Hp deskjet 5440, using Foomatic hpijs v 8.7.3 driver under Suse 11.1 on attempting to print produces page after page with 3 lines of rubbish on each Can only be stopped by pulling the plug. The printer performs nomally under Windows
  • alexanderosb May 12, 2009
    both the articles you recommended were about Laser printers, the HP Deskjet is an INKJET!
  • alexanderosb May 13, 2009
    All your solutions have been focussed on the printer.
    The printer works perfectly with Windows.
    I need a Linux expert not a printer expert!
    Sergeant:
  • 296 Answers
Hi
visit these websites sited below,i believe u will b helpfull,regardin the problem u r facin wth your printer at the time of printing.
http://www.smartcomputing.com/editorial/article.asp?&bJumpto=true&Isfrm=IN&article=articles/webonly/techsupport/ref1101/47r01/47r01.asp&ArticleID=40453
http://www.smartcomputing.com/Editorial/article.asp?article=articles/archive/r1101/47r01/47r01.asp&guid=
If u find this answer satisfactory,plz don foeget to rate the answer.
all the best
thankyou.
Posted on May 12, 2009
Im looking for a driver for Hp deskjet 825c for windows 7 in south africa
Use the Deskjet 830C/832C drivers. I have a Deskjet 825C and the Deskjet 830C/832C works fine on my Windows 7 64 bit OS. It will work with the 32 bit version as well.
Previously I had Windows Vista installed and found the Deskjet 830C driver worked ok with it as well.
1. Start, Control Panel, Devices and Printers
2. Click Add a printer
3. Click add a local printer
4. Selct Use an existing port
5. In the drop down list select USB001 or 002 or 003, which ever appears. It should say "(Virtual printer port for USB)"
6. click next
7. On the install the printer driver screen under manufacturer select HP
8. Under printers select HP deksjet 830C/832C
9. Click Next
10. If prompted for Which version of the driver do you want to use?" select "Use the driver that is currently installed." and click next
11.Type a name for the printer int the text box for printer name:
12. Click next
13. If you want other computers on your network to be able to share this printer select "Share this printer..." and click next.
14. click print a test page.
15. Click finish.
Download Driver...... HP Deskjet 825c Printer Drivers
Read More help... HP Printer Support
Thanks,
Aug 18, 2014 | HP DeskJet 825c InkJet Printer
I have a HP F380 All in One Deskjet Printer Mac OS 10.5.8 Printing for over 2 years using Airport Scanning I need to connect by usb Issue: I reset the settings and can't find the driver I used to...
Thanks for using Fixya.
First, Uninstall your HP F380 and then again reinstall it.
If your printer is connected via usb to airport extreme you will have to download and install the following.
1. espgs-7.07.1.ppc.dmg
2. hpijs-foomatic-2.0.2.ppc.dmg
Do this by going to The Linux Foundation (http://www.linux-foundation.org/en/OpenPrinting/MacOSX/hpijs)
Install in the order listed above, they both must be installed for this to work.
Then do the following:
1. Go to > system preferences > print & fax
2. Click "+" to add a printer
3. The HP F380 will be listed with the connection type "Bonjour"
4. Highlight this printer
5. At the bottom of the window you will see the option for "Print Using" and than you can choose something from the drop down menu.
6. Scroll down to "HP" and choose that
7. This now propagates a window full of HP printers including the HP F380 drivers that you installed above.
8. Scroll down until you see "HP F380 FOOTMATIC" and highlight this.
9. Click "add".
That's it, your done and it should work.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Mar 18, 2010 | Office Equipment & Supplies
When I try to print a page it only prints the first sentence without the first few words and the second sentence without the last few words all the way down the page. Sometimes it prints the first two...
Install the temporary drivers
If the product is connected via network perform the below steps to add temporary drivers
1.On the Windows task bar, click the Start icon, click Control Panel, and then double-click Printers and Faxes.
2.Click Add a Printer.
3.Select Local printer attached to this computer. Please uncheck the option ‘Automatically detect plug and play printers’.
4.In the Add Printer dialog box, Select Standard TCP/IP port, and then click Next.
5.In the next window type IP Address of the printer. You can get the IP Address of your All-in-One by printing a Network configuration page on your All-in-One.
6.Under Manufacturer, scroll to and click HP.
7.Under Printers, scroll to and click hp DeskJet 990c, and then click Next . The Type a printer name dialog box opens.
8.Make sure hp DeskJet 990c is listed in the Printer name box, click the Set as the default printer checkbox to clear it, and then click Next.
9.In the Printer Sharing dialog box, select the appropriate radio button to share the print driver or not, and then click Next.
