Question about Motorola Mobility i425e Pay-As-You-Go Cell Phone - White/Espresso Trim
Battery does'nt charge, won't hold charge,& time,military,when bat. low fromstand
I425 new. battery won't charge,& clock, military time.
  • johndoyle228 May 12, 2009
    clock goes to military, when battery's low. can these phones be returned?
I took phone back,& exchanged for another, but need my time put on new phone,&would like to use my phone #, from cellular south. 228-861-1114,& need to complete instalation of new phone.
Posted on May 13, 2009
The battery is low after one week. Isnt it supposed to last up to 6 months?
It sounds like you have something that is drawing some power off of it while it is turned off. You will need to track down this parasitic drain or disconnect the battery each time you park it.
Jan 17, 2017 | Cars & Trucks
I got a 69 chevy c10 the starter wire grounded to the exhaust fixd that then it wuldnt charge so changed the voltage regular then starter & silaniod seems like its holdn a charge but still wo
Hey Steve, if you need a jump to start it then every thing is working except battery holding power try putting battery on a SLOW charge for a day then try again when its running check output of altinator with a fully charged battery it should be 12.5-13.5 volts and rise when you rev motor up ,when you jump it im thinking the battery is very low and the altinator is trying to recharge battery and it cant do that in just a few minutes running time or take it on along ride and watch amp gauge .good luck Steve.
Woody
Oct 05, 2014 | Cars & Trucks
My daughter 2004 Kia won't hold a battery charge.
voltage regulator. it may be in the alternator, or remote mounted. ((the alternator can be charging, but if voltage regulator is'nt working then it won't allow voltage to get back to the battery to keep it charged
Sep 07, 2012 | Cars & Trucks
1996 Ford Econoline charging problem
Is this E-150 econoline?
Engine running, take reading at generator bat terminal, what is it? The basics, take reading across battery terminals, everything off. Take second reading at bat terminals, engine running. The second reading should be higher than the first if charging system is working. Was the charging system checked on the vehicle when the generator was checked out?
There could be a wiring circuit problem? The bat terminal at generator is hot all the time, engine running or off.
Aug 02, 2017 | 1996 Ford Econoline
Clock won't go from am to pm
Your clock is set for military time; check the instructions. I believe you have a dual alarm clock that can tell conventional and military time.
Apr 03, 2012 | Audio Players & Recorders
The low battery light remains on after I changed the battery,
Hello
There are two possibilities for this fault. The first one is with its battery itself. If the battery did not hold current, in otherwords, it has weak, proper charge both in volts and amperes won't hold on it, and when the device draw current from it while it works, voltage drop will occur, and low voltage indication will be displayed.
The second chance is due to the charger circuit inside the radio. If charger circuit do not give proper voltage and current to battery, the battery won't charge to its full capacity.
Check it by replacing it with a new battery [batteries] first. If it helps you it's OK. If not, your radio need service, and its charger circuit must be checked well. OK.
Nov 15, 2011 | Emerson CKS2237 Clock Radio
Have a 4-5 yr old Canon S2 IS PowerShot A75 Digital Camera. The batteries are new &/or charged but the camera won't always work reliably - says to change batres. but if I just open the bat. door...
Sometimes, the lower contacts get bent downward after years of use, causing the batteries to ride low in the compartment, and thus making poor contact when the battery door is closed. Try lifting/bending these interior battery contacts upward, so that the batteries ride higher when inserted.
Oct 29, 2011 | Canon PowerShot S2 IS Digital Camera
SmartSEt Clock Radio went to military time
You can reset the time from military to regular time by holding down the time button and let it cycle to the normal time. I hope this information help you with your problem.
Feb 01, 2009 | Emerson Smartset Clock Radio
Emerson clock radio cks 3516 military time
You will need to try some combination of the set button and time button to change the time back to normal time. Try hold both the time and set button for a period of 5-10 seconds and see if this will cycle the time to normal. If not try hold the set button alone for 5-10 seconds and see if this works. If not try holding the time time button for 5-10 seconds and see if that works. If none of the fixes work. Call Emerson customer support at this telephone number 1-800-898-9020 between the hours of 9am-5pm CT. Tell them the make and model number of your Clock/Radio and ask them for assistance with your problem of resetting the time back to normal from military time. They will be able to help you. I hope this information helps you solve your problem.
Getting the clock off military time
With the sytem off, hold down the Alarm Setup button and the On/Off button to switch between 12 hour (AM/PM) and 24 hour (Military) time. If you need the manual go to
http://www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/customer_service/owners/guides/music_system.jsp
Nov 28, 2007 | Bose Wave Radio
Motorola Mobility i425e Pay-As-You-Go Cell Phone - White/Espresso Trim Logo
109 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
