Question about Maytag Ensignia 3.3 cu. ft. Top Load Washer
The washer doesn't always fill up when we turn it on
Our washing machine doesn't always fill up even though the water runs
    President:
  • 1,136 Answers
Hi, Dose the water fill the first time you start it but, then will not fill in the rinse cycle? Does the water continually try to fill but never gets to the top?
I want to help.
Thanks
Vic
Posted on May 12, 2009
Gday,ive got a simpson eziset 950 top load washing machine,it does the first wash sequence and pumps out,but the pump keeps pumping even though its empty and it wont go any further,wont re fill or spin,and...
This is a seriously wild stab in the dark at your problem. Washers usually have a totally jacked-up schematic somewhere in them. I never can figure them out.
But, I think your fill switch is stuck. The ones I've worked on use a type of pressure switch where water rises in a tube and makes the switch.
Find the switch and see what it is doing. The washer thinks water is still in the tub because the switch is telling it so.
Clean the lint trap also.
Our KenMore washer also automatically selects warm and it ain't broke.
Sep 16, 2017 | Dishwashers
Washer water will not turn off . You have to turn water off & let wash & then turn back on to rinse
Hello, Thank You for using FixYa. I will be helping you today.Unplug the machine if when you turn the water on and it fills with unit unplugged you need a new fill valve. If its unplugged and water on and it doesn't run its the timer
Thank You and please rate my answer if it was helpful..
Jun 14, 2011 | Admiral AW22 Top Load Washer
Turning on the water valve fills the washer with running water even when the washer is not turned on. was the washer incorrectly installed?
probably not.
you could have a defective water inlet valve that lets the water in even though there is no power to that valve.
check that valve, remove it and blow unto it. there should be no air passing thru.
i hope i was able to help...
cheers,
drcool
Aug 13, 2008 | GE Washing Machines
Water in my washing machine
it sounds like you have a leaking water valve, you will have to replace the mixing valve, For now turn the water off at the wall suppling water to the machine. When you want to use the washer turn on water, when its done with the cycle turn the water off.
Note: unplugging the machine will not stop the water from running
May 13, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
u will need to replace the water solenoid that is letting the water in it is a fault that does occur with all solenoids,theses are were the water pipes connect to
Sep 10, 2007 | Maytag PAV2300 Top Load Washer
dudett, uplug the washer and turn the water valves on. If the washer is filling with the washer unplugged the valve is bad. Part number 22001196. Not a hard job. If you need help installing, just e-mail the cat here at catriver1@gmail.com Catriver..post back.
Feb 19, 2007 | Maytag Performa PAV2200
Maytag Ensignia 3.3 cu. ft. Top Load Washer Logo
163 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
