Question about Bunn Iced Tea Maker 3 Gallon Tall w Ready light TB3 29in
Bunn Tea Maker ~ flashing green light and not working
Doesn't come on at all now. I got it to work once after it broke, but the water that came out was cold, not hot. Flashes the green light 3 short times, then pause and repeats.
    President:
  • 1,618 Answers
Check the top of the brewer, there is a limit thermostat on the tank between the elements, disconnect and check resistance, if no reading replace. If you have a good reading, there may be another inline fuse on the line from the element to the ready light, disconnect and check resistance. If no reading replace, if you get a good reading, then the problem is with the pressure stat(box with the black knob for on off.
Posted on May 12, 2009
Coffee maker works fine but no green light telling me its ready. why the green light does not work ?
Probably just a LED burned out!. You can live with it but if possible, go to nearest authorized repair site to get it changed
Coffee maker works fine but no green light telling me its ready why the... Fixya com Customer Support Products Repair Manuals Troubleshooting on Any... Superstar Expert Achievement Badge Fixya Mister Danger Tablets eReaders PC Laptops Expert Fixya
Oct 05, 2015 | Bunn O-Matic 23001.0000 CW15-APS Airpot...
Water will not stop running when i turn on
Free tech support for Bunn Tea & Coffee Maker Infusion Series ITCB-DV 29
Feb 24, 2011 | Bunn Infusion ITCB DV Coffee Maker
Seems to be clogged.Is there anyway to flush or
Try putting white vinegar in it, and letting it soak. For more cleaning, you can recirculate the white vinegar back through the machine, but strain it through a coffee filter first to remove any sediment that you break free. Once you're satisfied with your cleaning, flush the tea maker with pots of fresh water, until no vinegar can be detected by taste or smell.
Best regards, --W/D--
Aug 04, 2009 | Bunn Iced Tea Maker 3 Gallon Tall w Ready...
No power
Check the top of the tank, there may be 2 thermostats, one that sits on the tank and the other is in line with the element. One of those are not working.
Mar 24, 2009 | Bunn Iced Tea Maker 3 Gallon Tall w Ready...
My bunn coffee maker leaks water out the coffee maker.
You need to replace the washer kit inside the top of the maker. Remove the 3 screws that fasten the top and lift it off. You will see the rocker leaver that allows the water to flow into the tank. At the point where the rocker stops the water there is a series of washers that degrade from the heat over time and allows the leak. The washers are very easy to replace. The problem is finding the washer kit. I found it at: www.buyitnow64.com for $3.95 plus shipping (FedEx is only $9.98). I bought 2 (one for backup) kits.The original washers lasted almost 6 years. I had repaired this problem before with a washer from my shop but it broke down rather quickly from the direct heat from the tank. This washer kit is a Bunn washer kit that is supposed to fit all Bunn machines both residential and commercial.
Hope this helps. It took me 2 hours on line to find the washers!
Aug 11, 2008 | Bunn BT10B Coffee Maker
All lights flash
Try cleaning the light sensor that reads the barcode on the disk. If it is dirty, some of the discs won't work. Also, try holding the water canister down with your hand while the coffee is brewing. If the canister vibrates, the lights may blink.
Feb 09, 2008 | Braun Tassimo Espresso Machine/Coffee...
Bunn coffee maker not working
My warm indicator light is not working. Only used less than a month.
Nov 15, 2007 | Bunn NHB Coffee Maker
Bunn pod coffee tea brewer
Visit the Bunn website on the following link: http://bunn.com/retail/service/faq.html You can download manuals, read the FAQ & get telephone support from them. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 25, 2007 | Bunn BREWER POD COFFEETEA
Kitchen Appliances - Others Logo
740 people viewed this question
Top Bunn Kitchen Appliances - Others Experts
jasbo
jasbo
Jerry Greenberg
Jerry Greenberg
Steve
Are you a Bunn Kitchen Appliances - Other Expert? Answer questions, earn points and help others