10.Click Print a test page to make sure the print driver is working correctly, and then click Close. Click Troubleshoot printer problems to solve the issue if the test page does not print correctly.
11.Click Finish to complete the installation.
If the product is connected via USB Cable perform the below steps to add temporaty drivers
3.In the Add Printer dialog box, Select USB001 port, and then click Next.
4.Under Manufacturer, scroll to and click HP.
5.Under Printers, scroll to and click hp DeskJet 990c, and then click Next . The Type a printer name dialog box opens.
6.Make sure hp DeskJet 990c is listed in the Printer name box, click the Set as the default printer checkbox to clear it, and then click Next.
7.In the Printer Sharing dialog box, select the appropriate radio button to share the print driver or not, and then click Next.
8.Click Print a test page to make sure the print driver is working correctly, and then click Close. Click Troubleshoot printer problems to solve the issue if the test page does not print correctly.
9.Click Finish to complete the installation.
After adding the temporary drivers, while printing from applicaiton you should need to do the following steps
1.In the program you are printing from, click File, and then click Print. The Print dialog box opens.
2.In the Name drop-down list, click hp DeskJet 990c, and then click OK to print.
Sep 11, 2009 | HP Office Equipment & Supplies
Hp deskjet 9650 not compatible with Vista 64-bit
Hp Deskjet 9650 printer owner, sorry to inform that there is no Microsoft Windows Vista operating system printer driver solution available for your printer. But there is an alternative way to workaround it so that you can do basic printing with your printer.
As a workaround, an alternate printer driver solution included in Microsoft Windows Vista operating system can be used to perform basic printing to the printer. However you might find that some of the product features are no longer available when using this alternate printer driver, but that is your best option right now.
The alternative HP printer driver that will work with your printer is HP Deskjet 9800.
The Next thing you do is: Install the driver for HP deskjet 9800
1. Verify that the Universal Serial Bus (USB) cable is NOT connected to the printer.
2. Click Start , click Settings , and then click Printers .
3. Click Add a printer .
4. Click Add a local printer .
5. Select the Use an existing port check box.
6. In the Use an existing port drop-down list, select LPT1: (Printer Port) and then click Next .
7. Under Manufacturer on the Install the printer driver dialog box, select HP .
8. Under Printers , select the appropriate alternate driver for the printer (deskjet 9800) and then click Next .
9. In the Printer name text box, type the printer name and then click Next . The printer driver starts to install.
NOTE: The name of the alternate driver displays as the default name. Change this name to the name of the printer, if desired.
10. After the screen stating that the printer was successfully added displays, connect the USB cable / Parallel cable to the printer and to the computer.
11. On the Found New Hardware screen, click Cancel .
12. For USB connected printer, please proceed to step three . For Parallel port connected printer, please proceed to step four .
NOTE: If multiple pop-up windows display, click Cancel on each window.
Next is: Configure the printer
1. In the printer folder, right-click on the name of the printer and then click Properties .
2. Click the Ports tab.
3. Change the port from LPT1 to the newly created USB port, click Apply .
Last step: Print a test page
1. Click the General tab.
2. Click Print Test Page .
Good luck Cheers!!!
Apr 26, 2009 | HP DESKJET PRINTER, HP OR COMPATIBLE
Printer Driver
You can download the drivers for your printer , both on MAc and Windows, from the link below:
HP Deskjet 5440 Printer series - Download drivers and software
Mar 07, 2009 | HP Deskjet 5440 InkJet Photo Printer
Cancel print on a HP Deskjet 5440
on the bottom right side of your computer screen you will find a icon of a printer.click on it .a screen with the printer driver will apper and the job you printed will be listed on that screen.right click on it and then click "cancel"you can leave the printer turned of as it will take a few minutes to do this.during this time the printer will keep pushing out paper if it is not turned off.
Nov 10, 2008 | HP Deskjet 5440 InkJet Photo Printer
Printer
Windows comes with drivers for many HP printers.
You can try to install your HP deskjet 5440 by going to (depending on operating system) "Start", "Printers and Faxes", "Add Printer". Select a local port. Select "HP" and Model "HP Deskjet 5440".
If 5440 is not in your list, or if you want the latest driver, you can download the driver for your specific operating system here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=445441&lc=en&cc=us&dlc=en&lang=en&cc=us
Aug 02, 2008 | HP Deskjet 5440 InkJet Photo Printer
HP deskjet 5440
Never use alcohol, instead use distilled water or just water...
Seems like your cartridge need to be changed, maybe is very old in production date and ink is no more so fluid.
Dec 18, 2007 | HP Deskjet 5440 InkJet Photo Printer
51 people viewed this question
k24674
