Question about TMC - 4-line Speakerphone
Siemens 420 phones on DHCP randomly reboot
Phones on different networks, different Stimis, and poe/or pwr brick randomly reboot-hypath 4000
Does Huawei S5700 Series PoE switch support Huawei PDC-650WA-BE DC power supply?
Huawei S5700-28P-PWR-LI only can be equipped with AC 110V-220V power supply.Only Huawei S5720-28X-PWR-SI, S5720-52X-PWR-SI, S5720-36C-PWR-EI, S5720-56C-PWR-EI can support Huawei PDC-650WA-BE (650W DC PoE module)
Mar 08, 2018 | Huawei Computers & Internet
Will the PoE Function of S2700/S3700/S5700 PoE Switches Be Affected When a 110 V Power Source Is Used?
When using Huawei power supply units, Huawei fixed switches supports 110 V AC input power. The power consumption of most powered devices (PDs) is 4 W to 5 W; therefore, 250 W and 500 W power supply units can provide sufficient PoE power for PDs.
NOTE:
All fixed PoE switches except the S2700-9TP-PWR-EI, S2750-20TP-PWR-EI-AC, S2750-28TP-PWR-EI-AC, S2751-28TP-PWR-EI-AC, S5700-10P-PWR-LI-AC, S5700-28P-PWR-LI-AC, S5700-28TP-PWR-LI-AC, S5700S-28P-PWR-LI-AC, S5701-28TP-PWR-LI-AC, S5700-52P-PWR-LI-AC, S5700-28X-PWR-LI-AC, and S5700-52X-PWR-LI-AC support double PoE power supply units.
Jan 10, 2017 | Computers & Internet
How can I get a second hand Mitel 5215 to accept an IP address?
Your phone needs an IP address in order to communicate. Normally, it asks a "host" for that IP. You need to be connected to the internet for it to connect to the normal host, and your router should be willing to give it that IP address. "DHCP" is how devices ask for and get an IP address.
May 11, 2015 | Mitel 5215 IP Phone
I was wondering if the PWR-2911-POE and PWR-2911-AC can be installed in same 2911 router? Thanks.
No, both of them are power supplies. PWR-2911-AC is the standard power supply but the PWR-2911-POE is a bigger power supply to power up EHWIC or single/double-width line cards. Moreover, there is no physical way to put two same/different power supplies into a 2900 router. But 3800/3900 routers can support dual power supplies. Cisco 2900 Router Price Buy Cisco ISR 2900 Series Routers 3Anetwork com
Apr 03, 2015 | Cisco Computers & Internet
1120e phones keep rebooting
The phone's configuration is likely corrupt and it will need to be reset to factory defaults and reprogrammed.
To stop the reboot cycle, try this:
- Connect the phone to POE (Power Over Ethernet) injector, but do not plug in a data cable into the injector.
- When the message "Cable Unplugged" appears on the screen, connect a data cable to the POE injector.
The phone should return to an online state.
Aug 14, 2013 | Nortel 1120E
How can I activate PoE port on avaya2526T switch?
Try this: http://www.retrevo.com/support/Nortel-2526T-PWR-Switches-manual/id/8084dj990/t/2/
Jun 18, 2011 | Nortel 2526T-PWR Ethernet Routing Switch...
How do I unlock my Siemens gigaset 4000?
To unlock Siemens model mobiles,
you may try this site http://www.theunlockarena.com/siemens/rs13wp8/
It has the best instructions and easy methods for unlocking siemens mobile phones!!!!
Dec 18, 2009 | Siemens Gigaset 4000 Phone
Hello, my cisco ip phone does not start
Confirm if the Phone has power supply. and If it's connected to a POE switch confirm that it connects to the Switch port on the phone.
Oct 14, 2009 | Cisco Computers & Internet
3 vlans, data,1; data 2,;voip,5. Ports carry voice tagged, and data. currently Windows 2000 DHCP server lives on Vlan 1 (AND WORKS). Need to upgrade. When we test the new servers we are unable to make both...
Here's what you need to do:
First, be sure to assign an ip address(in the proper subnet) to each VLAN.
Second, use the ip helper-address command in the context of each VLAN, the address used should be the address of the DHCP server
Third, Add a scope for each additional VLAN on the DHCP server.
The switch will route the DHCP request to the proper server based on the ip helper-address command parameter and based on the ip address of the VLAN that is passed tot he server, a DHCP address in the proper subnet is automatically configured.
Here is a sample:
ProCurve Switch 3500yl-24G-PWR# configure
ProCurve Switch 3500yl-24G-PWR(config)# vlan 33
ProCurve Switch 3500yl-24G-PWR (vlan-33)#ip address 192.168.33.254/24
ProCurve Switch 3500yl-24G-PWR (vlan-33)# ip helper-address 10.1.2.250
Aug 06, 2009 | HP ProCurve 4104gl Networking Switch
Lands Phones Logo
Top TMC Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a TMC Lands Phone Expert? Answer questions, earn points and help others
