Question about Vizio VW32L 32 in. LCD HDTV
How to use earphones but not using optical outlet?
What amp is needed for use of earphones?
  • 4 Answers
Any amp that has an optical imput and a headphone jack output.
Posted on May 12, 2009
A model TC-P42x60 and I need to use earphones. I have tried the audio outlets using a rca cord with a 3.5mm plugged into a set of earphones, that does not work.
There are no audio outs on your TV The digital audio out is an optical output meant for a sound bar or a stereo audio amplifier that has an optical input. If you have a compatible stereo system you can use an optic cable to connect the two and then use the headphone jack on the stereo system.
Aug 05, 2017 | RCA Audio Players & Recorders
My sound bar hooked up directly to my tv has no sound
You may have to go into the Bravia setup procedure and opt to disable its internal speakers
Nov 17, 2012 | Boston Acoustics TVEEM25 TVee Model 25...
Want to connect pc speakers and subwoofer to lg37lc55 tv unfortunaly it doesnt have an earphone 3.5 connection point. My other smaller tv does, the speakers and subwoofer consist of a white and red audio...
Your TV should have an AUDIO OUTPUT other than optic..at least " Headphones" output..
You can connect TV audio output with a RCA cable.
white and red audio jack....
since SUB has both RCA and "3,5mm Headphone female Jack"..here are the options;
** you need to buy a cable one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
** or 2x RCA
white and red audio jack and connect from your TV..
**" "Headphones" output to SUB with 3,5 male-to-male cable ( the least recommended)
And you need to connect front,centre and rear speakers to your SUB as well...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
May 19, 2011 | LG 42LH40 LCD TV
Speakers are ok but headphone is not working
OK. Speaker works/headphones don't! Sultanrajia, what is refering to! Audio Amp, play-back record, computer, radio, TV, all communication equipment. what. It could be broken wire on the headphone jack plug or it could the headphone aren't working. Maybe some bad wire in the headphone cable, faulty plugs.
By the way, do have a Night Visison optic devise that it can take a look into the night. Also, how does the spearkers and headphone work with the Night Vision Optics? stewbison
Apr 08, 2011 | Optics
New Bounty Hunter Discovery 3300 Metal Detector No external sound
Most earphone jacks have two functions. One, to provide signal to a set of earphones or headphones. Two, to DISCONNECT the path that would be amplified and sent to loudspeakers. If that particular contact on the jack is bent or broken, when you UNPLUG the male jack, the connection is NOT re-established!
Apr 22, 2017 | Bounty Hunter Land Star Metal Detector
No sound from laptop
The simple damage your laptop and here is you can not move but the socket earphone / headset of your laptop,the opening of outlets are you have seen lock switch is you just poke a gently using the little things like the end of ball pen.good luck and hopefully helped revenue
Dec 12, 2009 | Compaq Presario Notebook
Sharp Aquos LC-32GH5 and MacBook problem, HELP! I've recently bought a 32" Aquos and want to use it with my MacBook as a secondary monitor and screen for movies, etc... I bought all...
it sound like you did the right thing . The problem is the mac output for sound is bad or the TV input sound is bad.
try input a mp3 radio to the TV verify TV is working.
put an earphone to the mac to verify the mac out sound is working .
if both are working just tool around a little and you will get it. good luck
Aug 18, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Samsung G600
you need to go to options while you are listening to music & then select "earphone on"
May 24, 2009 | Samsung SGH-E900 Cellular Phone
I have an LG plasma TV.The only audio out is by optical toslink. I bought an LG home cinema system thinking I would be able to get analog audio out via a scart adapter but nothing doing. This is so my...
ok so you already established the optical connection from your TV to the hometheater system right? then follow these steps:
*first get look for any PRE-OUT terminal at the back of the amplifier
*get two rca cables (red and white to be color coded) and stick it to the PRE-OUT terminals of the amp.
*then get an adapter that will allow you to connect the headphones to the other end of the RCA cables (i think its available at radio shack).
*make sure that your headphones have volume adjusters. because the volume level on the PRE-OUT is fixed and cannot be adjusted using the amp. the only way to adjust it is by adjusting the volume level on the headphones. ü
after this you should be good to go...TC!
Feb 23, 2009 | Audio Players & Recorders
Vizio VW32L 32 in. LCD HDTV Logo
110 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
