Question about Troy Garden
Can not pull cord to start mower - Troy Garden
  • 13 Answers
Right off the top of my head I would ask if you have the safety on the handle engaged so that the brake hitting the flywheel is released. If you're engaging it and the rope still does not pull, the spring in the recoil could be bound. This is relatively easy to fix but need to know a little more to know how to help.
Posted on May 13, 2009
My Toro mower won't start. The cord will not allow me to pull it out all the way. It seems to be caught on something.
Disassemble the starting mechanism and remove the snag in the line that is preventing you from pulling cord all the way out. Till you do that, you will be pounding salt.
Nov 01, 2015 | Toro Garden
Repair lawn mower pull cord
Home Depot sells a replacement pull cord kit that has great instructions. My mower, however, had pop rivets holding the cover on the engine, so if yours does too, get a pop rivet tool with the correct size pop rivets before you start drilling out the old pop rivets.
Aug 07, 2014 | Mtd 22" Yard Machine Push Mower
I have a Troy-Bilt Briggs and Stratton 675 series lawn mower. The pull cord is stuck and will not move. I can lightly pull the cord repeatedly and the cord slowly allows me to pull more but if I release it...
Take the plug out and try to move the blade. If the motor won't rotate, the problem might be with the motor and the cord can't move because of it.
Gary
May 19, 2011 | Garden
When yanking on the pull cord to start engine
Im guessing that you have started it before, so I guess , check that its not flooding ,pull air filter out see If you can see heaps of fuel in the bottom hole ,if you do take spark plug out pull cord a few times without holding start cable or you will catch on fire replace spark plug try starting ,no start still flooding take it to a lawn mower place ,float may have a hole in it , if not flooding, on the bottom of the cardy one brass nut , four holes find them clear then, start also a brass pipe going into the center of the carby is probable blocked
Jun 18, 2010 | Mtd 22" Yard Machine Push Mower
My riding mower will start by pull cord but not from ignition
Jump the solinoid with a screw driver, it the engine starts, replace the solenoid.
Apr 23, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Yard Machine won't start
Maybe the Spring is broken in the housing, that is assuming you are talking about a problem with the pull cord. Your question is kinda vaque. Submit more information !
Sep 13, 2009 | Mtd 22" Yard Machine Push Mower
Starting issues. Can't pull cord.
Make sure your flywheel brake is not engaged or the cover is hindering the mechanism somehow after it is installed
May 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Problem with mower string
The metal clamp on the cord is, to prevent the cord from going all the way in should it break. There should be a place on the handle of the mower for the cord to go through instead of having to pull from the mower you can pull the rope from the handle
Apr 25, 2009 | Garden
Pull cord on Sears 4.5 mower binds up
check, or have someone check the flywheel key, it is probably sheared off.
Apr 20, 2009 | Craftsman Garden
Troy Bilt Lawn Mower pull Cord broken
there should be four bolts holding the cover on that houses the pull cord assembly take the bolts out look inside you should see the rest of the broken cord at the other end there is a spool that the cord rolls up in to pull the cord until it stops the other end of the cord is a not in the cord pull on the knot the broken peice should come out turn the spool 2 times in the direction that is against the pressre while holding the spool in place feed the new cord in through the whole that you pulled the broken cord out of then tie the cord in a knot wind the rest of the cord up then feed the other end of the cord through the new pull handle tie the cord in a knot put the housing back on
Mar 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
265 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
