Question about Car Audio & Video
I have a 2600 watt Power Acoustik Gothic Amplifier and two 12 inch MTX 7500 superwoofers. When I go to hook up both the subwoofers, it seems like the subs won't work as well, but when I only hook up one sub, it works just fine. I have no clue what to do. I have 4 AWG wiring. Someone told me it might be because the wiring isn't big enough, but I have no clue and I am getting so annoyed. Help please!
  • 82 Answers
Look at the speakers, is one jumping out and the other drawing in? If so try this. Hook one speaker up normally, reverse the polarity on th other. Hook it opposite how you hooked the other up. This won't hurt a thing but it may cure the problem. Sometimes the amps get wired up backwards inside. I know for a fact that fosgate does cause mine was.
Posted on May 12, 2009
Can i hook up My 500w Power Acoustik subwoofer to my entertainment center
yes, but you will need a significant 12 volt power inverter to support 500 watts
Feb 19, 2016 | Power Acoustik Car Audio & Video
How do i fix a frozen 12 inch power acoustik FUBAR-12W sub
You have a case of a blown sub. You will need a recone kit. You ca send it in to a company like fix my speaker or google recone kits for Power Acoustik FUBAR. May be cheaper just to get another sub.
Oct 20, 2012 | Power Acoustik FUBAR-12W Car Subwoofer
How to install a power acoustik 30th anniversary version series 4 channel 1200 watt amplifier
Power to battery. Ground to something in trunk. Remote to blue lead on radio. Rca to line or sub out on radio.
Sep 14, 2017 | Power Acoustik Car Audio & Video
Need sitting for my amp so it will work with out the protection coming on the amp is a power acoustik gothic series mosfet,bridgeable,crossover,HPF,LPF bass EQ, 2ohms stable, ov2-2600 it was made in china...
Most fan cooled amplifiers would be fine on its side provided the flow of air is not impeded. Unless it's been modified the probability of a wire falling into the blades is pretty small. Where you may want to be concerned is if it's a convection cooled amplifier which would depend heat rising away from heat producing components and their heat sinks. Placing this type of amp on its side could reduce the efficiency of its cooling capabilities possibly causing it to thermally shut down and/or shorten its lifespan.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Sep 28, 2010 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
I have 2 15 inch mofos do i need two poweracoustik 4000D AMPS?
You want an amplifier that is rated for the subwoofers. In your case your subwoofers are rated at 1500 watts rms each, so you will need an amplifier of 1500 watts rms or more for one subwoofer. good luck
Dec 26, 2009 | Power Acoustik MOFO-15 Car Subwoofer
Power acoustik gothic OV2 800 manual
Could not get a manual for you but did get the follwing specs. Hope they help.
Power Acoustik Ov2-800 2-Channel Class A/B Gothic Series Amplifier (800-Watt)
POWER ACOUSTIK OV2-800 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER
800-WATT 2-CHANNEL
4 ohm RMS: 150W X 2
2 ohm RMS: 180W X 2
Bridged mode MONO RMS: 360W
BRIDGED MAX: 800W
FULL MOSFET POWER SUPPLY
PWM CIRCUITRY
FULL SELECTABLE CROSSOVER
3-WAY PROTECTION CIRCUIT
TRI-MODE CAPABLE
VARIABLE LOW PASS 40 HZ - 120 HZ
VARIABLE HIGH PASS 150 HZ - 1.5 KHZ
VARIABLE 18 DB BASS BOOST @ 40 HZ
FREQ RESP: 10 HZ TO 30 KHZ
S/N RATIO: 98 DB
THD: 0.02%
2 ohm STABLE STEREO
SYSTEM DISTRESS INDICATOR
HIGH/LOW LEVEL INPUTS WITH FLOATING GROUND
4-GAUGE POWER/GROUND CONNECTION
PLATINUM RCA CONNECTORS
LINE OUTPUT WITH FLOATING GROUND
BLUE LED
CHROME TOP PLATE PANEL 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER (800-WATT)
Aug 18, 2009 | Power Acoustik GOTHIC OV2-800 Car Audio...
My amp goes in protect mode
Maybe the audio amplifier IC´s are damaged
Feb 06, 2009 | Power Acoustik GOTHIC OV2-1200 Car Audio...
Amp Not working!
If the amp goes into protect mode, it's likely due to shorted output transistors. To eliminate other possible problems, read through the following page:
Amp in Protect Mode - Troubleshooting
If the problems are not with the wiring, follow the link at the bottom of the page to the Amplifier Repair Primer page.
Let me know if you have any other questions.
Sep 20, 2008 | Power Acoustik TS620-2 Synchronized...
Mtx 7500 sub
what amp are u usin?What enclosure 4 speakers do u have?Might not have enouigh voltage 4 the amp.How big are the wire for power 2 amp?what ohm are you playing ,is it compatible to the woofers.Need more info.Model and makes please,but 1st a rating.
Jun 16, 2008 | MTX Car Audio & Video
Car Audio & Video Logo
180 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
