calling support, as their manual is useless, I would recommend powering the unit off and then unplugging all cables, including power.
Press and and hold the power buttons for 20 to 30 seconds to see if it clears up your issue. Sometimes, after unplugging the unit and pressing the power button on the projector will briefly light the panel lights and then they fade. This may be enough to drain enough power to force the projector to reset to normal conditions.
If if that doesn't work, I'd recommend leaving it unplugged for a day or so and try it again. Beyond that, the controller board for the display may have failed. It shouldn't be the case, but it is possible.
However, I feel the unit needs a simple reset, which normally you'd do though the menses, which obviously possible.
Apr 02, 2017 | Optoma EzPro 610H Multimedia Projector
How can I adjust my screen as of now one side is high and one is low,please help
Hi dave4455_uk
You will see two feet on the bottom of the Projector that can be adjusted for height purposes.
Thanks for using Fixya !
Apr 29, 2008 | CTX Optoma EzPro 610H Multimedia Projector
EZPRO 610H...has a red shadow
this is ghosting, caused by interferance. cheaper cables tend not to have metal sheathing and those ferrite RF suppression thingees on the ends, which prevents this problem.
also, avoid running your signal cables next to power cables. If your cables are long (say more than 10m) this may also cause problems.
Nov 22, 2007 | CTX Optoma EzPro 610H Multimedia Projector
Projector problem
it has a faulty rca jack provable. You are lucky you have the computer jack. You can get a little vga to rca adapter i think.
Oct 14, 2007 | CTX Optoma EzPro 610H Multimedia Projector
CTX Optoma EzPro 580
Hi, Optoma USA recommend that you set the PC resolution to SVGA (800 x 600) or XGA (1024 x 768). Your HP Pavilion ze 4900 default resolution is S = SXGA (1400 × 1050) or X = XGA (1024 × 768). I would assume that your cable(s) are properly mated/attached from the laptop to the projector. If on pressing TV Now! One-Touch button with a TV icon at the top of your keyboard to switch the display to the TV-Out mode, there is no picture projected, you can try to manually lower the screen resolution of your PC. Try lowering it to the 800 X 600 setting in your Display Properties. Also, you may want to check if the Dual Display Mode is enabled/activated. You can try different resolution setting as long as the projector can handle it. Hopes this works and give you an idea. Should you need more assistance, pls post/comment. Good luck and kind regards.
Aug 11, 2007 | CTX Optoma EzPro 580 Multimedia Projector
CTX Optoma EzPro 610 Multimedia Projector Logo
381 people viewed this question
Top CTX Office Equipment & Supplies Experts
k24674
Are you a CTX Office Equipment and Supply Expert? Answer questions, earn points and help others
