Question about Averatec 3200 Notebook
Power light on, fan on but no function
Laptop dropped and stopped working.  Was told that it could be the motherboard.  The power light and fan will come on but the computer will not boot up or operate.
  • 2 more comments
  • lsmith470 May 12, 2009
    any good dyi links that I may be able to check the ram and/or replace the motherboard?  Saw some online but not sure which one is needed.
    When I take out the battery and leave it plugged in the unit the green light goes off and it shuts down.
    When I attempted to use a remote monitor I didn't get anything.
  • Serbob May 11, 2010
    Could be many things, but most likely your motherboard.
    President:
  • 987 Answers
First check the RAM if its ok then your motherboard needs to be replaced..
Posted on May 12, 2009
Sony vaio pcg5kfp
All Sony notebooks come with a built-in fan that keeps the hardware components in the laptop from overheating.
When the fan on your Sony notebook does not spin, your motherboard or other key hardware components may become permanently damaged.
If your Sony notebook fan is not spinning, it is important to resolve the issue as soon as possible to avoid further problems.
By going through each of the most likely causes for this problem, you can determine how to get the fan in your Sony notebook working again.Clogged Fan
A Sony notebook computer has vents on the bottom that enable air to flow in and out of the laptop's fan.
Occasionally, dust and other particles may get into the fan through this vent, which can cause the fan to become clogged.
When the fan is clogged, the fan may either spin slower than normal or stop spinning altogether. You can usually fix a clogged fan on your Sony notebook by using a can of compressed air to blow the dust out.
Consult your Sony notebook's user guide to determine how to safely access the fan for cleaning. Disconnected Fan
The fan on the Sony notebook is connected through a wire to the power supply on the laptop. Although this wire is firmly connected from the fan to the supply, it may become disconnected if the Sony notebook is dropped.
When the fan's wire is disconnected, the fan will not spin because it is unable to draw the power it needs to function properly.
You can check whether or not the wire is connected by following the directions listed in your Sony notebook's user guide to take apart the computer.
Defective Fan Your Sony notebook's fan may not spin because the fan is defective.
The fan may become damaged if the notebook itself is damaged in some way.
Occasionally the fan may be defective due to a manufacturing error, as is often the case with the VGN-CS and VGN-BZ Sony notebooks: these notebooks have an extended warranty due to faulty fans.
You can have your fan replaced by Sony for free if the notebook is still under warranty. Otherwise, you may need to pay to have the defective fan replaced.
Other Problems
If the fan is clean, fully functioning and connected correctly to the notebook's power supply, your Sony notebook's fan may not spin due to a defective power supply that prevents the fan from receiving the power that it needs to function.
Alternatively, your fan's wire may be frayed or otherwise damaged, which can cause the fan not to spin.
In either case, you must repair the faulty component in order to restore full functionality to the Sony notebook's fan.
Nov 21, 2013 | Computers & Internet
My Dell Inspiron 1546 Laptop will not turn on. When the power button is pressed, the front white light comes on for ten seconds, then it switches off. Same reaction on battery or AC. When AC is plugge
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive power and data cables IDE SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty
computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical or fan lead can cause you problems
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat
Thermal compound is a sticky paste that is placed directly onto the CPU.
Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink.
hope this helps
Jul 15, 2012 | Intel Dell Inspiron 1545/1546 Laptop--oem...
After turning on it turns off automatically after 3-4 seconds
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Jun 07, 2012 | Computers & Internet
Pre-bios failure
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button. And if that's true maybe you was operating off the battery the last time you had it on and since the power cord is bad, it was not charging the battery so the battery is drained and the power cord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove the Battery, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in (leave the battery out) and hit the power button to see if it boots. If it does, you can put the battery back in and let it charge.
If it is a laptop Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Remove the Power Cord, (If Desktop Open the Case0 If Laptop Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop)) and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
May 23, 2012 | Dell Motherboard for Dimension 3000...
Acer aspire 2920 power light on fan spins then stops and wont boot
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 23, 2012 | Computers & Internet
Packard Bell L4 just the HD lamp lights and Power Light.No activity at all though.
I'am afraid this is very bad news, the motherboard is far to gone to rescue, but lets try something, remove main battery and the power supply from the laptop, press and hold power for 2 minutes, at the end of that time put everything back in place and power up. If this fails motherboard only option.
May 03, 2012 | Packard Bell Computers & Internet
Hi i have an r630 desktop and it did work but now i have no power to motherboard no fans cpu but i do have power to the hard drives and rom replaced power supply same problem
Maybe your motherboard is toast.
Mar 30, 2012 | Computers & Internet
My laptop shuts off after i turn it on.why
Does your laptop even begin the boot process where it displays stuff on the screen? Do you hear fans running, disk drives running, see lights, hear the cd drive click once and notice a light that comes on the cd drive door briefly when you press the power button? If not you computer either has a bad power cord, a bad dc power jack where the power cord plugs in, a bad mother board or static build up. 1) lets eliminate static buildup by removing the power cord and the battery then press and hold the power button for 30 seconds. Then replace the power cord but not the battery and hit the power button. If it boots up you had static build up. 2) Take an ink pen and put in in the slot where the power cord plugs into the laptop, if it wiggles loosely then your dc power jack which is soldered onto the motherboard needs to be replaced. 3) If the power jack is tight and when you plug in the power cord if you don't see any lights or hear a fan, disc, cd drive, then you can almost bet your power cord is bad. 4) If the power cord is ok then you have a mother board issue. Normally motherboards will give some beeps or constantly blinking lights when you plug in the power cord and try to boot up. These beeps or blinking lights will tell the technician what is wrong with your computer.
Mar 19, 2012 | Acer Aspire One Netbook 8.9" Notebook
Toshiba Satellite L450 black screen on startup no fune sound
OK, you get the yellow light which I assume happens when you plug in the power cord even though you have not pressed the Power Button. So, when you pressed the Power Button, did you see any other lights flashing such as the disk drive light? Did you hear the Fan running and the Disk Drive running? Did you hear the DvD/CD drive click once or the light on the DvD/CD drive door flash? If you did see the aforementioned that means your system is trying to boot and might in fact completed the boot process but the Video is not displaying. If it seems like the computer is running by no video is displaying try shinning a flashlight on the screen to see if you can faintly see the icons or something on the screen. If so that means your LCD Inverter is probably bad and needs to be replaced. You could attach an external monitor to the laptop then press and hold the FN (Function Key) + the (F1 thru F12) key that corresponds to displaying on an external monitor. If the video shows on the external monitor then surely you have an issue with the Laptop's screen. If the laptop is not running and you hear no fans, no disk drive running and saw no lights then you probably have a motherboard issue. Get a quote from your local repair shops, then try the guys at: http://www.generalsystemsconsulting.com. They will repair it and ship it back by Fedex or UPS and most times their prices will beat any quote you find including shipping.
Mar 14, 2012 | Computers & Internet
Power light is on. Will not boot up.
Sounds like a back light problem.
Oct 24, 2009 | Computers & Internet
Averatec 3200 Notebook Logo
83 people viewed this question
Top Averatec Computers & Internet Experts
k24674
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
